Question about Brother HL 5250DN Laser Printer
A piece of clear label has stuck to something inside
I printed out clear labels and foolishly reprinted on one that I had cut. A piece of the that clear plastic is stuck on something that must rotate because now a small rectangle shadow repeats three times on my print out paper. Where is the cylinder that must have this stuck on it so I can remove it? HOw do I get to the cylinder?
  • 837 Answers
You can go here and download the service manual for that printer. But as far telling you exactly where that "label" is . .I would guess either the drum or developer ..
Posted on Dec 22, 2008
Why does the label wrap around the bar every other label I print?
possible becouse the tear off position stop the gap on the wrong spot and wen you cut the label, left some label with glue expose, and wen you send other print, the printer make the backfeed and the label go stuck on the white rollar.
go througt the setings to TEAR OFF, and ajust to the front or back, untill hav the best gap/label rest possition and cut proply. don't forget to save (press setup button twice)
May 10, 2010 | Zebra Z4Mplus Label Printer
Printing labels from ebay but they come out blank
If you got a blank shipping label, kindly double check first the ink of your printer. Then you can go ahead and reprint the shipping label. Please follow these steps :to reprint your label:
1. Log in to PayPal at:
https://www.paypal.com/.
2. Click the "History" link.
3. Find the transaction you want to print the label for.
4. Click the "Details" link for that item.
5. Click the "Reprint Label" link at the bottom of the page.
Feb 04, 2010 | Dymo LabelWriter 400 Thermal Printer
My dymo label writer twin turbo stopped printing on left side!
There are a few common reasons this is problem can exist.
1.) the incorrect template is used when creating the label
2.) the labels are installed incorrectly - the labels must be loaded and pushed against the left side of the printer and lid closed when printing to ensure the labels don't "wander" out of the sensor's view.
3.) the label sensor is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view. 4.) the print head is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view.
5.) The labels are defective - if you have another roll of the same size, try it to see if it has the same issue. If not, make sure you purchase quality labels like Dymo name brand or Labelvalue brand Dymo labels.
6.) The printer is defective. Labelwriter 400s have a 2 year warranty, so you can contact Dymo customer support to determine if the printer is defective and return to the retailer you purchased it from.
Oct 08, 2009 | Dymo LabelWriter Thermal Printer
Label stuck on a roller?
Looks like label stuck on the toner cartridge. Easiest solution would be to replace toner cartridge or if you can slowly spin the OPC drum on toner cartridge till you find label NOTE: damage to the OPC drum with affect print quality as well as oil from fingers will affect PQ( print quality)
Jan 13, 2009 | HP LaserJet 5000n Printer
Paper Jam
You may have left some debris in the printer, or there could be a piece of debris blocking one of the sensors. Try to reinspect printer and clean it out throuroughly. If it still isn't printing, try removing toner and replacing again. If neither of those work buy a used laser printer on craigslist and save yourself the trouble.
sorry if this isn't great news. service may be worth it, try a small computer store rather than a larger store.
Dec 09, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Blue color smears on every page
If you're still getting smudges, there must still be a label or part of a label either on one of the image drums or the transfer belt, i've found in the past it somethings gets stuck inside the unit on the cleaning blade. What i suggest is you run a print and open the front door at the paper travels along the transfer belt, look at all the image drums and see if you can see the smudge on one of them, if so the problem is caused by that cartridge if not it's in the transfer belt somewhere. You may need to try stopping the printer a few times and if the problem is in one of the cartridges, you will mst likely have to replace it, as with the transfer belt if you think that's causing the problem it's easier to remove it and rotate the belt manually.
Please note the image drums and the transfer belt are all light sensative
Sep 02, 2008 | HP Color LaserJet 2600n Printer
Tape Jam
There may be a small piece of label cutting stuck in the gears. remove the label cartredge, you will see a white gear set between the pinch wheel and the print head. Use a micro drive or something strong and give the gears a little help while pushing the print button. You may have to do this several times. Be careful not to use too much force as this may knock a tooth off. Good luck. My Dymo continues to print prefet labels.
Mar 08, 2008 | Dymo LetraTAG Thermal Label Printer
Sato CL 480e not printing clearly...
Your platen roller (the black rubber roller) isn't smooth in that spot. Maybe it has be nicked or cut there or has something stuck onto it. If it's cut you will have to replace it, otherwise try cleaning it with high percentage isopropyl alcohol.
Jan 30, 2008 | SATO CL408e Thermal Printer
Z4MPlus barcode printer
I have had this problem, but only when I used a label of a size that isn't within specification. Technically, this printer isn't specified for a label that is under 1 inch in height. I have a label that is only 0.2" in height and it will get sucked down inside the machine. I have asked the people who work on the manufacturing floor to advance the label two rows after a print job so that this doesn't happen. Then I ask them to cut the label off leaving the two rows sticking out. So, the next print job will start with the label stock sticking at least 1/2 " out of the printer.
I believe that also my printer doesn't tear the labels cleanly, so there is sometimes something that can catch right at the tear bar. You can probably fix that problem if it exists for you by adjusting the tear bar, or having a machinists slightly sharpen it. I hope this helps.
Dec 27, 2007 | Zebra Z4Mplus Label Printer
Labels jamming
Check the entire paper processing path as it sound like either the roller gear is not engaging properly to push the paper out of the top, or the output paper path is somehow blocked, like from a label or something else stuck at the top, the roller gear is damaged, or other obstruction.
Nov 16, 2007 | Konica Minolta magicolor 2300DL Laser...
Brother HL 5250DN Laser Printer Logo
94 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
