Question about Kenmore Elite 45986 Front Load Washer
Kenmore door to tub spring has come off
My washer tub came out of my Kenmore front loading door to tub seal after my son pulled too large a pile of clothes out. Everything looks fine but I am holding the spring in my hand and the tub is totaly out of the seal. Do I need to follow the same instructions as if I was installing a new seal or is there a short cut? It seems a pity to remove all else when it is still water tight. Getting the spring back in the track with out the support of the tube seems impossable. My washer is an older model serial no. 417.29042992
Thank you,
Marcus
  • par4n1 Dec 22, 2008
    does the front of the machine and door need to come off?
    Thank you
  • 5,911 Answers
If you are talking about the inner spring that holds the door bellow to the tub, it's going to require two hands to get the spring to go back in the groove. You will need to carefully remove the bellow from the front opening of the door, first. On the 417 models, such as yours, the bellow is usually glued in place aorund the door frame and held in place by a spring to the tub. Use a putty knife to carefully peel the rubber form the washer facing. Once completed, you can glue it back in place with some appliance adhesive. To get the spring back in the groove on the tub facing, you will need to start at the top and have someone hold it on place as you work your way around the the tub. It's a real bear to get back in at times. Let me know if this helps you. Please post back if you have questions.
Posted on Dec 22, 2008
  • Jeff Rockwell
    Jeff Rockwell Dec 22, 2008
    If you can remove the front panel, it would make access much easier. However, you CAN work through the door opening to complete the task and save some time. Removing the fornt panel on some 417 models is not easy though. There's more work involved in removing the panel, than actually getting the bellow back in place. If you leave the front panel in place, remove the lower panel under the door. One person can work through the door opening to position the bellow spring and hold it in place, while another works from below (through the bottom panel access) to stretch the spring and work it around the groove.
  • Jeff Rockwell
    Jeff Rockwell Dec 23, 2008
    How are things going with you? Were you able to resolve your problem?
Basket rubs on door boot seal.
Be sure both lower and upper halves are correctly connect together
May 01, 2017 | Frigidaire Washing Machines
Rubber seal damaged. needs to be replaced kenmore model 970-c44052-00 How do I remove sides to get at it?
there is no need to remove the side to replace the door seal, just behind the door seal there is a spring clip undo this and fold the seal into the drum were you should see another spring clip undo that as well and the door seal comes out from the front through the hole in the door, to refit a new fold the seal till its inside out and fitted on the inner drum first fit the inner clip then pull it through the door hole and fit the outer spring clip out side the door
Dec 06, 2009 | Kenmore 43142 Front Load Washer
The boot seal/tub seal is torn and I want to replace this piece
door boot or baffle as it is sometimes called can be replaced. however it is not an easy job as there is a large spring that hold it on.
Oct 04, 2009 | Kenmore Elite 45986 Front Load Washer
Large rubber door seal came apart
Yes it can be put back on without taking the drum apart. The larger end goes on the drum side. Fit larger end around drum lip make sure it seals all the way around, install spring around seal. Smaller end goes around door opening. Install seal around outter lip and install spring around seal.
Mar 05, 2009 | Kenmore 44102 Front Load Washer
Kenmore HE 3t Front Loading washer, rubber seal torn
fix ya..do it your self and save big,,im going to talk you through..and give you the part number...what you need is the bellows part # 8182119...ok vack unplug unit..open the door,,now you see the front lip of the bellow theres a wire with a spring stick a srew driver and pull off,,wire off ..ok now look in the unit right behind the front panel and in front of the tub in the upper right hand corner of tub font or bellows backside there a nut take screwdiver and losen pull bellows off,,easy to put back just reverse but open clamp a bit on back...onthejob
Jan 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3T door seal tear
tear may be from pulling something across it with sharp edges..to replace seall not major job front part of seal held in place with spring ..remove and pull boot away from front edge inlet tub slides out of boot opening rear held in place with LARGE screw clamp a little patience is usually all that's needed ..did 2 today
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
KENMORE H3T WASHER GREY TWISTED FRONT SEAL
I am currently replacing this bellow because of holes and five years of wear and tear. The bellow is attached to the front door assembly via a spring loaded clamp. This clamp is a solid large wire ring with loops on each end where the spring attaches. You do not have to remove the spring, just place a screwdriver between the bellow and the ring or spring to remove. This will allow you to take off the bellow from the lip of the front door assembly to reposition. The spring clamp goes on starting first from opposite of the spring and working in both directions a little at a time. ALL DONE.
Dec 20, 2006 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
220 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
