Question about Sharp R-1405 / R-140 Microwave Oven
Fuses keep blowing out
My microwave oven suddenly just started popping fuses. The fuse is 250v 20 amp. when i put in a new fuse and turn the oven on it sounds like it is going to start for about 2 seconds then the fuse blows. I have killed 5 fuses so far so I believe it is time for a diffrent approach. Any suggestions?
  • Anonymous Feb 05, 2009
    I have a similar problem Except our first fuse blew after 25 years. When we opened up the micro we found a spare fuse inside. We replaced the blown fuse and it worked fine....but only for a few days. It blew again this morning. Should I just go buy a couple more fuses? Is it time for a new Microwave? Could the spare old fuse inside have gone bad after all these years? Any suggestions would be helpul. Thank you.
  • Sharp Master
  • 9,156 Answers
In case it's still helpful, I'll inject a little sanity into the replies.
If the fuse blows as soon as you hit Start, it's probably a shorted high-voltage capacitor. That's usually economical to repair.
If the fuse blows a few seconds after you hit Start, it's probably a shorting high-voltage transformer. That's usually not economical to repair.
It's not radiation (non-ionizing RF by the way) that's the hazard, it's the voltages.
Posted on Nov 05, 2007
  • William Miller
    William Miller Nov 05, 2007
    ALSO:
    We have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
    Problem Solver:
  • 6 Answers
I have the same experience in replacing five microwave fuses within two days and cost me almost ten dollars. They are expensive. True somewhere inside the circuit had a short. But I could not find any lead in locating the faults, nothing burnt or smell inside the microwave. However I noticed that this blowing fuse acts happened after I cleaning the inside of the microwave oven with grease removal solution. At last I found a thick grease (over ten years history) covered those switches that behind the door notches. So I disconnected all the connection wires from those switches (make sure to draw a trace map of all wire connection before disconnected them, so you can put them back in order), pull out the switches from the cradle and immersed them in the diluted organic grease removal solution for overnight. Gave them a good clean water bath and dry them good before installed them back to the cradles and connected all wires back. I have been using the microwave for more than two months now, no more blown fuse. Please be aware I am not an expert but just share this with you. The greasy switches might be one of the causes. One final warning, please make sure you have the proper skill and knowledge to do this, otherwise find some friend to help you. Hope this help!
Posted on Mar 08, 2009
  • nty Young Oct 22, 2010
    Here is ntyfixer again. Just recap what happened to my microwave. Good Lord! It is running like new and no more blown fuse since I cleaned the switches over a year ago.
    President:
  • 3,130 Answers
Yes a fuse blows because there is an internal short in the unit. The more you replace the fuse and hopes it will fix it, the more damage you may cause and maybe even cause a fire. A fuse blows in a piece of equipment as a safety feature. most fuses do not blow because they simply go bad, they blow because of a problem. First thing would be to check the door switch alighnment. next would be to check the Hi voltage diode and the capacitor, next test should be the magnatron for a short. If you do not have any knowledge on microwaves, call in a pro to assist you in this repair ans there is alot of high voltage inside this puppy. Good Luck
Posted on Apr 08, 2007
Throw the darn Microwave out before you kill yourself with Radiation. Blown Fuse is a sign of Sorted circuit to ground. With a microwave they are cheap now a days and does not warrant the risk.
Posted on Apr 18, 2007
Panasonic microwave keeps blowing fuses jus put in a new fuse but after a few days blowes another fuse
Luzetta
This is a common problem with microwave ovens and is easy to diagnose. Whenever I replace the fuse, I always perform this test. I don't want the unit coming back in a couple of days with the same problem.
Install a known good fuse. It should be a 20 Amp, Slo-Blo, with a ceramic body. Leave the cover off. Place a container with at least 2 cups of water inside the unit. Cook on high for at least 5 minutes. As soon as it finishes, UNPLUG the unit and feel the fuse. If it is extremely hot, the fuse is going to fail in a short period of time. The fusible material inside the fuse is melting from this excessive heat. It only takes a small amount of resistance at the fuse holder contacts to create this amount of heat. Replace the fuse holder rated at least 20 Amps. The higher the better.
Nov 30, 2017 | Panasonic Microwave Ovens
How do I fix a blown microwave fuse?
How to Fix a Microwave Oven - Simple Fuse Replacement ...
? 18:04
https://www.youtube.com/watch?v=IN0BqiVX5ds
May 21, 2013 - Uploaded by GuruBrew
How to Fix a Microwave Oven - Simple Fuse Replacement. GuruBrew .... I'm hoping it's just a blown fuse ...
Whirlpool Microwave Keeps Blowing Fuses - YouTube
? 2:35
https://www.youtube.com/watch?v=KGQgendKTR0
May 7, 2013 - Uploaded by AdamDIY
Whirlpool Microwave Keeps Blowing Fuses ... MicrowaveThermal Fuse Replacement - GE Microwave ...
Microwave Oven Repair 101 ' DoItYourself.com
Dec 06, 2015 | In Microwave Ovens
Microwave blows fuses
A short likely in the wiring for the light or at the safety switch embedded on the side where the door closes----be careful as a 20 amp fuse takes something major to take out.
(for it to blow)
This might be best left to a qualified service person.
Dec 22, 2012 | Microwave Ovens
My Maytag Microwave is blowing the 250v- 20a fuse behind the key panel on the black wire. It melted the fuse holder mounted to the main body of the unit. Any thoughts on why?
The magnetron is shorted, the keypad control board is bad, blowing fuses. If less than 7 years old it has a inverter board that can be trouble, But with the level of work and parts it will easily exceed the cost of a new microwave oven.
Apr 07, 2012 | Magic Chef CMV1100 Microwave Oven
Viking Microwave Model VMOC205SS little over 4
9 amps is approx. correct. Does magnatron make an odd sound when running? If not, you will need to discharge cap then clean terminals with alcahol. Replace diode as well. Should run correctly.If blows again, replace magnatron. Suggest you put a 12 amp fast blow fuse in circuit and nor a 20 fuse.If you dont have a grill or an oven, use a 10 amp fuse.
Sep 17, 2009 | Viking VMOC205SS Microwave Oven
Dead Microwave
Check your plug and change the fuse there also.
You might need to rechange the 20 amp 250v fuse behind the control panel again due to the recent spark.
If none of this works then i'm afraid a certified technician needs to check the power packs and boards
May 22, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Blowing 25 amp fuses
In that case the outlet your using is pushing out too much electricity. Try calling your local electric company for help or a professional electric repair man.
May 21, 2009 | Emerson Black Microwave Oven
Sanyo EMS1000 microwave. Keeps blowing 13amp plug fuse.
New or older wiring to microwave? Is there a GFI circuit installed?
Apr 27, 2009 | Maytag MMC5000 Microwave Oven
My Emerson Microwave Model # MWG9111SL keeps blowing fuses..
You have a shorted high voltage capacitor.
Here is a link you or someone you know can use to test it, but please read the safety info:
http://www.gallawa.com/microtech/cap_test.html
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
Nov 24, 2008 | Emerson Black Microwave Oven
Microwave fuse keeps blowing
ckeck your door switches and h.v doides if you know how if do not get serviced by technician
Mar 21, 2008 | Microwave Ovens
Sharp R-1405 / R-140 Microwave Oven Logo
3,347 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
