Question about StarTech.com StarView SV211K 2-port KVM Switch
I cannot find the menu which allows me to input starview codes
When I try to enter starview codes I cannot get the screen where you in put the code
  • glamour puss Dec 22, 2008
    i can't get into the menu to enter the new codes
  • diceyreilly Dec 22, 2008
    can"t get codes for starview box no letters on remote
I just forgot da menu pin and 1570 isnt working what should i do please help me
Posted on Jan 16, 2009
    Problem Solver:
  • 4 Answers
Press menu 1570
press ok on nagravision
letters are coloured buttons and audio and pause
Posted on Dec 22, 2008
STARVIEW REMOTE CONTROL CODE
Could do with being a bit more specific, in the sense that your either asking for a code to enter into a Univeral Remote that would allow it to function as a Starview Remote, or your asking about the code you enter on the Starview Remote itself in order to access the hidden menu.
If the latter is the case, then presuming you know what uou need to do before you get to the point before you enter the code, then try using "8989".
I've heard 0000
Sep 29, 2010 | StarTech.com StarView IP SV1100KVMIP...
Cant enter codes in Eurovox ex1000 sl
if you need to manually enter the keys a different procedure is required to previous versions of the firmware.
To access the key entry screen try the following:
On the remote press "Menu".
Highlight "Language Settings" and press "OK".
Highlight "1st audio lang" or "2nd audio lang" or "Subtitle lang" NOT "Menu language", then press the buttons 1,9,6,8 in order.
The key entry screen should now be visible.
Use the left/right arrow keys or "FAV" button to find the "NagraVision" screen which contains the keys for UK service providers.
to reveal the "Emulation" and "EMM Capture" Highlight "Menu language"
Aug 21, 2009 | StarTech.com StarView SV211K 2-port KVM...
How do i access factopry settings on starview box,
Right..press menu then 0000 to enter factory settings...scan then go back to menu..press 1570 another menu will appear..make sure your emu key is on (at the bottom)..then enter nagravision..and enter codes..you will see you can enter letters by useing the coloured buttons on your remote (just look at the screen to see what I mean) ...and then when codes are installed just exit back to tv (just keep pressing the back button until you get back to tv..) and you should be up and running....if you have any problems let me know..and I will do my best to help.
Good luck
Gord
Apr 15, 2009 | StarTech.com StarView SV211K 2-port KVM...
Need CODE to get second pin up on starview 2(THE BOX PVR)
You enter 1570.
Fixya!
Chris (ziraffa)
ps To put keys in manually do as follows.
Press menu button
Press 1570 this takes you into secret menu.
Now hit ok on nagravision
Next make sure your cable provider is listed at top NTL or TELEWEST C&W ect
Now change key 00
(YOU MUST SAVE EACH KEY INDIVIDUALLY - I.E. AFTER CHANGING KEY 00 MAKE SURE
YOU STORE BEFORE CHANGING KEY 01 (TO STORE PRESS OK)
Jan 14, 2009 | StarTech.com StarView SV211K 2-port KVM...
How do I put the codes into the starview super box?
press menu,
press1570
Nagravision screen Look down list make sure EMU is set ti ON press ok,
Code screen make sure service provider is in tad. Ntel. 5401, Tw.5A01,Cw.5C01.
Go down to the bottom and enter codes store each code as you enter them.
Go to the 00 tab press right to 01 then change codes and save each as entered.
exit out.
Ntel. codes.
0. 3F B8 36 62 72 E5 E2 76
1. 35 5E D6 40 6E AA 99 41
tw. codes.
0. C0 F6 61 87 91 F9 67 57
1. F0 83 35 E5 28 40 49 B2
cw. codes.
0 .D4 A3 5D EB 7B F3 69 59
1. 27 77 A1 FC 8F 9D 34 76
Dec 12, 2008 | StarTech.com StarView SV211K 2-port KVM...
Starview 4 thebox super usb
hope this is of help to you if not let me know .
press menu.
press 1570.
look down list to make sure EMU is set to ON . press ok.
code screen service provider tab should be 5A01.
00. go to the bottom of screen and change the codes saving each code entered.
go to the 00 tab and press right to 01. go to the code tab and change codes saving each code as entered.
0.C0 F6 61 87 91 F9 67 57
1.F0 83 35 E5 28 40 49 B2
Dec 11, 2008 | StarTech.com StarView SV211K 2-port KVM...
Code
press menu
press 1570
nagravision press ok
00 enter codes at bottom of screen saving each code.
go back to 00 and press right on remote t0 01.
01 enter codes saving each code entered. then exit out
Dec 02, 2008 | StarTech.com StarView SV211K 2-port KVM...
Saving codes onto starview
go into menu bring codes screen up got to 00 tab and press save change codes saving each code that you have entered. Then got to 01 tab press save then enter new codes saving each code entered. hope this is of help.
Dec 01, 2008 | StarTech.com StarView SV211K 2-port KVM...
How to input codes in the Eruovox maxv
OK.........PRESS THE MENU KEY..........THEN THE YELLOW KEY ON YOUR REMOTE.YOU WILL SEE BOXES USE UR REMOTE TO PUT THE CODES IN SUCH AS(RADIO........P+ INFO ETC)THESE SHOULD SHOW UP AT BOTTOM SCREEN TELLING YOU WHICH ONES TO USE ON REMOTE??? THEN ON TOPLINE THERES 4BOXES??? ENTER............5A 01.....THERES 2LINES BELOW THE CODES ARE BELOW FOR YOU
98 B0 BA 52 D3 21 08 B4
D2 EA 29 B7 B5 52 E9 AD
USE THE REMOTE TO ENTER CODES DO YOU NO WHAT I MEAN???
LIKE FOR LETTER "a" ITS THE BUTTON.........TV............ON REMOTE
THE LETTERS ARE PUT IN WITH UR REMOTE IF U LOOK AT UR SCREEN AT BOTTOM IT HELPS YOU TO NO WHICH BUTTONS TO USE
HOPE THAT HELPS IF NOT EMAIL ME
Nov 29, 2008 | StarTech.com StarView SV211K 2-port KVM...
Starview codes
go to http://thechatterbox.cc and download the Chatterbox toolbar. Then Downloada program called KeyMaster on there.
For EUROVOX
Press MENU then press the Yellow button
For STARVIEW
Pres MENU then press 1570, go to Nagravision, Either enter provider number (look below) or Select your operator.
Now go to 00, Input Code into "DATA", press OK, Now go back up to 00 and press Right button, to change it to 01, Enter the 01 code in.
Provider ID is as follows,
Before Virgin Media took over, type in what ever code is next to your old supplier..
NTL - 5401
TELEWEST - 5a01
C&W - 5c01
When you find your codes of the Keymaster, you should have Key 00 and 01,
On your screen go to 00 and type the code you got of the internet,
Now do the same for 01,
The codes will change every day until new software is released.
Use the key on the bottom of your screen to type in the Letters.
Keys as of 29/11/2008 (Might have changed by the time you read this)
NTL - 00: CD 11 58 05 EE 96 E7 F3 // 01: EA B7 BF B2 D5 AA 46 AB
C&W - 00: 00 58 8D CF 27 98 04 ED // 01: 2A E0 72 B0 9E 07 9B 5D
TW - 00: 98 B0 BA 52 D3 21 08 B4 // 01: D2 EA 29 B7 B5 52 E9 AD
Aug 29, 2008 | StarTech.com StarView SV211K 2-port KVM...
StarTech.com StarView SV211K 2-port KVM Switch Logo
252 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
