Question about SanDisk 2GB microSD Memory Card
Memory card is write protected message
My 2.0 GB card is showing this message on my camera. This has never happened before and it will not allow me to reformat.
What do I do?
Thanks
Jeff
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • SanDisk Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Posted on Mar 09, 2010
I have had this camera for two years and never had a problem. Now when I switch it on the screen shows the message, " Memory card is write protected" and the camera will not function.
On the memory card is a slide lock that locks the card from being accidentally written to or erased. embossed with a lock that is unlocked/locked.
Somehow this slide lock has been moved to the write protection mode/locked. Could have happened if you removed the memory card lately.
Remove the memory card and slide the lock to unlock reinstall the card and that should cure your problem.
Feb 05, 2016 | Nikon Coolpix S3300
Question for SanDisk SD card 2 GB - Camera is Canon PowerShot SD870 IS Digital Elph Question: When memory card is inserted in my camera the message "memory card error - card locked" shows when...
There is a small switch in the card that is currently in the locked position. you need to move it over to the other position to unlock it.
Aug 06, 2008 | Cameras
What size memory card does the kodak easyshare cx6200 take?
The internal memory for this camera is 8 MB.
The manual indicates using memory cards of size 8 to 128 MB, so this is an early SD memory camera, following the original SD standard. Do not try SDHC or SDXC cards. The camera will support a 1 GB card. It *might* support a 2 or 4 GB card, but since this is a 2 Mpixel camera, a 512 MB or 1 GB card will allow you to save thousands of jpeg format pictures.
Mar 01, 2011 | Kodak EasyShare CX6200 Digital Camera
A new SD card 2 GB wil not work in my C310 kodak digital camera Message in camera "memory card full" message in card reader when trying to format the card says "write protected" Is this card too Big?
No, the C310 will handle a 2GB card.
Sep 10, 2010 | Kodak EasyShare C310 Digital Camera
Cannot copy files or pictures to memory card
Card has a switch on side slide it up or down
Feb 05, 2009 | SanDisk 2GB microSD Memory Card
Kodak C340 Memory card Formatting
The write protection is on the card (a little "pin").
Aug 15, 2008 | Kodak EasyShare C340 Digital Camera
Card protect
For some reason, the SD card in your camera is being viewed as write protected. There is a small "switch" on the SD card that slides. Slide it up and down a few times and try it again. If that does not work, here is the solution that worked for my camera. Place masking tape (opaque, used for painting) over both positions of the switch. I had to put 2 pieces to make it inflexible. Be sure not to get tape on the metal contact points. I hope this works for you. It fixed mine, although I don't really understand why. If this doesn't work, try a new card.
Mar 29, 2008 | Aiptek A-HD 720P Flash Media Camcorder
MEMORY CARD
it happend with me .
this camera was degined to use SD card by max 32 MB or may be less.unless there is a softwear to allow the cam to accept the bigger capicty like SD 1 or 2 GB
Nov 13, 2007 | BenQ DC3400 Digital Camera
SanDisk 2GB microSD Memory Card Logo
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
