Question about Refrigerators
Amana Side by Side, freezer not cooling adequately
Amana side by side Model SX22SE. ~ 10 years old
Freezer side will not go below 20 degrees with thermostat knob set at max (7). Freezer will get warmer with lower settings
Have Cleaned cooling coils, fan & compressor both operational. Fresh food side works (cools) properly.
  • kaceech Apr 20, 2009
    I have 8-year-old side by side, Model SB21VE, with the same issue.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 633 Answers
First make sure the fridge has not frozen over if there is ice on the walls it will screw the system that determines how cold it is up. if this is the case empty the fridge unplug and use a hair dryer to carefully speed up the thawing process. usually this happens during warm and humid seasons.
if this is not the case then see below and you might need a professional appliance service to perform the below unless you are fairly skilled
The temperature control thermostat directs voltage to the compressor, evaporator fan motor, and condenser fan motor (if applicable). If the temperature control thermostat is not working properly, it may cause the refrigerant system to run longer than necessary. As a result, the refrigerator will be too cold. To determine if the thermostat is defective, rotate the thermostat from the lowest setting to the highest setting and listen for a click. If the thermostat clicks, it is not likely defective. If the thermostat does not click, use a multimeter to test the thermostat for continuity. If the temperature control thermostat does not have continuity at any setting, replace it.
The thermistor monitors the air temperature and sends the temperature reading to the control board. The control board then regulates power to the compressor and evaporator fan based on the thermistor readings. If the thermistor is defective, the compressor and evaporator fan may run too frequently. As a result, the refrigerator will be too cool. To determine if the thermistor is defective, test it with a multimeter. The thermistor resistance should change in conjunction with the refrigerator temperature. If the thermistor resistance does not change, or the thermistor does not have continuity, replace the thermistor.
Posted on Jan 02, 2018
kstfas
  • 75 Answers
SOURCE: doesn't cool
Hi, Yes, If the evaporator was not frozen over then I agree with you. The unit has lost its refrigerant charge. The only thing you can do is to have a licensed refrigeration man find the leak, repair it and recharge it or replace the refrigerator. If the evaporator is frozen over the defrost timer would be the problem. In this case, manually defrost it and it will be good for a few days until you get it replaced. kstfas
Posted on Sep 27, 2007
  • 833 Answers
SOURCE: Fresh food section not maintaining cold temp
You're frozen up.  Defrost completely.  Then, clean your condenser.  Make sure to never leave open containers in the fridge...water condenses into ice.  If you still have problems, you may be low on gas.
Posted on Nov 21, 2008
  • 163 Answers
SOURCE: FRESH FOOD SIDE OF FRIG NOT COOLING
i would take the back freezer panel off and see what kind of frost pattern your coils have.they may be frosted over and the begining of a defrost problem.
Posted on Mar 11, 2009
  • 198 Answers
SOURCE: freezer fine, fresh food 55 degrees max cold
Check for frost build up in freezer section. If frosting up you will need to check the heater and bi metal. If it's a ge ref. could be thermister or main board
Posted on Feb 25, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: Hotpoint hts17gbserww My refrigerator section is
Sorry to read about your problem, I hope this helps you out.
if you have the freezer set to the coldest setting, you may want to check your door gasket.
Try and put your mouth/lips close to the seals, your nose/lips can sense cold very well. if you feel cold coming out, replace the door gasket.
if the door gasket seems ok, you maybe low on freon, or a defective temp sensor. or you may even have a defrost problem.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
Testimonial: "Thanks for suggesting a couple of things to check."
Refrigerator and freezer not cooling adequately
the ptc overload on the compressor is defective,replace this and it will again cool properly
Feb 16, 2012 | Magic Chef Refrigerators
My Amana 26 cu ft side by side quit cooling entirely in the freezer and the refrigerator. Is it worth it to get a repairman or should we just get a new frig. This one is 6 years old
I suggest get help with repairman.6 year old is not very old.Refrigerators have life more then 8 to 10 years.The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. These are basic possibilities which first need to be checked. But if these possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This will help. Thanks.Helpmech.
Oct 24, 2011 | Amana 26 cu. ft. Side-By-Side...
Freezer side works, other side does not cool
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you ti figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 06, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Freezer won't go below 32 degrees
Need condenser fan for unit to cool properly
Apr 27, 2010 | Amana SXD524VW Side by Side Refrigerator
Amana side by side refrigerator wont cool properly after moving from one house to another
have a two year old side by side amana frig. the freezer side works fine, the frig is at 56 degrees at coldest setitng. HELP, can't get repair guy for five days cause we live in rural area.
Apr 19, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
Freezer won't go below 10 and fridge goes between 40 and 60 degrees
Ensure the condenser is not clogged with dust or other debris.
Ensure the condenser fan (usually found in back) is turning when the fridge is running.
May 26, 2009 | Amana SXD524VW Side by Side Refrigerator
My Kenmore freezer, model #253.9280212 runs but will not cool below 40 degrees. It runs all the time but I do not hear anything cut on and off. The freezer is 10 years old but looks brand new.
The first thing to check is door gasket< bad corners,gap in side,bottom or top. Close door on a dollar bill and try to slide it top to bottom side to side and if it slides fairly easy then seal is not doing good. If you find dirty area clean it off along with the cabinet side as well.If you find the side is leaking then heat gasket with hair dryer and apply vasoline to gasket to help it move freely. If you find tear or hole then replace it.
Apr 22, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Believe my compressor is bad
bite the bullet. or get a repiar person who know how to fix it.
Oct 12, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
137 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
