Question about Blueant Supertooth Light Bluetooth Speaker Car Kit
How can i reactivate my blueant blue tooth on my motorola ic902?
  • 827 Answers
Try following the below instructions, if you haven't already tried them..
First Time Pairing to your Bluetooth Mobile Phone
When you turn ON your Supertooth Light for the first time, it will automatically go into Pairing mode ready to be found by devices in Bluetooth searches. This will be the case until you have successfully paired a phone. If you have already paired a
phone, please go to the next section.
1. Power ON your Supertooth Light. The Bluetooth Indicator (3) will turn a blinking
red/blue, The kit is now in pairing mode.
2. Go to Point 3 in the next section, “Pairing to your Bluetooth Mobile phone”
Pair the SUPERTOOTH LIGHT to your Bluetooth mobile phone to create a “Pairing”
link, or audio connection between the two. This has to be only done once when first connecting each new phone.
1. From OFF, Press and Hold the Accept Button (1).
2. While holding the Accept Button (1), switch the kit on (Press-and-release the
Microphone Shaft (5)).
3. The Bluetooth Indicator (3) will turn a blinking red/blue, when you see
this, release the Accept Button (1). The kit is now in pairing mode.
4. While the kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function then execute a Bluetooth search, or discover. (See your phone’s manual for specific instructions.)
5. When the phone displays the list of Bluetooth devices, select ST LIGHT.
6. When the phone asks for the password, enter 0000 and press Ok.
7. Set the ST LIGHT as a trusted/authorized device, if this is option in your phone.
Important Note: The kit is now paired. Most phones automatically connect to the
kit after pairing. With some phones you need to connect manually after pairing.
Go back to Bluetooth > Paired devices > highlight ST LIGHT > press
Options > then press Connect.
When connected you may see the Bluetooth Symbol on your phone change
slightly, either inverting in color or changing to a headset or car symbol. The kit
is now ready to use.
Repeat steps 1 -7 above for each new phone you want to use with the
Supertooth Light.
This was copied from the user manual, which you may or may not have already.. Here's a link to a .pdf file of the manual which you can also save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Posted on Dec 24, 2008
UNLOCK motorola ic902 phone with sprint service
Hi visit Superunlockcodes.com to unlock your Motorola IC902 mobile from Sprint network .Here they ask you the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
Nov 26, 2012 | Motorola Mobility ic902 Cellular Phone
My blueantz9 v3.1 does not want to pair up with my motorolai1 what do i do
It should pair. Both are comparable. First turn your Blue Tooth on and then follow these steps -
  1. Press the "find it"
  2. Now press "settings"
  3. Now press "wireless controls"
  4. Now press "blue tooth settings"
  5. Now press the "box" next to the word Blue Tooth to scan for a signal from your Ant
  6. Now look at the bottom of the screen and wait for it to find the Ant Blue Tooth
  7. When it find the signal then press "touch to connect"
If your Ant is still not pairing then either the phone of the Ant is malfunctioning.
regards, Tony
Apr 15, 2011 | Blueant Z9 Wireless Headset
My iphone 4 cannot discover my BlueAnt Z9i. I put the headset right on tp of the phone and it just says "seaching". The headset is on and phone's bluetooth is on as well
First you must turn your power to the blue tooth to on in the phone menu,then you have to put your blue tooth device in discovery mode,most blue tooth device manufactures use the power button,by holding it down for 6 to 10 seconds when turning on the device it should have a solid light the you can add or search for device ,they will pair if you have your power on and your device in discovery mode once they pair you will have to enter a pin or pairing code.Most blue tooth device manufactures use a 4 digit pin pairing code they are as follows 0000,1234,1111, or 9999 i hope this helps
Feb 19, 2011 | Blueant Z9i Bluetooth Headset
I got a new phone, and it is asking for the passkey for the blueant?
hi, the typical passkey for blue tooth devices is "0000"
hope this helps!
Sep 15, 2010 | Blueant Supertooth Light Bluetooth Speaker...
How to set up my blue ant blutooth to a motorola z 3
i cannot pair my motorola vx3 with blueant S1
Oct 15, 2009 | Blueant Z9 Wireless Headset
Need to pair my blueant supertooth st3 .
Code is 0000 make sure you press the green button to turn on the blue tooth light on the Blue Ant, while you enter the pin (don't hold it down, just make sure it's on before you finish entering it).
Mar 20, 2009 | Blueant Supertooth Light Bluetooth Speaker...
Is the LG CG 225 blue tooth useable?
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.php
Dec 29, 2008 | LG CG225 Cellular Phone
Motorola ic902
to unlock the ic902 put in *#11 it will go to puk go to unlock then put in 45942230 then put in new code if it does not work go on your accont then get new puk code
Jun 25, 2008 | Motorola Mobility ic902 Cellular Phone
Blueant Supertooth Light Bluetooth Speaker Car Kit Logo
449 people viewed this question
Top Blueant Radio Communications Experts
aliasger yq
Paul Chapman
Paul Chapman
Greg P
Greg P
Are you a Blueant Radio Communication Expert? Answer questions, earn points and help others
