Question about Ariston Technologies AWD121WH
Hi i have an Ariston 1636s washing machine that part way through the cycle water pumps out of the soap tray any ideas?
  • 183 Answers
SOURCE: Flashing Lights on Ariston A1636 & Won't progress to rinse either
Suggest checking for a faulty heater. Regards Engineer
Posted on Jul 29, 2007
SOURCE: ariston margherita washing machine
I have an old Margherita washing machine year 2000, my problem I don't have user's manual. Can you please provide me or teach me how to operate the machine?
Thanks & regards
ray salac
Posted on Sep 03, 2008
SOURCE: ariston awd121 washer will not complete wash cycle
I'm also having the same problem. I hate this machine!
Posted on Sep 22, 2008
SOURCE: F-05 on Ariston Margherita AIB 16
i had the same problem. try emptying the little chamber at the bottome front of maching. there might be something in there. then have a look at the little grey fan thing. give it a push. if it springs back it is working if not it is broke. tip the machine on its side and undown the filter part. ordr this section online. it is easy to replace. i done it myself. Lu
Posted on Sep 26, 2008
barkencoa
  • 3463 Answers
SOURCE: Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Posted on Jul 24, 2009
Bosch washing machine - electronic timer goes down to 1 minute remaining and stays there. Washing liquid has been drained from drawer, however, fabric softener is still there. We have resorted to stopping...
Check if drain filter is clear and drain pump is working properly. Also remove soap conditioner tray and check if you have black residue inside the soap/conditioner dispenser. Sometimes this can prevent water from entering the conditioner tray.
Oct 24, 2013 | Bosch Washing Machines
I was washing towels on cotton (1) cold water , at the end of cycle during drying a F-02 keep flashing on the control panel. This is a new machine used about 3 months
Hello
F02 Is a suds error code or water is to soapy.You need to use the E A type soap.
Try running the machine on rinse and spin.And then go through a normal cycle with no soap.
Apr 04, 2011 | Ariston Technologies Washing Machines
Ariston LS 2020 taking more than two hours to go through cycle.
Ariston and on and on...lol
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Apr 26, 2010 | Ariston Technologies Dishwashers
Water leak
open the back of your washing machine, you'll see a series of tubular figure. try to identify on which of the tube correspond to your soap tray, see if the rubber seal is broken or cut into pieces, if it does, then buy a replacement or if you don't have time, try to find an old rubber interior that has been used for vehicle tire, just cut same figure as the your old rubber seal and use it as a replacement
Oct 31, 2009 | Ariston Technologies Washing Machines
Bosch Washing Machine Softener Tray not emptying
You need to replace the cold water inlet valve. If the machine is older than one year it may be clogged on the side that moderates the cold water to the bleach and softener compartment. Replacing the valve fixed the problem. During the cycle when the softener dispenser fills it should fill quickly and no or little water should be seen in the soap dispenser area. If a lot of water goes into the soap dispense and little into the softener area the valve is clogged.
Feb 15, 2009 | Bosch Logixx WFT 2806 Front Load...
Water from soap dispenser when spinning
Thanks this solution cured mine and my friends machine with this problem of water coming out of the soap dispencer.
Jan 12, 2009 | Washing Machines
My ariston lsv 66 uk dishwasher is not starting the washing cycle. It is making the pumping noise as it normally does at the start of the cycle but will not go any further. I have tried all the washing...
take bottom front panel off to expose the bottom tray. you will find it full of water. mop water out and machine will run. if fault reoccurs then you have a leak
Dec 01, 2008 | Dishwashers
Ariston awd121 washer will not complete wash cycle
Jun 28, 2008 | Ariston Technologies AWD 121
Ariston Technologies AWD121WH Logo
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Oloyede Monsuru
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
