Question about Magic Chef CYE2000 Electric Commercial Dryer
Magic Chef Dryer CYE30005ayw
Yesterday there was a short power outage (30 seconds or so) while the dryer was running and when the power came back on the dryer will not start. There is electricity at the outlet.
  • flpotts Dec 22, 2008
    could you please resubmit your response, there is no answer on my end.
    Thanks
  • Magic Chef Master
  • 8,220 Answers
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 22, 2008
  • Dan Webster
    Dan Webster Dec 22, 2008
    Remove the 2 screws on the bottom of the front panel.
    The heater assembly will be located in the rear on the left.
    Take the 2 screws off of it on either side and remove the heater element. Check the limits mounted on the element. The small round one is the one that will be bad. Just guessing.
Hello I have an HMCF7W1 Magic Chef freezer, after a power outage the power light comes on, but the Run light will not turn on and everything is thawed. What can I do?
Perhaps the power outage, was caused by your freezer?
When you think a reset would help, the run light should come on, after a little while. But perhaps only the thermostat is defect.
Be aware there can be so many causes, and none has to be related to the power outage, for your freezer not to work.
It would be virtually impossible to see what is wrong, from a distance. Better try to bring the food to a working fridge and call a tech to solve the problem.
Feb 08, 2015 | Magic Chef Freezers
Magic Chef front load dryer is not spinning?? worked yesterday
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 04, 2011 | Magic Chef Dryers
My gas burner comes on and goes for about 30 seconds to a minute and then shuts off and then 30 seconds or so later will come back on
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help troubleshooting a gas dryer
Sep 24, 2010 | Magic Chef CYG2000AWW Gas Dryer
My magic chef clothes dryer won't fire up. The ignitor glows about every 30 seconds but no ignition. I checked the gas supply ,made sure it was ON. HELP ME PLEASE!!!
if the ignition is working but wont lite the gas presure valve is detecting a fault and refusing to lite you will need to have it checked by a cert plumber.. sorry
Jun 18, 2010 | Magic Chef CYG3004AWW Gas Dryer
Magic Chef electric Dryer won't start
Do you have power going to the receptacle. You can first go to your house panel and look for the circuit breaker for the dryer (usually a 30 amp 2-pole brkr.). It could be tripped. So first, put your dryer in the off position. Next, go back to your circuit breaker in your house panel. Turn off the breaker, and then turn it back on. This should reset the circuit breaker for the dryer. Then go back and try turning on your dryer. If this doesn't work, feel free to contact me again. However, this would seem to be it. Good Luck to you!
Mar 28, 2010 | Magic Chef Dryers
Magic chef dryer quit working
There is a thermal fuse inside the dryer usually located behind the back cover on the upper part of the combustion chamber. When this fuse "blows" it turns off power to the whole dryer. This keeps your house from burning to the grown, and you from dying. The fuse "blows" for a reason, most likely to is lint build-up in the dryer and/or dryer vent system. The good new it only cost a few dollars to get a new one. The bad news is you need to find out why it "blew", the dryer got to hot for a reason.
Mar 04, 2010 | Magic Chef CYE2000 Electric Commercial...
My magic chef dryer just won't start, was working perfectly yesterday, I have checked the breakers, they are fine. What would cause it to just stop?
Check your switch on the door first. Its like a light switch. If you have a volt ohm meter switch it to the ohm setting and test both leads coming from the switch. Have the power cord unplugged first to prevent shoc. No power is needed to test Ohm ratings
Jan 14, 2010 | Magic Chef CYE4000AWW Electric Dryer
CTB1722GRW compressor clicking on for 20 to 30 seconds then off.
it depends on how severe the power spike on the outage was,if your lucky it may just be the contactor,if not comp time,you can open the contactor case and manually start the compressor,use an insulated non-metallic device to do so
Jul 20, 2009 | Magic Chef CTB1722 Top Freezer...
My Magic Chef dryer doesn't dry properly
remove the vent from the back of the machine, run it full of clothes from the washing machine and if it dries nicely, then you have a clogged vent that needs replacing.
Jun 16, 2009 | Magic Chef CYE2000 Electric Commercial...
Magic Chef CYE2000 Electric Commercial Dryer Logo
77 people viewed this question
Top Magic Chef Dryers Experts
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
