Question about Kenmore 22422 Top Load Washer
Cold water won't fill.
We've been having to wedge a sliver of wood behind the temp control knob to get the hot to work. Now after a couple of months the cold is not working. Replace the water inlet valve about 6 months ago so I don't think it's that.
Turned out to be a frozen water ine which I've never experienced in this house before. Thanks anyways.
Posted on Dec 23, 2008
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Water is not coming in to washing machine when Start knob is pulled. When I disconnect both hoses, water is coming through faucets. Spin cycle is working fine.
ok
Two things control the fill. The fill "solonoids " ,hot and cold, via the temp selector
and the water level switch.Check cold only. If you get cold then your problem is definitely hot solonoid or temp select switch.If you get no water of any temp
then suspect water level switch and or temp select.Water level switch is behind console.Sometimes just turning level knob will get it to work . In any case, remove console and find the large switch with the small tube attached to it. If that tube gets kinked or clogged the machine won't stop filling.Your problem is the opposite. The switch thinks the tub is full. To test the swich, pull start knob.Put a volt meter or simple test light to one side of switch and ground, Then do same test on other side of switch.
There should be voltage available on both sides .If voltage on one side. replace switch.If voltage on no sides, the problem is the timer.(Not likely)Remember ,this test there is live electricity use extreme caution please!
Hope this helps
Sep 15, 2011 | Washing Machines
Oasis Elite auto temp control does not allow cold water
Ok, often the actual inlet Solenoid/Valves get "Gummed Up" and need to be "Stripped Down" and put in a bath of solvent for a bit, But, sometimes a couple of good "Whacks" with a suitable tool, will "Free Up" the jammed valve. I wouldn't wonder if this wasn't your problem all along? Anyway try that...
Mar 15, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore front loader sometimes fills with warm water on cold setting.
Most washer today use automatic temp. control fill valves. If water is too cold the control might mix in some hot to bring up to a preset temp. The same is true when control set for hot. For energy savings cold water will be mixed in to maintain a semi hot temp. Check with manufacture just to be sure.
Feb 03, 2010 | Kenmore 3.5 cu. ft. King Size Capacity Top...
GE super capacity heavy duty washing not filling w/hot water
On an older model washer, you probably have a bad water valve. (hot water solenoid coil electrically " open ") Newer models, now there's a can of worms. Some models use thermistatically controled water valves to limit water temps, so you may not be able to get true hot water. Also, if you are checking the temp as the machine fills, some models will only fill with cold if the lid is open. (safety feature) The only way to see what is really going on is to fill the machine with cold and use a thermometer to check the water temp, then, pump that out and fill (with the lid closed) with hot and check to see if that temp is higher. As stated previously, water temp may not really be " HOT " but may be warmer than " COLD ". That may be as good as you will be able to do, as all manufacturers are trying to reduce energy consumption. Thank your government.
Jan 21, 2010 | Washing Machines
How can I disconnect the auto temp control on a whirlpool washer so my wife can wash with straight hot water?
There are no short cuts to auto temp control.To bypass you would need to change the wiring harness and control panel to mod to a lower end washer.
To do that would cost big bucks.
Jan 20, 2010 | Whirlpool Washing Machines
Whirlpool washing machine...only uses hot water
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
Sep 12, 2009 | Washing Machines
Water intake
sounds like a problem with your selector switch , or you ve hooked up your hoses backwards(pretty common issue).new accutemp water temps will indeed turn hot water on even though yuove sselected cold/cold wash. Energy guidelines state that there is an optimimum "cold" temp and if your water is too cold it will turn on the hot water to stablize a warmer "cold".
Oct 27, 2008 | Whirlpool Washing Machines
Temperature Control Problem
is washer less than a year old? if so call reapir ..there was an issue with the temp controls on a small number of those machines they use an electronic control in what looks like a mechanical switch..if over a yr old could still be a temp switch but be sure hoses are connected correctly and on a rinse cycle the water does come in hot ..don't worry too much about wash cycles temp is controlled to to prset temps and is based on final water temp in tub after fill not incoming water temp
Aug 06, 2008 | Whirlpool WTW5500S
Kenmore 22422 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
