When i first got this laptop like a few days later I found a way to turn off my LED side lights on my laptop and the lights on the bottom that changed colors. Now I cannot figure out how to turn them back on and i've looked online but that was pretty much no help. I've already went into the BIOS menu and could not find the LED in there.
SOURCE: DV9000 issues
hey, so ir dv9000 doesnt boot to hp logo screen & restart itself,first replace the cmos battery if thisdoesnt solves ur problem, the next time u boot check whether the rj45 & the dial up port give a led flash on start or not ,if not then u may have hape board ,cpu or power problem ....which can be fixed by repair only.
SOURCE: I have a 2000 Subaru
Here is an idea. Check the connections between the battery and the car's ground and the starter. Then find the ground cable which connects the engine to the car and check the connections there as well. Often times odd ball electrical problems are caused by a faulty ground, especially when there is a starter issue. May help, costs nothing but a few moments of your time, and once in a dozen times it is the problem.
SOURCE: My 2003 Hyundai Accent just
P1401=
Go to www.hmaservice.com and register your vehicle by VIN #.. you'll then have access to wiring diagrams, shop manuals, service bulletins, campaigns, illustrations and procedures, etc.
SOURCE: I have a Kenmore side-by-side model 106.41212101.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
Be sure the BACK COVER is in place and hasnt been accidently removed.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
