Question about RCA RT2770 Theater System
I need a new Resistor for my RCA RT2770 the number by the resistor is R202, does anyone know what size the resistor is?
I just need to know what kind of resistor to get if I dont already have on I can see the colors of the rings on it still but I dont know what size it is from top to bottom the lines are a very light brown, then an orange, then a either very very dark brown or a black, and last a medium shade brown
  • 1 more comment
  • Nyle Davis
    Nyle Davis Oct 16, 2013
    I have the same problem with my RT2770, which uses the same power supply board. R202 along with C211 make up the "snubber network" for the fast action diode pack (TO5 Tab mounted on 2nd large heatsink) labeled D207. This resister is so burnt, on my unit, the color bands are not readable, so the value can not be determined. Obviously, by size, this is a 1 watt resistor. This resistor goes out when C211 shorts out at high voltages. Normal testing will not show the short, since it is an arching short at high voltage. On my system C211 has no markings so I need this value also. From my knowledge of High Efficiency Switching Power Supplies, they use high frequency switching (pulse width modulation is used to vary signal width to increase amperage under load). Snubber networks are needed to chop off the hign voltage spikes that occur. These spikes vary as the input voltage varies. Typical voltage here in the US varies from 105 to 125 VAC. Therefore the spike voltages at the upper end can easily exceed 30 KVAC. Since I used to repair switching power supplies, the design engineers typically under rate the capacitor at 10-25 KVAC, which should be 35-50 KVAC. So when you replace this capacitor, get one with same capacitance rating (critical for resonance with the frequency of the design) but add 10-20 KVAC to the voltage rating from the schematic. I'm trying to find the value of these 2 components, so please share if you have this knowledge.
  • Nyle Davis
    Nyle Davis Oct 21, 2013
    Since only these 2 components are bad on my board, will draw complete schematic for the board and post on my tech blog later and put up URL here. RCA Tech support would not give me the values, they have no schematics on hand and are only set up as "HOWTO" from operational stand point, so interaction with them is useless. Oh researching I found the factory spec values, C211 is 2200pf 1KV, but do not use exact replacement but use 2200pf 30KV, R202 is 10 ohm 1 Watt and I recommend using 10 ohm 2 Watt 2%. Look for the 2 Watt that has air holes for cooling through the substrate. Will be a smaller form factor about same diameter as standard 1 Watt.
  • Nyle Davis
    I honestly was amazed at the stupidly low 1KV value the engineers gave to C211, since any experienced engineer know these voltages spike well above 12-20 KV. I recommended 30KV replacement, but if you are erroring on the side of caution, go even higher 35-50KV and your snubber network, will never go out again.
My currently working R202 measured today at 22.5 ohms. I learned this was a problem yesterday after doing general research about this new to me system. Again my resistor has not failed, though its rings are discolored, and the system works well. I did cut and solder short wires to allow me to mount the resistor elevated above everything to get better airflow and hopefully stay cooler and possibly last longer.
Posted on Aug 08, 2015
I haven't found the answere yet, but my RT2870 uses the same power supply board and this appears to be a known issue with this power supply board. keep checking this thread:
http://www.hometheatershack.com/forums/rca/54253-rca-rt2870-turns-then-back-off.html#axzz2DvlVJuuL
if an answer is found, it will wind up being in that thread...
also, if you found the answer, please post it to that thread, thanks!
Posted on Dec 03, 2012
3 Suggested Answers
  • 4234 Answers
SOURCE: connecting RCA RT2770 to PC
Yes. Take the output from the sound card and connect it to one of the tape inputs. Note: you should use the "line out" jack for this.
Dan
Posted on Mar 27, 2008
  • 4 Answers
SOURCE: Blowed up in my RCA RT 2770 a resister and I need the number
Contact customer service, http://www.1800customersupport.com/rca
Posted on Mar 08, 2010
Should I,change just the resistor that is burned?
Normally if a resistor has burned you will need to locate the cause or a replacement resistor will surely blow instantly in most cases? Is your model the HD52W59 RCA with the ITC222A chassis? If so let me know the resistor board location number such as RP256 etc.
