Question about Dryers
Dryer stopped in the middle of a load
I have a maytag performa right in the middle of a load it stopped i thought maybe it over heated but it still won't come back on i checked the breaker. is there a reset button?
  • Dryers Master
  • 8,220 Answers
The fuse mounts on the right hand side of the heat element on the top rear of the dryer inside. It has 2 white wires going to it. It's mounting clip is held onto the side of the heat chamber with the same screw which holds down the element. To get to it start here:
Go ahead and remove the front panel and clean out the filter housing. Check the blower for looseness.4f0ecf5.jpg
Get the dryer stopped in the middle of a load - 07d491b.jpge vent:07d491b.jpg
These problems are what causes the fuse to blow.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 22, 2008
My Maytag Performa won't run at all
I looked up your model. The blower wheel on these 31001317
causes the dryer to over heat. The fuse kit LA-1053 mounts here:e930c75.jpg
Apr 13, 2010 | Maytag PYE2300AY Electric Dryer
Maytag performa pav2200 dryer has stopped heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
tust
Jan 24, 2010 | Maytag Performa PAV2200
Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
Jan 18, 2010 | Maytag Performa PAV2200
Maytag performa dryer suddenly stopped working, as if no power. i replaced both fuses and it worked. ran for about 15 mins and stopped again. any suggestions?
did it blow the fuses a second time.try this .put your dryer on a cycle that wont call for heat and turn it on.if the heat strips are not on and it still blows a fuse it is the motor.if the heat strips are on and it blows a fuse the heat strips are the trouble.
Nov 05, 2009 | Maytag Performa PAV2200
Maytag performa dryer doesn't fully heat
A couple of suggestions. STOP, be sure the gas it turned off before disconnecting the line. Move it to an open area and check all venting. A good cleaning makes a huge difference. I believe your problem to be the heating coil is on it's way out, "works sometime". Write down the Make, Model, Seriel Number & Year of MFG...someone may ask for it..Check Your local appliance store for price & availablity Easy to replace on most model dryers.
When reattaching the gas line, be safe not to overtighten the coupler. A safe test for leaks is NOT a match... a drop or two of dishsoap around the fittings will bubble if it is not sealed. Good Luck
Jan 02, 2009 | Maytag Performa PAV3200
Maytag performa dryer quit in the middle of a load
probably the thermal fuse i just fixed mine it did the same thing it was about twenty bucks for the kit and it is located right under the wires that feed the heating element
Dec 15, 2008 | Maytag Performa PAV2200
Maytag performa dryer vent got clogged and quit working
maytag performa dryer quit in middle of drying.
Dec 01, 2008 | Maytag Performa PAV2200
My Maytag Performa Oversize Capacity Dryer stopped working without a warning. It dried a load on the week-end without a problem. I put a load in on Wednesday, turned the dail to on
but there was no movement or sound.
HELP!
Jul 02, 2008 | Dryers
Maytag dryer won't heat up
i am having the exact same problem with this model as well just happened 4 days ago.
Mar 18, 2008 | Maytag Performa PAV2200
Dryer will not turn on
i've had my maytag dryer since 2002. it just stopped in the middle of a cycle. i think it's the motor. isn't maytag guaranteed for life???
Dec 22, 2007 | Maytag Dryers
Dryers Logo
108 people viewed this question
Top Dryers Experts
Marvin
Marvin
