Question about Marvel 6BAR-BD Beverage Cooler
Marvel 6barbd undercounter fridge
I Replaced the thermostate and control knob, and now I think i have a problem with the compressor relay. I can not find the part I am looking for though? it's says on the relay "cge" than a small logo and then "28DRL230100UGDW" then "10 uf (U) 230 VAC B"
Thanks jeffamsler@yahoo.com I app. any help
Marvel 6sbar-BD with wine storeage racks on the bottom and two glass shelves above. If I put sodas on the top shelf they expode. I have it on the lowest setting. Please advise.
Posted on Aug 10, 2009
Why does my wine cooler run too cold?
If after adjusting your thermostat to desired temp and is still cooling. The thermostat is bad or your relay is bad
If you disconnect the thermostat and the compressor stops it most likely a bad thermostat
If you disconnect the relay from
The thermostat and it stay running it is the relay. It is sticking
If possible store you wine somewhere else and shut the unit down and unplug for 10 to 20 minutes this may cause some melt of condensation some water may be on the floor if is to cold
This may also reset the system.
Jul 26, 2015 | Marvel 61WC Wine Cooler
Why does My marvel 61WCM wine fridge turn on but right away off again?
First make sure it is not plugged into an extension cord. Low voltage could cause this type of problem. If you have it plugged directly in ,It is probably the compressor or overload relay on the compressor. You can bypass the thermostat to see if it is the problem, by first unplugging the device, then removing the wires from the thermostat, and jumping them together. Then plug it in If it still acts the same way the problem is in the compressor or overload relay mounted on the compressor. Sometimes the relay can be purchased and replaced or a hard start might work solve your problem.
Aug 07, 2014 | Marvel 61WCM Luxury 45 Bottle Wine Cooler...
I am a repair man n I am workin on a marvel refrigerator two drawers under the counter! It was acting irratic so I changed the main board! Now it's flashin e1 n the compressor turns on for a few...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 14, 2011 | Refrigerators
Kelvinator 401 Impression series. Oldie but a goodie until I switched it off for 6 weeks while on holidays. Switched it back on and now fridge area freezing. Tried switching up overnight (8-10) hrs and...
If it runs then that cold control is the problem.
If this doesn't work Do this
That is probably the compressor relay or cold control (Thermostat
The relay is on the compressor and needs replaced
Leo Ponder
Aug 16, 2011 | Kelvinator Refrigerators
Hello, My Marvel undercounter refrig. is freezing everything in it no matter what the dial setting. Do I just replace the thermostat or is it something simpler?
Hi, It sounds like you need a new thermo switch. It's not turning off at proper temps.
thats why it's freezing everything. Thank for asking us.
Jun 07, 2011 | Marvel (6CAR) Refrigerator
When the compressor (I think?) runs it makes an intermittent buzzing sound. What could be the problem?
Hi, you need to change the relay and overload on this. It is located on the side of the compressor. take the cover off the back of the refrigerator and you will see the compressor. These relays go bad a lot, here is the relay and overload.
May 15, 2011 | Marvel 60RDE Refrigerator
Our whirlpool fridge/freezer has stopped working today for no obvious reason. There is still power being supplied to the unit, as the light is still turning on once the door is opened, but it is no longer...
You will need to check the following parts:
  1. Compressor start relay
  2. Cold control thermostat
  3. Compressor
  1. With the fridge unplugged, and an Ohm-Meter in hand, remove the Compressor start relay after marking where each wire goes. The wires must be removed before testing the start relay.
  2. Use your ohm meter to test the white(overload) wire, with one meter probe on the terminal where the White wire went, and the other meter probe on the other terminals, 1 at a time, should read 0-1 ohm.
  3. For the brown relay, just put both meter probes in each hole, should read 0-1 ohm.
  1. Put the Compressor start relay back in place and hook the wires back up to it.
  2. Find the cold control thermostat, it is the Switch with a knob that controls the Temperature. Tap under the console and on the knob in your refrigerator section and see if it comes on.
  3. If the contacts inside that cold control thermostat go bad, then when you tap the console or knob the refrigerator comes back on again.
Jan 23, 2011 | Whirlpool Refrigerators
Temperature control does not work. Unit freezes everything no matter where the temperature control is set (Marvel Wine Refrigerator)
Either the thermostat itself is bad, or the relay is sticking. If you break the connection between the T-stat and the relay, and it keeps runnning, the problem is the relay.
If the compressor stops running when you break the connection or disconnect the T-stat, then the T-stat needs to be replaced.
Oct 12, 2009 | Marvel (6SBARBSG) Wine Cooler
Marvel undercounter refrigerator, works for a few days then stops
I experienced same problem with my refrigerator, Marvel ar61. Call Marvel and they will send you a repair kit which includes a new thermostat, switching relay and a new thermistor. My refrigerator is working great.
Mar 28, 2009 | Marvel 6BAR-BD Beverage Cooler
Marvel model 61WC Wine cooler
If the unit was made after 2000, there is a solid state control in the back that you can test. If it was made before then, it will have capillary tube style thermsotat that you can test.
Made after 2000:
First, pull the unit out to access the back lower area and disconnect the power. Remove the lower backing to access the mechanical area. There will be 2-inch square back box with seven terminals and 4 dip switches. Disconnect the red and black wires from terminals # 3 and 2 respectively and connect them together (this bypasses the control). Plug the unit in...if it runs you need a part of or all parts of the control.
Made before 2000. With power disconnected, remove the front grill to get access to the thermostate (usually on the right side). It will have up to three wires connected to it and a sensing line. Leave the green (ground) wire as is (if connected), disconnect the other two wires and connect them together or run a jumper. Plug the unit in...if it runs then you need a new thermostat (only one part).
If the compressor does not run but the condenser fan does...something is wrong with the compressor.
You can also call the factory at 800-428-6644 and ask for technical assistance. They can assist you with further troubleshooting and/or finding a servicer near you. They should still have parts to repair that unit.
Sep 01, 2008 | Marvel (6SBARBSG) Wine Cooler
Marvel 6BAR-BD Beverage Cooler Logo
555 people viewed this question
Top Marvel Refrigerators Experts
richie46
ray gallant
Are you a Marvel Refrigerator Expert? Answer questions, earn points and help others
