Question about RCA F19436 19" TV
My 91 year old mother is very hard of hearing and in a long-term care facility. I want to install headphones on her RCA F19436 TV. There are output jacks on the back, but that hook-up doesn't seem to work. The headphones work fine on a TV with an earphone jack, but this TV evidently does not have one. Should I try to hook up directly to the leads to the speakers inside the chassis?? Any suggestions? Harlan
    Top Expert:
  • RCA Master
  • 49,896 Answers
You probably will need to make a wireless connection to the TV so your mother can control volume remotely. Went through that with my Mom in similar circumstances.
Posted on Jul 24, 2017
5 Suggested Answers
  • 119 Answers
SOURCE: audio output jacks
If I remember this tv correctly, check under the audio setting in the menu, most tv's including this on have variable output for the audio o/p. meaning the the o/p vol. is adjusted as the tv speaker vol. changes. some tv's will put out a fixed audio o/p to the rca jacks, but will only do this when the speakers are shut off in the menu (not muted, but off). I have run into this problem many times & have yet to find a better solution to getting a steady sound sound out of the o/p jacks.
Posted on Nov 03, 2006
  • 99 Answers
SOURCE: Can I hook up external speakers to this T.V.?
This tv carries two sound out phono plugs, but if for some reason they are not there ( date of mfr ) you can use the headphone out jack. Just go to any radio shack store and explain what you are trying to do and im sure they will be happy to assist you.
good luck,
Posted on Feb 09, 2008
  • 213 Answers
SOURCE: no picture
you have bad solder inthe center of the pcb board behind the hozoutput thear is bad solder you can have it fix the fix cost
79 to 89.00 no your pixtube is not bad this is a comam
thing with rca.ctc203ctc195 all of this have the same thing that go wrong this set.
Posted on Apr 01, 2008
SOURCE: WANT TO HOOK UP MY SONS PLAYSTATION 2 BUT WHEN I
You have to put you TV in AV Mode. You don't use the "Channels Tuner" on this type of input. But use Audio Visual Mode.
Posted on Feb 06, 2010
Hdtv optical audio output works except in tv mode
Unplug one of the RCA plugs one at a time, see if sound changes to no buzz but one ear channel only. The buzz can occur when RCA is not connected correctly and the video feed is put onto the earth wire of both audio feeds.
Dec 15, 2013 | LG Televison & Video
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
I just received for my birthday, a RCA 900 MHz headphones. Followed the instructions but cannot get it to work. I tried to install it on a Hitasha TV. Can you help me?
  • "Connect the RCAheadphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) RCA pilot lamp should flicker in parallel to voice coming from TV
  • RCA headphone should have 2 different rotary adjustment on it..one "Volume" and the second "Frequency" adjustment
  • while TV talking , adjust slowly the "frequency rotary dial" to catch the headphone transmitter coming from RCA headphone base,when you catch it you will hear the voice of TV,(sometimes fine adjustment makes it better ) than adjust volume properly..
  • .After this pls do not touch Frequency dial any more..Just Turn it on ,and Volume adjustment ..Thats it..
  • After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs work independently from the TV's master volume control..
Jun 30, 2011 | RCA Audio Players & Recorders
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
Need to hook up headphones to an RCA F19436 19" TV
The headphones have to be attached to a specifically identified headphone connector that switches off internal speakers.
Jun 05, 2017 | RCA F19436 19" TV
Parental Control Code?
if you forgot your password you can reset it ,turn tv off press and hold vol< on tv and clear on the remote for 5 sec.,enter a new password next time you access the parental control menu.
Apr 16, 2008 | RCA F19436 19" TV
RCA f20580wn 20" TV about 20 years old
Hopefully you have the problem solved.
If not, the RCA plugs, listed as input 1 and 2 are shown on channel 91 and 92.
I recommend connecting the DVD to either input. Turn on the DVD. Then run the auto programming function of the TV. It will find and program the channel for the DVD. Then use the channel up or down on the remote you are currently using and you should find a working DVD.
Hope this helps.
Rcs97
Apr 07, 2008 | Televison & Video
Picture but no sound
check audio speaker ,audio ic & its supply voltages,check audio signal
Jan 10, 2008 | Televison & Video
Sound
It could be a defective speaker or the audio output IC could be bad also. If your not a tech its a good Idea to seek a pro in the repair of a tv set as there are no user serviceable parts inside these set. Good Luck
Jun 30, 2006 | RCA F19436 19" TV
RCA F19436 19" TV Logo
57 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
