Question about Shuttle 9094 Emax Remote Control Helicopter
Shuttle 9094 r/c helicopter spinning on take-off
Hello. having recently purchased the mentioned remote control helicopter i have found it almost impossible to start the chopper without it spinning on take-off. the instruction manual is in poor english but mentions calibrating the "potentiometer" on the "chopper circuit board" via adjusting a screw... however, i can not seem to locate the potentiometer screw and am unsure where the "trim" button is either.
can you help me please and advise of how i can try to make the chopper take-off without spinning..!
your help would be greatly appreciated!
thankyou
  • faridKL Mar 04, 2009
    can someone post the photo where to make an adjustment....
  • 15,935 Answers
Usually trim adjustments are on the controller... not on the vehicle itself.
a potentiometer os a fancy word for dial adjustment. It wont be a metal screw, but probably a metal square with a plastic looking slot that can be turned. usually white or blue plastic
Posted on Dec 22, 2008
My silver bullet helicopter wont take off, the top blade is spinning but the bottom one isnt
Kindly check the rotor carefuly.. there is one white/black color rotor fixed on the bar of Motor rotates whith motor and there is anoter rotator which attached parally with its i.e once motor rotator moves the another ones also moves (which connected with the rod of Blades) some times these rotators gets loose by time and makes the rotation of Blades weak. kindly connect the same tightly and check....
Jan 01, 2014 | Shuttle 9094 Emax Remote Control...
My bottom propellers won't turn. What could be the trouble? Only flew this a few times.
Same happened to me. I've found out that the white gear at the end of the right motor, that conects to the wheel and makes the blades spin, has been worn out by the harder plastic of the wheel itslef. So now they are no more in contact and thus the lower blades wont sping. I temporarily solved it pulling the white gear a bit lower but it lasted only for a couple flights more :-(
Jan 06, 2011 | Shuttle 9094 Emax Remote Control...
I have Brookstones silver bullet u control helicopter and have a problem. I crashed it, and when I went to fly it again it seems like the bottom blade is hit off the tail of the helicopter. Do I just...
Sometimes the metal weights fall out of the top rotating bar causing the blades to be out of balance and the bottom blade to hit the tail. Check to see if both the weights are in the top bar.
Dec 27, 2010 | Shuttle 9094 Emax Remote Control...
Silver bullet helicopter wont stop spinning counterclockwise
i would continue to hold the trim. this happended to mine and i held the trim for a couple of seconds and it leveled out. also i have a problem, mine wont generate enough lift to take off. do you have a solution for that?
Feb 13, 2010 | Shuttle 9094 Emax Remote Control...
My new u-control helicopter is experencing spinning
how much is it spinning after and if not to much adjust the st. trim on the controller.
Aug 06, 2009 | Shuttle 9094 Emax Remote Control...
Shuttle 9094 Emax Remote Control Helicopter Logo
1,839 people viewed this question
Top Shuttle Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Shuttle Toy Expert? Answer questions, earn points and help others
