How can i change the screen diameter - Televison & Video
  • 21 Answers
This would be in the menu screen. mostly likely under the screen option or display option.
Posted on Dec 22, 2008
What is the circumference of a circle with 54" diameter?
Circumference = Pi (3.14159) times diameter (54") = 169.646
Online circle calculator: http://www.athropolis.ca/popup/c-circ2.htm
Nov 08, 2014 | Computers & Internet
Worx manuals
It's probably not a good idea to do that - the manufacturer designed it to cut 10", and it probably works much better at 10" than at any other diameter.
Aug 01, 2014 | Worx GT WG150 10 in. 18 Volt Cordless...
Changed filter and fuel lines, poulan 31cc 250E. starts fine but dies when accelarated
My chainsaw was doing this.The carburetors on these small engines have a fuel inlet screen that clogs with tiny bits of debris.Remove the carb,and take the portion off that has the fuel line attached to it(if you're careful,you can reassemble it without needing a new gasket).The screen is about 5/16" in diameter.Spray some carb cleaner in there to clean the screen out.(this is mt best guess,because it sounds like a fuel starvation problem)
May 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
How many thermoststs does the nissan nomad have
1 this being the specifications on it
Features & Benefits Quality Controlled Factory Calibration Assures Accuracy Of Opening & Closing, Regardless Of Pressure Changes. Positive Piston Heat Motor Provides Accurate Temperature Control. Sturdy Metal Construction Throughout. Attributes Depth from Flange : .82"
Design : Offset
Flange Diameter : 2.125"
Height from Flange : .91"
Jiggle Pin : Yes
Temperature Range : 195 Deg
Warranty Limited Lifetime-See Manufacturers Written Policy
Warranty PDF
Material Safety Data Sheet (MSDS) There is no MSDS for this item Application Information: 1990 Nissan Van Engines : 2.4 L 2389 CC L4 SOHC
Comments: 195 Degrees;Alternate Temperature
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Warranty PDF
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Warranty PDF
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Design : Offset
Jiggle Pin : Yes
Design : Offset
Jiggle Pin : Yes
Feb 27, 2011 | 1990 Nissan Minivan
Over past couple of months the tv has gotten 2 red spots in the lower right hand corner of screen about an inch in diameter, and recently a green spot in center top third of screen that is about 2 inches...
Unfortunately your light engine(also know as optic block) may need to be replaced. If your tv is out of warranty, it will probably cost around $1000 to fix. There is a slim possibility that the optics lens could have dust on it and a tech could clean it for much less than that. This is a very common problem in any dlp tv and they are all expensive to fix. I've replaced several of them at our shop, but about half of the customers won't have the tv fixed and will get a new one. Good luck!
Jul 30, 2010 | Panasonic PT-44LCX65 Television
How come my yamaha raptor 700r will only go 76 with aftermarket tires but with stock tires it goes 80
Most likely a diameter change. Changing tire diameters is like changing gears. I used to road race shifter karts and this was a tuning aid that was often over looked by most. Tire construction/tread design/rim size/side wall will all affect growth at higher speeds basically changing gears progressively. Watch a topfuelers tires and you clearly see this. Your new tires are probally not "growing" as much. This not neccesarily a bad thing. Just different characteristics.
Apr 01, 2010 | 2003 Yamaha YZ 125
Can you change the tyre size set up on a bmw x5 without any issues
Yes and no. Yes you can change the tire size and go up. Your car is equipped with 225/50-17 if I am not mistaken. What you need to be concerned with it not increasing or decreasing the overall diameter of the wheel/tire combination. The diameter of you wheel/tire is 25.9". If you go to a larger or smaller diameter tire you speedometer and odometer will be off. To check the sizes and how they effect the diameter go to this site. Put your OEM size in and then check different sizes and how they effect diameter. http://www.miata.net/garage/tirecalc.html You can on some cars, for a fee, have the ECU reprogrammed for a larger tire by the dealer. Contact your BMW dealer to find out.
Jan 07, 2010 | 2007 BMW 530xi Sports Wagon
Sometimes, when booting-up, the BIOS screen set-up
The motherboard battery is dead. Look on the board for a silver disk about 1/2 inch in diameter, that is the motherboard battery. It is usually held in place by a small spring affair and is easily removed and replaced, your local pharmacy or watch maker should have new ones in stock.
Nov 02, 2009 | ASUS P4S800 Motherboard
How do I find the diameter of my sway bar on my 2003 pontiac sunfire? Are they all the same on the base model?
You would have to use a micrometer. Yes they are all the same the diameter doesn't change.
Sep 30, 2009 | 2003 Pontiac Sunfire
Black holes on Screen
those black holes come usually from a decay in the LCD(from age, like age spots, truly) or something was pressing on the screen..LCD replacement in either case.
Aug 17, 2008 | Dell Latitude D600 Notebook
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
