Question about Empire Heating & Cooling
Soot coming from Wall Heater
I have a propane wall heater and soot falls on the floor.. I have taken it apart in the past and cleanded the ducts of soot. Yet it still does it. Is there a possibility the burners are shot? Or??
  • wvandersyde Dec 23, 2008
    Thanks for the info. This makes sense.. I will check it out and see what happens
    Scholar:
  • 75 Answers
The fuel mix it too rich. There should be a place where the gas hose goes into the burner part, and an adjustment where you can adjust how much air it gets. The flame should be almost 100% blue. It can make the grates glow another color, but the flame should be mostly blue.
Posted on Dec 22, 2008
Came down stairs water heater off and pan filled with water
Copy following link for troubleshooting leaking water heater.
http://waterheatertimer.org/Leaking-water-heater.html
You posted question under propane gas heater.
Propane is heavier and air, and this type gas water heater should not be installed in basement (below grade) since gas leak can fill basement with explosive gas.
Water leak does not cause gas leak, so water leak is separate problem.
Recommended for propane safety: install gas detector close to floor near gas water heater
Regular Natural Gas heater, install gas detector higher on wall since NG is lighter than air and will rise.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 04, 2012 | Whirlpool 40-Gallon 6-Year Gas Water...
I have black soot coming out of my gas wall heater and the vent on the roof is all black too. Not sure the age of it, could be up to 50 years.
You need to have a service company come in and service your heater. #1 it needs to be cleand. #2 They need to do a thorough check out of your heating system. I can not stress this enough; your flue and heat exchanger are blocking up and you are at risk for carbon monoxide poisining.
Oct 07, 2010 | Heating & Cooling
DESA Propane Heater Valve Apart
Do,not override the safety features on any units unless youre qualified. These are not overides ,but safety switches to tell when something is not right! Anyway, its time for a fall service overhaul or kit ---plug---fuel filter---2 air filters --clean the flame sensor---and vanes in the pump replaced.You can buy the kit and parts that you need a your local lawnmower repair shop or have them to order them!
Dec 14, 2009 | Desa International Propane Portable...
How to change gas orfice to propane glass smokes up. soot
Is this unit originally set up for natural gas? If so, the burner oriface and the gas valve need to be retro-fitted to propane. This is something only a qualified service technician should attempt as an incorrect retro-fit could cause an explosion resulting in someone getting hurt or even killed.
Nov 09, 2009 | Empire Hight Efficient Direct Vent Wall...
Have to keep replacing the thermister. H400
Constant sooting can be from a down draft problem, too close to any wall 8 feet tall or more. this is fixed with a draft hood. Or check to be sure you have a propane heater if you have a natural gas with lp running to it or an lp with natural gas running to it this will cause the problem also. This can be cured with a conversion kit for a fue dollars at you local supply store. It will be a pre block for your gas valve and new orfaces for your burner tray. It will come with detailed instructions that will be tougher to deal with than the process. I hope this helps and good luck
Oct 24, 2009 | Hayward H Series Pool & Spa Heater 400k...
Gas dryer leaves black grease spots on clothes
the soot is coming from the flame at the gas heater box the drier needs to be converted to propane the flame is too large without the conversion kit installed and thus creates soot at the vent. contact a local repair place for this one it can be tricky.
Sep 12, 2009 | Whirlpool LGR5636L Gas Dryer
There is a black "soot" coming from my radiant heater
Black soot appearing above and around electric baseboard heaters is caused by burnt hydrocarbons in the air.
The Heating element draws the cool room air from the bottom and over the element. Any excess hydrocarbons in the air become burned and are deposited on the surrounding surfaces from the warm heated air flowing up out of the heater.
The Heater is not the cause of these hydrocarbons. They come from the home / enviornment.
Some cause.
Smoking, burning Candles releases waxy hydrocarbons, carpet cleaning solutions, spray type air fresheners.
Black waxy sooty deposits are usually from burning candles.
Posted by George Patterson
Jan 13, 2009 | Fahrenheat FBE15002 Baseboard Heater
I have a propane Empire Wall Heater. Soot falls on the floor around the heater.. I have taken the heater apart in the past and cleaned out the ducts. But it still does it. Is there a possibility the...
if your heater is sooting up that means that there is not complete combustion accuring , WHat you need to do is call a service company that is liscensed to do propane appliances and have them check it out.
Thanks for using fixya
Dec 22, 2008 | Heating & Cooling
Inefficient (big, yellow flame) on wall propane heater, using up propane too fast
A clue to what could be wrong is that you mentioned it took 10 minutes for the pilot to go out. It could be your gas valve. Get a technician in to check your gas pressure both before the gas valve and after. Have them check it as the water heater is running.
May 15, 2008 | Dayton Heating & Cooling
Heating & Cooling Logo
328 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
