Question about Lightware VP 800 Plus Multimedia Projector
Manual for lightware vp800, and i can't get the sound to work
I need to find a manual that i can download for the lightware vp800, i cannot get the sound to work at all, also we were having problems with it not wanting to play, it would get choppy, also do they have remotes for these projectors that can be purchased
  • 25 Answers
Try changing to your S video wire input.If you hear a cracking sound it could be you've blown your speakers.It depends on your application but I run all my DVD equipment through my stereo system,just run the same video wire to your stereo and select that input on the stereo .And yes they do have remote controls,try ebay where you can get another vp800 w/remote under 100.
Posted on Oct 27, 2009
  • Robin Wilson
    Robin Wilson Oct 27, 2009
    http://www.askproxima.com/service/Lightb...
    Sorry if I posted the wrong reply.
  • pankaj_jain Oct 24, 2010
    thanks a lot Redzone 133. u solve a big problem. thank you very much again
I have Scouts lightware projectors In the equipment the extractor is working, but there is too much temperature and turn off the equipment only if I take out the back cover the equipment work also dont...
The unit might not cool down if the air filters are blocked. You can check whether the air filters are blocked.
Remove the top cover and check the air filters for dust. Clean the filters and your problem will be solved.
Sep 22, 2011 | Lightware Scout XL Multimedia Projector
Light goes on and off lightware vp800
Hi, How long have you had the unit? If its new take it back and get warranty repair. If longer then, try giving it a good clean. Get some "Air Cans" if you can to blow trough the vents. It could be dust/dirt on the sensor. If you clean it first then we can be sure. If you are ok about taking the casing off then you can give it a better clean. If after cleaning it is still playing up, it is an overheating problem and best repaired by proper service centre as they can get the parts you need.
Sep 08, 2007 | Audio Players & Recorders
After my vp800 plays for a hours it cuts off. WHY?
Remove the cover and check whether the air filters blocked with dust.
Whenair filters are blocked, air doesn't flow freely through the projector. This result in overheating, leading to automatic shutdown.
Sep 21, 2011 | Lightware VP 800 Plus Multimedia Projector
When I connect a Lenovo w500 laptop - using windows xp - the screen of the laptop becomes magnified and the the image from the projecttor reflets same magnifacation - when I disconnect from projector and...
You don't probably, your laptop screen is not exactly becoming magnified, the resolution is being lowered to match the maximum resolution of your projector which is only 800x600. They are setup as "cloned" together. You could try setting up an "extended desktop" rather than having the projector "cloned" with your laptop screen, that way you can change the resolution (within their allowed limits) of both displays independently. To do this, Right click on desktop and select video setting or the control panel of whatever video card you have. If you can set up an extended desktop, it is here that you'll be able to do it.
Jan 10, 2010 | Lightware VP 800 Plus Multimedia Projector
Lightware VP100 has no sound
make sure the internal speakers are on. go through the menu under settings to find out and to turn them on.
Sep 09, 2009 | Lightware VP 800 Plus Multimedia Projector
Two bulbs?
it needs one to work,is better when you installe two,so when is burnt out you just need to slide the other one and continue the show.
Apr 07, 2009 | Lightware VP 800 Plus Multimedia Projector
Can't get computer images to project
Hi, I have found out that you must have the laptop set to an external monitor, in the control panel, display area, click on 2, then you must have the projector turned on before you start the laptop so it can recognize that the projector is there. Also make certain that you allow the unit to cool off by turning the lamp off, leaving the fan on and open the door where the projection lens is located.
Jun 29, 2008 | Lightware VP 800 Plus Multimedia Projector
Lightware vp800
blow out the dust, check the fans, and then replace the thermo sensor if necessary
Sep 08, 2007 | Office Equipment & Supplies
VP100 Projector Powers Up But Doesn't Light Up
Well, If you are pushing the power button beside the lens and the fans speed up but no light is on hte lights might of gone out as of now i have the same projector no one has a replacement bulb but if the fans just go steady and does not speed up when you power it on the there night be a problem with the button try the remote if you have it otherwise it just might be the bulb,
Hope This Helps
Jan 20, 2007 | Lightware VP 100 projector lamp Projector...
Lightware VP 800 Plus Multimedia Projector Logo
1,092 people viewed this question
Top Lightware Office Equipment & Supplies Experts
jasbo
jasbo
Piyal Perera
Piyal Perera
Bill Boyd
Are you a Lightware Office Equipment and Supply Expert? Answer questions, earn points and help others
