Question about Sony STR-DE595 5-Channel Amplifier
Playing ipod on sony str-de595 receiver
1. Is the sony str-de595 compatible for an ipod hook up? 2. If yes where in the input?
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    If receiver has ipod dock then its compatible. check owner's manual to locate ipod dock in receiver.
  • 85 Answers
You need a 3.5mm mini jack coupler lead with phono plugs on end plug one end into your headphone output on ipod and phonos into your amp lead must be stereo
Posted on Jan 09, 2009
I have a Sony STR-DE595 receiver that I would like to connect to powered speakers. How do I do this?
One way would be to follow the directions supplied with the unidentified powered speakers. Lacking details we can't really provide a good answer.
Jul 21, 2011 | Sony STR-DE595 Receiver
Why can't I play a turntable through my "Sony str-de595
Turntables have a very low output level. Receivers with a phono input have a op-amp to boost the signal level.
What you can do: Check the turn table it may have a line level switch under the rubber mat, otherwise you can get a phono amp ($20-$40) to boost the signal. and input it to any unused input on the receiver.
Jan 10, 2010 | Sony STR-DE595 Receiver
Input from IPOD - I want to play music from my IPOD through my Sony STR-DE1075. I have an IPOD line out adapter. cannot figure out which input I should be using.
Any input as AUX , DVD or Tape will work fine ..whichever you connect.and/or available...But please do not ever use the "Turntable" input...make sure volume of IPOD is half way open as listening earphones not max..good luck..
Jan 07, 2010 | Sony STR-DE1075 Receiver
NO! It uses the same amps for a and b channels. and you could short it out if its wirer improperly.
Dec 17, 2009 | Sony STR-DE595 Receiver
Want to play my ipod through sony str-de135 receiver
Get a headpone to rca cable (radio shack or best buy) and use any input on the rear of the receiver except phono. You will need to turn the ipod to near max volume.
Nov 28, 2009 | Sony STR-DE135 Receiver
Sony SRT-DE595
go into the speaker setup menu and turn subwoofer to YES
Dec 08, 2008 | Sony STR-DE595 Receiver
Optical inputs
In short yes!
If you have two optical inputs and two equipment (PS3 and HDVD) then you shouldnt have a problem at all. Just make sure you change the mode of the receiver to TV/SAT when you want to use the HDDVD. Your problem may be the video out put.
If i was you i would do the following:
1. Get rid of all your optical cables as you won't need it.
2. If your receiver support HDMI then by default HDMI will send both video and digital sound.
3. Plug the HDMI of the PS3 to the HDMI input of the receiver, plug the HDMI of the HDDVD player into the HDMI 2 of the receiver and plug 1 HDMI cable from the receiver to the tv/monitor you have.
That is the best set up so when you play PS3 you select dvd/ld and when you watch hddvd you select tv/sat.
However having said all that the fact that you have dvd/ld suggests you actually don't have HDMI at all on the receiver(...i just checked the specs of the receiver). Which means you will need to have 2 hdmi inputs for your tv and you will need to have the 2 optical connections.
But in short yes to your question.
hope this is not too confusing.
good luck
smeags.
Feb 05, 2008 | Sony STR-DE595 Receiver
How do i hook up my ipod to a sony STR-DE597 6.1 channel reciever?
have u checked the COMPATIBILITY of the IPOD with your system(receiver/amplifier). the software of some models is not compatible withyour respective receivers.
Go to their sites for software upgrades.bye.
Oct 31, 2007 | Sony STR-DE597 Receiver
Buzz sound when i hook my laptop up
How many years have you had this laptop? Sad to say, if it's many years, time to replace as that would be cheaper.
Apr 29, 2017 | Sony STR-DE595 Receiver
Sony STR-DE595 5-Channel Amplifier Logo
576 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
