Question about Zyxel P660HW-D1 Router
Port Forwarding I just bought a new computer and I need to do port forwarding in order to use torrents. I did this successfully on my previous machine and I followed to same steps this time (i'm using the same Zyxel router as before) but the DNS servers appeared to have changed when i check on the ipconfig/all command - the DNS is now the default ip address (192.168.1.1) - I have set up a static ip address but it's still not forwarding.
  • scoopdog Jan 10, 2009
    having the very same problem i think i need to interogate the actual router itself but it will not let me into the settings just sits on the status screen ?????any help would be great
Hello just got sorted, hope this is helpful ,,,i logged onto port forwarding.com and a long story short , basically had to interigate my zyxel router, what you do is fix the ip add of your wireless connection (the computer) to a manual fix eg. mine is now fixed to 192.168.1.40 with a port tunnel 46207(utorrent preferences)i picked this out of my head as there is a scale from one no. to another.   you then get the password to your router and get into its internal settings via password and go to the port forwarding section, you then tell the router that the computer has a fixed ip add (the one above ) and dedicate a fixed port or tunnell/window mine is 46207save this setting on your router and your home and dry, basically your telling the router that the computer has a fixed add, with port window??? and off it goes ,,,,portfward.com tells al
Posted on Jan 11, 2009
IP Camera Port Forwarding
The best way to find out what is being forwarded is to look at the traffic with the Wireshark program. You can install this from the Internet.
Wireshark is perfect for this but you have to learn how to filter traffic or there will be too much information collected. It is also regarded as (a bit of) a burglar tool so don't use it at work without permission.
I would recommend that you connect a PC to a wired port on the inside LAN and configure the router to forward outside requests to the PC. When you run wireshark on the inside PC with a filter that selects for tcp port 80 (or tcp port == 80) you will see traffic forwarded from the router.
Use your outside machine to request a page from the router's outside address and the port you are forwarding. If you have forwarding set up correctly, you should see a TCP connection attempt. If you are not running a web server on the inside PC, there will be no connection so you will only see the SYN packet from.
outside. If you have a web server on port 80, you will see a fair number of packets in both directions. (SYN -- SYN-ACK -- SYN -- some HTTP Headers an HTTP GET / a response and FIN -- FIN-ACK).
Once you see successful port forwarding (your are forwarding TCP packets, right?) at the PC, change the destination of the forwarding to the camera.
This is really technical but Wireshark is so good that it is quite easy to use.
Sep 10, 2012 | Computers & Internet
Forwarding ports
Port Forwarding is explained indeepth by the torrent companies help FAQs section,
Heres a link that may helps you too....
http://www.fixya.com/support/r4582466-set_up_speed_touch_5x6v6_broadband_modem
In the Admin function you can accept the ports if you have the correct servers address's
You must add them to your firewalls permission settings and then try the test again,
Note ,
Even with Port Forwarding set up,
you will also require the correct band width and downloader from the torrent site,
ie,
Bit Comet and Bitcomet Excelerator
The downloader and the high speed function,together.
Hope this helps,Misterdj
May 03, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Port Forwarding with Kaspersky Internet Security 2009
Anti Hacker -> Settings -> Enable Firewall -> Low Security -> Settings ->
Rules For Applications -> Add -> Torrent
Edit Rules -> Add -> Rule Name -> utorrent
Properties -> Remote port (selected)
properties -> Local Port (selected)
Rule description -> Remote Port - >(enter the port) -> DEPENDS YOUR CONFIG
Rule description -> Local Port - >(enter the port) -> DEPENDS YOUR CONFIG
Allow Inbound and Outbound TCP connection, where :
Remote Port: DEPENDS YOUR CONFIG
Local Port : DEPENDS YOUR CONFIG
May 25, 2009 | U.S. Robotics MAXg(USR9108) Wireless...
I have D link router DES 1008 V. I cant do port forwarding. I cant download torrents.
Check out this link, everything you need to know about port forwarding and more. http://portforward.com/
Apr 27, 2009 | Computers & Internet
Port forwarding on utorret
Depending on the model you have, you need to enter "applications & Gaming" chose "Port range" and set it to the same Port as your torrent-program, dont forget to point to the IP address on the computer.
Need more, dont hesitate to ask!
/Teis
Helpfull? dont forget to vote
Nov 23, 2008 | Computers & Internet
Port Forwarding
Try here:
http://www.portforward.com
Aug 11, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Help with my router
You did not have this problem before because port forwarding was set on the previous router settings, or you were using a modem ( no firewall) .
Here are instruction for port forwarding
Here are more instuctions
One last thing, if your computer is powerful enough (1gb memory would be good), use Azureus, is much better.
Jun 08, 2008 | Linksys Wireless-G Broadband Router
Port forwarding
hi there,
this is a basic step used to forward ports to your system.
Port Forwarding Steps for Routers 1. Log into your router. Usually the URL is http://192.168.1.1/, and enter the username , and the password . If you have never set a password, the password (which you should change) is admin. Consult the manual if you have never set up your router before or need to reset the password. 2. Click on the "Applications & Gaming" tab or Under Advanced, click Port Forwarding.
3. Click on the "Port Range Forward" tab .
4. In the "application" field, type "web" (if you are forwarding wb traffic on port 80) or "torrent" (if you are forwarding bittorrent traffic on port 40156). This is just a "nickname" so that you can recognize what you were trying to do when you come back to it.
5. In the "Start" field, enter: 80
6. In the "End" field, also enter: 80
7. Set "Protocol" to TCP. Web and Bittorrent servers use only TCP, so there's no reason fo forward UDP traffic too and create an unnecessary security risk.
8. In the "IP Address" field, enter: 192.168.1.11 or your system IP address.
9. Click "Save Settings." Forwarding should begin immediately.
Apr 15, 2008 | Computers & Internet
Zyxel P660HW-D1 Router Logo
287 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
