Power supply out on printer
Their is no power to our printer. We checked all connections and appear ok.
    Scholar:
  • 130 Answers
Try replacing the power cord first... Also try resetting the surge protector if you have one. If all else falls, try sending in for repair to the manufacture.
Hope this helps...
Posted on Dec 22, 2008
Power 48v check
Hi
Either the power supply is
not generating a proper 48
Volts or the controller board
is not detecting a 48 Volt
output from the power
supply board.
1. Make sure the power supply
board is correctly connected to
the controller board.
2. Power on the printer. If the
message appears, do the power
supply operational check (page
195). If the power supply fails the
check, replace it. If it passes the
check, go to the next step.
3. Power on the printer. If the
message appears, replace the
controller board. Record the
message and return it with the
defective board.
Aug 11, 2014 | Printronix Matrix Office Equipment &...
Rjwylie@wowway.com..... I asked for assistance regarding fixing my pixma 600 printer. I mentioned that I checked the outlet and the power cord {with a meter}. They are O.K. Do you have any other...
It appears that your MP600 Power supply has died.
My MP600 Power supply died as well. Web searches (including Canon) turned up nothing. Called Canon. To order power supply from Canon, call: 866-481-2569 (credit card over the phone, no on-line interface). $34.49 with tax and delivery.
Note: the power supply has black tabs the you push away from the grey power supply case. One tab in front and one in back. The grey power supply box pulls right out of the printer. The internal connector (six colored wires) pulls straight out (there is no release tab/catch). Use small screwdriver or needle nose plyers to carefully remove. Pull/pry the female white nylon connector. Do not pull on the wires.
Feb 11, 2011 | Canon PIXMA MP600 all-In-One InkJet...
The power connections are ok; and the cables are ok but the printer has no power, how to fix it?
Hello
Check the fuse in the printer, otherwise power supply may gone faulty, needs repair from HP technician.
Good Luck
Jan 19, 2011 | HP DeskJet F380 All-In-One Printer
Printer will not power on
Check that the corded power supply is plugged into a live receptacle. Verify by using a lamp with a light bulb to see that it lights before plugging power cord into the wall.
Check that the connection at the printer is ok.
Push the power button, and if nothing happens, you might have a bad transformer either on the cord or in the printer itself, depending on the design.
One can double check by getting a spare power supply transformer or cord and trying it.
Or else, a multimeter should show the voltage printed on the power supply or printer. Check that the voltage is within specifications when plugged into the wall whether it is AC or DC voltage.
Jul 04, 2010 | HP Office Equipment & Supplies
Printer does not switch on power supply and connecting chord OK
Try the connecting power cord on any other device just to make sure that it is working. Check the wall out let and ensure that it is working. If the above is OK then check the main switch on the printer. If it not working then you have to get it replaced. There is no other reason for PRINTER NOT GETTING ANY POWER.
May 01, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
I have no power
You have no power for printer. first check your power supply is ok or not. then check your power cable and chk your printer power connection post is broken or not. finally you chk your power supply card which is inside in your printer.
Thanks
Aug 16, 2009 | Canon MP830 All-In-One Printer
No power
Follow the points
  1. First chk the main power supply of your office/Home
  2. Check the Power Cable is Ok or not
  3. Check it is conected to the power point perfectly or not.
  4. Check the Power button switch is ok or not
  5. Connection may be loose.
  6. Finally Check the Power supply Card which is inside the printer
Thanks
Aug 15, 2009 | Samsung ML 1610 Laser Printer
I have no power to the printer to my canon pixma mp780. why? Saw another on E-bay with same problem. Cord is Ok - checked it w/ meter.
This is what the service manual says:
(1) Check the power cord
connection.
(2) Check the connection between
the SPCNT board (JPSU1) and
power supply unit.
(3) Replace the power supply unit.
Aug 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printer wont power up
I found over 50 people online that had the same problem which appears to be a fatal software problem. One person had a partial fix which invoolved unpluging the cable to the wireless card and leaving it unpluged and using cable to connect printer to the network.
Apr 06, 2009 | HP OfficeJet 7410 All-In-One InkJet...
FAULT CODE
indicated. The connections for the fusing unit, from the power supplies and the printer control board, TRY AND re-seated.CONNECTORS
NOTE.
if you are not handy try and reset machine first by powering off ,and back on WHILE HOLDING DOWN THE Utility Botton untel prompted .with trouble reset message,,,,
press ok and turn machine off 10sec back on
hope that helps
Oct 20, 2008 | Office Equipment & Supplies
Computers & Internet Logo
23 people viewed this question
Alun Cox
David Payne
David Payne
