Question about Weather King 12AJA6001AH Air Conditioner
Heating my airconditioner comes on when the heat pump comes on
  • 700 Answers
Your condensing unit shoould run when the heat is on. Noe what is the temperature of the discharge air at the grilles. If it's really cole then the reversing valve may not be working correctly and you may be ablre to go to emergency heat only until you get a technician out to see why.
Posted on Dec 22, 2008
Remote control required for airconditioner
Not too many units only work with remote control...try using Bing or Google to find your problem and solution to the answers that you seek.
May 18, 2013 | Heating & Cooling
I am looking for the reset button on my Amana heat pump the outside unit fan inside operates but the compressor does not run
There are no simple reset buttons for that...
Here is a tip about troubleshooting your airconditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 11, 2011 | Amana Heating & Cooling
Installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
May 09, 2010 | Heating & Cooling
WHY DOES MY RHEEM RBHC-14J11SFD BLOW ONLY COLD AIR? THE AIRCONDITIONER WORKS, HOWEVER THE HEAT DOES NOT TURN ON. THE THERMOSTAT IS SET TO ON AND TO THE HEAT POSITION.
Heat pumps tend to blow a much lower temperature outlet air than a gas fired unit would. Is this your first year with this furnace?  Depending on your outside temps, an auxiliary heat strip may not be operating properly.
Jan 05, 2010 | Heating & Cooling
Heating part of split system not working but fan outside is
if the cooling is ok then the reversing valve outside may be faulty
May 28, 2009 | Heating & Cooling
Need to know what the wiring diagram is for a ar30-1 airconditioner, for a home
Sounds like a Goodman A/C. Wires R red Y yellow cool W white heat Green FAn Blue or brown will be common. O or orange if heat pump goes to orange outside unit.
May 08, 2009 | Heating & Cooling
Airconditioner LG LSk181-N2 shutting off
Sounds like your aircon is stuck on heating mode. Or. The outdoor fan speed is affected by ambient temperature, or low refrigerant. In heating mode the indoor fan will come on for a while to sense temperature and will then wait for the outdoor unit to pump up pressure and build up heat.
Feb 01, 2009 | LG LS-K1830CL Cool Mini Split Air...
After RTH6400 installation heat strip is no longer actuated
http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Thermostats/Do-It-Yourself/Programmable/5-1-1/Default.htm look at the very last part of thius page and you will see that the particular thermostat does not work for heat pumps tha have auxillary heat. Sorry for being the bearer of bad news but you need to upgrade the selection to make it work right.
Jan 24, 2009 | Honeywell Electronic Programmable...
Switching from air conditioner to a haier heat pump
(only the control wires from the thermostat to the inside and outside unit.A regular airconditioner has a 4--5 wires control and a heat pump has 7--8 wires control..!
Jun 02, 2008 | Haier hwr10xc6 Air Conditioner
Weather King 12AJA6001AH Air Conditioner Logo
65 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
