Question about RCA F19436 19" TV
Need to hook up headphones to an RCA F19436 19" TV
This TV has RCA jacks in front and on the back, but when hooking up the headphones, there is not sound. I know the headphones work, because when hooking them up to a earphone jack on a different TV they work fine. My 91 yr old mother is in a long-term care facility and she has to turn up the volume so high it disturbs the other residents. Headphones seemed to be a possible solution. I would like to use the TV because she is somewhat familiar with its operation. Harlan
    Top Expert:
  • RCA Master
  • 47,134 Answers
The headphones have to be attached to a specifically identified headphone connector that switches off internal speakers.
Posted on Jun 05, 2017
5 Suggested Answers
  • 119 Answers
SOURCE: audio output jacks
If I remember this tv correctly, check under the audio setting in the menu, most tv's including this on have variable output for the audio o/p. meaning the the o/p vol. is adjusted as the tv speaker vol. changes. some tv's will put out a fixed audio o/p to the rca jacks, but will only do this when the speakers are shut off in the menu (not muted, but off). I have run into this problem many times & have yet to find a better solution to getting a steady sound sound out of the o/p jacks.
Posted on Nov 03, 2006
wayez3
  • 20 Answers
SOURCE: RCA TV
Hook cable directly to television ( no box ) , Then autoprogram the set if you still have the problem replace the tuner it is about $30 rebuilt from Tip Top tuners.Do not attempt if you dont feel comfortable soldering precisely. IRIONS TV & Electronics www.Irionstvshop.com
Posted on Feb 21, 2008
SOURCE: WANT TO HOOK UP MY SONS PLAYSTATION 2 BUT WHEN I
You have to put you TV in AV Mode. You don't use the "Channels Tuner" on this type of input. But use Audio Visual Mode.
Posted on Feb 06, 2010
dvdcdlaser
  • 1285 Answers
SOURCE: I have the TV above and the cable man came out to
is there a coaxial cable jack in the back of tv..(if not you may need an adapter..hook to antenna)..then set the tv to ch 3 and set to cable broadcast not air. then you will use the cable box to tune to ch.
Posted on Jun 07, 2010
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Audio out
Look for a red and white RCA plugs on the back of the TV. It would be marked Audio Out. Otherwise, if your TV has a mini-plug for a headphone that will also work for audio out. A headphone jack could be on the front of the TV or back.
Mar 18, 2013 | Vizio M470VT LCD TV
NEED INSTRUCTIONS FOR HOOKING UP WIRELESS HEADPHONES FOR VIZIO TV
From the manual:
1. Plug the stereo audio cable into the headphone jack of your audio
source (e.g., stereo, TV, CD player, DVD, etc.). If your audio source
has two RCA output jacks instead of a headphone jack, use the
supplied Y cable to connect your headphones to the two (red and
white) RCA jacks.
2. Connect the other end of the stereo audio cable to the AUDIO IN
socket at the back of the recharging cradle/transmitter.
3. Connect the AC/DC main power adapter to the DC IN power
supply socket at the back of the recharging cradle/transmitter. Then,
connect the adapter to an electrical outlet.
Important: This power unit is intended to be correctly oriented in a
vertical or floor mount position.
Manual:
http://audiovox2.info/docs/common/AW772/AW772_OM.pdf
Jun 10, 2011 | Acoustic Research AW-772 Headphones
If I hook up a set of headphones to the slot on the side of the TV the sound goes off and you can only hear sound through the headphones, no one else in the room can hear the TV. Is there a way to hook...
The headphone jack on the TV has switch built-in to kill the TV speakers when headphne jack is used, you need to use powered PC speakers with headphone jack and connect this PC speakers to the Audio line out of the TV set (RED and WHITE RCA audio line out). Basically the powered PC speakers are being used a headphone driver. Or you can get one of those wirless headphone system instead.
Jun 27, 2010 | Televison & Video
Can i hook up my speckers to my tv
yes, all you have to do is plug it into the headphone jack. if your tv doesn't have a headphone jack you can buy an aux jack to the rca input and hook that up. Check out the link below.
3.5mm Headphones Plug Jack to 2 x RCA Audio Cable
Jun 11, 2010 | Logitech Z-5300 Computer Speakers
On the box, it says I can hook it to the tv, but there's no jack that hooks to the tv....
You need a 3.5MM FEMALE Stereo Jack (looks like a headphone jack receptical) to stereo RCA MALE cord. Then plug it into the RCA monitor or audio out of the TV.
Cheers,
Kevin
Feb 26, 2010 | Philips MMS 321 Computer Speakers
Need headphone solution for Panasonic c12lcd tv
I have a Panasonic viera 32in lcd hd tv. I'm trying to hook up headphones but there's is no apparent audio output jacks. But there's is only one digtal output jack! is this the jack ? and if it is, what cables do I need to make the headphones work? or am I forced into by an amplifier
Sep 30, 2009 | Panasonic Viera TC-32LZ800 32 in. LCD HDTV
TRYING TO HOOK UP HEADPHONES,IS IT CAPABLE.
Hello, IF your tv is capable of using headphones it will have a little jack with a head phone symbol over it or under it most likely. IF not you can buy a home theater system which would hook up to your tv and some of these have an option to hook up headphones or even ipods and usb devices.
the greek
May 31, 2009 | Sanyo DP19648 19 in. LCD TV
My 91 year old mother is very hard of hearing and in a long-term care facility. I want to install headphones on her RCA F19436 TV. There are output jacks on the back, but that hook-up doesn't seem to work....
You probably will need to make a wireless connection to the TV so your mother can control volume remotely. Went through that with my Mom in similar circumstances.
Jul 24, 2017 | RCA F19436 19" TV
Audio output from my TV
take a red and white audio rca cable and cut off one end of the jacks. on the end you cut, solder a headphone output plug on. can also solder on the lines of a pair of headphones (where you've cut off the 1/8 in jack) directly to the rcv jacks.
Nov 07, 2008 | RCA Personal MP3/CD Player
RCA F19436 19" TV Logo
111 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
