I have an old hp pavilion slimline s7320n and the mouse that came with it finally died on me. I purchased a usb plug-n-play mouse to replace it, but the computer does not recognize it. I have tried an old ps/2 connection mouse and that does not work either. Advice?
  • Computers & ... Master
  • 27,725 Answers
make sure the batteries are inserted correctly and have charge if applicable
make sure the usb device is properly inserted
make sure you turn the mouse on depending on type/brand of mouse it will vary it could be a button or switch on top bottom
or you might use the safe mode option
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer then if your mouse works
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question/exclamation mark? ! or a red X right update driver
W7
hope this helps
Posted on Aug 31, 2012
  • 2,878 Answers
Strange, but try booting into safe mode by pressing F8 during boot. Choose safe mode with arrow keys and enter. sometimes it can take awhile to load. Use Windows key on keyboard. Windows > Start > run (search in win7) > type devmgmt.msc. This will load Device Manager. Go to View > Show hidden device in case they are not already showing. Delete all Mice and reboot with USB mouse attached. It should pick it up.
Use the Tab and Alt keys to navigate without a mouse.
    Genius:
  • 1,074 Answers
You need to replace it with a new ps2 mouse.most old computer does not recognize usb mouse.
SOURCE:
SOURCE: No Sata, intermitantly just locks up and reboots on it's own.
Random computer reboots can be difficult to diagnose. Try the following:
1) Check event viewer for messages that could be related. (Control Panel >Administrative Tools >Event Viewer) These could point you in the right direction.
2) PC could be overheating. Many motherboards have a utility you can install to display the CPU and motherboard temperature. I have read the maximum operating temperature for the AMD 9850 is 61C (142F). You can also see the CPU and motherboard temperature via the BIOS. If heat is an issue try installing extra or more efficient case fans, run the PC with the side panel off or maybe get a better heatsink/fan for the CPU if you are using the stock AMD offering.
3) If the inside of the case fairly clean? I see many PC's full of dust which prevent the cooling fan working efficiently causing the PC to overheat and reboot. If your CPU heatsink is covered in dust give it a careful clean...it makes a lot of difference.
4) Check for loose cables. Reseat any that look suspect.
5) Remove one of the harddrives and see how it runs. If fine take it out and try the other. If fine try them both. (this may be difficult if one of them is your system drive) If one appears to be at fault test it in another PC and if the fault follows the drive take it back for a swap.
6) Could be that your power supply is not powerful enough. What wattage rating is your Power Supply? You can see this on a sticker on the PSU but you will need to open the case to see it. Your CPU sucks upto 125 watts and video card up to 150 watts depending on model. Depending on the exact model of video card I would think the minimum PSU rating you would need would be 550-650watts....more to be safe. Maybe adding the harddrives just pushed the PSU over its limit?
7) Computer reboots and freezes are often related to bad memory. Could be that when you installed the HDD's a bit of static electricity found its way to the RAM? (unlikely but stranger things have happened) Do a memtest. Maybe take out one stick of ram and test. Then swap over and use the other stick and try and isolate a bad stick. Test each stick for hours, not minutes. When I test ram I drop down the size of the pagefile and run heaps of programs to ensure the ram is being fully utilised and tested.
Good luck and please reply with any comments.
Posted on Apr 08, 2009
  • 8 Answers
SOURCE: My computer won't recognize my logitech USB headset
Okay, I've had the same problem with their keyboards and mice, first you uninstall and reinstall the driver, if that doesn't help go to start>run then open MSCONFIG. Then find the services and re-enable all of them, along with all the startup entries.
Posted on May 07, 2009
  • 13 Answers
SOURCE: my HP Pavilion s7210n slimline
the problem is the power supply. it's pretty much a special order part since the slimline case is 'non-standard' . check the link for more info.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1156567&prodTypeId=12454&objectID=bph06788
Posted on Sep 21, 2009
Cool Sam
  • 79 Answers
SOURCE: my hp pavilion slimline s3407c locked up and I
► do a power drain i.e unplug the power cable and press the power button and hold it down for 10 secs.
► reseat the hard drive by unplugging the cable connecting the hard drive and motherboard and also the power cable
Posted on Feb 09, 2010
Testimonial: "Thanks...that worked...I'm up and running again"
I have a wireless logitech mouse M/N RBS111. DOES IT WORK WITH RECEIVER NC-U0010?
well first is the battery
wireless needs a battery on the MOUSE end.
and the 2 parts, mouse and the (usb receiver, must match)
usb
C-BS35 did you read the Logitech web site, first, to see if this old mouse is 10 supported?'
I looked for you and they have no legacy mouse suport there.
this mouse is OLD real old why use OLD relic mouse.?
HOPE?
ok , turn on your unstated PC
run w10 connected to the INTERNET (if not its hopeless)
with fresh batteries, plug in the mouse and USB device
windows (PnP) pops the screen or shows the USB ICON busy
this is the PnP engine looking for a driver for you new mouse
plug and play.
did you ask MS for support on this mouse on their forum?
many devices are NOT supported in W10 , vast devices.
old stuff that the maker no longer supports..
Jul 03, 2017 | HP Computers & Internet
Desktop keyboard keeps dying
Have you connected any other USB devices that could be draining power? Try to disconnect everything but your mouse and keyboard and see if the problem comes back, if this rectifies the issue get a powered USB hub to connect the rest of your devices.
Also check that the USB bandwidth and power level limits are not being exceeded, I have attached a picture
Oct 03, 2012 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
How do i add wireless to a hp minitower pavillion slimline s3600z
Assumming you have an available signal, the cheap/easy way is by usb wireless adapter. Should be plug and play. Cheers
Jun 06, 2012 | HP Pavilion Slimline s3600z Desktop PC
Where is manual eject hole on hp slimline pavilion s7320n
Below the drive tray there is a tiny hole, straighten a paper clip and gently insert the paper clip into this hole. Push the paper clip and the tray will release and pop out, then pull the tray out to the fully open position.
Mar 02, 2012 | Computers & Internet
I have a "HP Pavilion
hi texin.
check this link out you might find something there that might help you out.
HP Pavilion s7320 faults Google Search
Nov 06, 2017 | HP Pavilion s7320n (EP140AA) PC Desktop
Why wont my hp pavilion slimline play my cds
first go to my computer and click with the right mouse button then choose properties then hardware devices and see if the cd have an yellow icon, if so you need to upgrade your drive.
you also can go to the hp website and on the support option you put your model and get the drivers from there, if nothing works, your cd lent is faulty or needs to bee cleaned.
Thanks
May 25, 2010 | HP Pavilion Slimline S3123W Desktop PC -...
Start up Probelms HP Pavilion Slimline
Unplug the AC power, remove the battery, wait a full minute and then reinstall AC and battery. See, if you now power up. Most power up problems are related to AC power, DC input jack, motherboard, memory or processor. A lot depends on your comfort level and expertise in how far you should go in self diagnosis and repair. Good Luck.
Sep 08, 2007 | HP Pavilion S7510N (EX255AA#ABA) PC...
Computers & Internet Logo
143 people viewed this question
Alun Cox