Oct 15, 2011 | RCA HD52W59 HDTV Projection Television
Have an RCA RT2770 unit and it will not turn on either by remote or unit itself. have all components plugged in and still nothing. any suggestion?
Possible this is a shut down due to a protection cut off.
Need to check the outputs and the power supply to confirm,
Sep 30, 2011 | RCA RT2770 Theater System
Have you a diagram for the bosch charger model number d 70745 need to know what the ohms is for a resistor
If you can see the resistor then make a note on the color rings on it. If you go to a electronic supply store and tell them what the color code is they can tell you what it is rated at.Hope this helps you. Thanks
Mar 20, 2011 | Garden
Some of the resistors inside it are fried need to know which one to replace them with
look for resistor color code chart on line. it will give you the value and the wattage size.
Mar 13, 2011 | PPI PC2600 Car Audio Amplifier
I need value of two coponents of resister and capacitor.
what are the 2, the cap would have the size on it, the resistors would have color code, you can google resistor calculator and put the color in and it will tell you the size.
Feb 12, 2011 | Televison & Video
I have an RCA RT2780 - receiver unit, and one of the resistors on the power supply board is burned so much that the color bands are not there anymore. The resistor is R202, if somebody has the circuit...
The resister called for is R202, which is a 1 Watt resistor and makes up a "snubber network" with C211, which must be replaced as it shorted, which caused R202 to burn out. This short will not show on any tester as the short only occurs above 25 KVAC from the spikes that this system typically produces. Do not replace C211 with same value capacitor, because it will also fail. The MFD rating must be the same to resonate with the frequency, but up the VAC rating. Engineers typically design these @ 12-25 KVAC and you need a rating of 35-50 KVAC, since the voltage spikes easily exceed 30 KVAC.
Jan 13, 2011 | Audio Players & Recorders
Looking for the resistor R15 data or part number to a DESA heater ignitor PC board 113471-01. Only indicator is DALE/R1F. I want to repair the pc board but cannot find the specfic part number to purcahse...
I also need this resistor! ignitor element shorted and took this resistor with it. If i cant find the size i will start with a high watt, high resistance resistor and work my way down until it lights i suppose. It appears that DALE R1F is a resistor series but the actual wattage and resistance are not given
Jan 05, 2011 | Heating & Cooling
My 50" Toshiba has a color problem!!!
Ur convergence is dead.Must replaced the 2 Convergence ICS and all it resistors.By replacing these 2 convergence ICS well solved these problems colors misalign, 3D double pictures,blurry pictures.The shop will cost U $300 for parts and labors.
Jan 23, 2010 | Toshiba 50H81 50" Rear Projection...
Amp repair advice
check on the board to see if there is a resistor that looks similar, 90% of amps amps are matched in there design, meaning the left side is usally a carbon copy of the right, so if you look at one side and there is a resistor that looks like it's in the same spot on the other side, good chance thats the same one, read the colors off the one thats not burnt up. resistors come in different wattages,1/8,1/4 1/2 up to 10 watts, each wattage is a different size, most of the ones you see in the amp are 1/4 watt but some are 1/2 and 1/8. some on the output are 2 to 5 watt, but those are generally 10-18 mm in length, they are big ones you cant miss those. so once you get the color code, read the colors, ex red,gree,brown,last line is either silver or gold, that will tell you the resitor value. then google resistor color codes and then you can match the color sequence with the value codes, and that will tell you the value you need in ohms but then you have to get the size 1/4 watt resistors are generally about 6 mm in legnth, im measuring the actual part of the resistor not including the metal leads, just the body, so if its larger its probally a 1/2 watt if smaller its an 1/8 watt, 1/8 watt are about 4 mm. now go buy the resistor, but you might find it that tough, if its a common value radio shack might have it, but resistors are so cheap, pennies for a handful, good luck on your search.
Jun 30, 2009 | Sony Car Audio & Video
RCA RT2770 Theater System Logo
852 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
