Question about Cobra MicroTalk PR 1100 WX (15 Channels) 2-Way Radio
Brand New Cobra microtalk won't work!
I bought a pair of Cobra Microtalk PR 650 WX from Wal-mart today.....charged them up, and tried to turn them on to test them. According to the owner's manual, there's supposed to be a set on tones to indicate that the units are on, which never sounded. The display works fine, channel selection works fine, etc. But, they won't transmit nor recieve. I bought these for an upcoming trip, the package is way beyond damaged so I can't talke them back to Wal-Mart...Help!!
  • 2 more comments
  • TraMan Jan 06, 2008
    Brand new, charged up, one unit works, one doesn't. Help.
  • Anonymous Mar 15, 2014
    oricom UHF050 40 channel vehicle mounted standard cradle mount with 6 dB gain antenna has been working fine for 3+ years in same config but now only the key noise at start and end of trans can be heard. It receives nothing, and at times it seems that the busy light is on all the time but I hear nothing. TX red light shows when transmitting. I have reset factory settings per the manual to no avail. How do I test the mike, and am I able to open the unit and test anything such as fuses etc?? many thanksGreg
    HiRE: oricom UHF050 40 channel vehicle mounted standard cradle mount with 6 dB gain antenna has been working fine for 3+ years in same config but now only the key noise at start and end of trans can be heard. It receives nothing, and at times it seems that the busy light is on all the time but I hear nothing. TX red light shows when transmitting. I have reset factory settings per the manual to no avail. How do I test the mike, and am I able to open the unit and test anything such as fuses etc?? many thanksGreg
  • Anonymous Mar 17, 2014
    OK so long story short I bought my cobra mirco talk walked from walmartthat same day iI went to charge both of them just getting to know them and one of them the screen went blank to where I can't see anything on itni tried holing down every button then when I put it on the charger the light we not come on indicating that its not beening charged
I had to replace some of the cheap Chinese NiCad batteries to get mine to work. Check them all with a voltmeter, they should be at least 1.1 volts DC.
Posted on Mar 10, 2008
  • 123 Answers
Im not sure if this radios can work with alkaline batteries like AAA or AA type, this will focus the problem in the batteries or in the charger
Posted on Apr 09, 2007
  • 247 Answers
Double check against all the instructions - in particular, make sure the batteries are charged according to "before first use" spec, that the volume is turned up, and that the squelch (if fitted and not automatic) is adjusted properly. If it still doesn't work, take it back to Wal-Mart. If the product doesn't work, there's no need for the packaging to be in good condition - it's not as if they'll be needing it to resell the goods to anybody else. A.
Posted on Apr 08, 2007
SOURCE:
Unlock cobra microtalk pr4500
You can download the manual with all the instructions from here: https://www.cobra.com/sites/default/files/manuals/PR4500WX_MANL.pdf
Jun 29, 2014 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Cobra microtalk pr550wx
Download the manual from here: http://www.manualslib.com/manual/223491/Cobra-Pr-550wx.html
Jun 05, 2014 | Cobra Electronics microTALK® PR 550 WX ...
I have one microtalk radios PR 4500 (because I lost the other) and I thought to buy another pair of radios . My question is: should I buy exact type of radio to work with what I have or I can buy...
You may want to Buy the same thing, Go to store with yours, Have it turned on, When checking all they have, turn theirs on to see if you get good reseption
Aug 27, 2013 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Bought two pairs; not communicating with each other
Hi
If the second units are not working check power in those units, ar eyou sure they are on the same channel? also make sure the antennas are connected correctly.
good luck,
John.
Dec 20, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Tranmitting
one of the units may have a bad mic element. Can you hear the speaker unmute when the radio is keyed?
Jul 30, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Batteries won't charge on new cobra 2VP 270 radios
If radios are brand new then I would take them back to the store for warranty exchange. The other opton is to vist a local radio service center and ask the tech to jump the battery. if the battery falls below a certain voltage it might need a quick jump sart from a power supply with a higher voltage normally 12 volts works well...
Jun 28, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Cobra MicroTalk PR 1100 WX (15 Channels) 2-Way Radio Logo
2,708 people viewed this question
Top Cobra Radio Communications Experts
Steve Allison
Steve Allison
Chris
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
