Question about Toshiba DKT3020SD Corded Phone
Is there a mute feature? Using the speaker phone w/mute?
  • 21 Answers
Sometimes the mute button is with the menu button or it has it own button. I would look on the phone and see if there is mute above a button. If it is above a button than that is the mute button when the phone is on. To make sure, I would call a friend then put it on speaker, then hit that button to see if that is it.
Posted on Dec 22, 2008
2 Suggested Answers
  • 225 Answers
SOURCE: Cannot hear the ring on a particular phone. The
There is a speaker test you can do. Press the feature button then on the dial pad press 805 followed by the # key or the next key until you see speaker test in the display. Press the test key or the hold button to start the test. You should hear a page tone at maximum volume. Press any button to end the test, the volume will return to its previous level.
The phone is mute by pressing the handsfree/mute button(bottom left button). sometimes the button labels do not match the feature that is programmed for the button. Press feature * 0 and any button to see what feature is programmed on the button.
Posted on Dec 13, 2010
How do I put it on speakerphone?
Cricket Samsung Galaxy Grand Prime: Speakerphone:
1. During a call, tap Speaker to turn speaker ON
2. Tap Speaker again to turn speaker OFF
3. Tap Mute to mute the call
4. Tap Mute to unmute the call
see interactive map here that indicates where the Speaker icon is during the call
Using the Speakerphone
Jan 12, 2016 | Samsung Cell Phones
How to get my unidendect60 off silent mode
Uniden offers a variety of electronics products including corded and cordless telephones. Each of these phones features the ability to mute the phone whenever you desire. Muting the phone can be done as often as you like and canceled as you desire. The steps to muting your phone will vary depending on the type of phone you are using.
b> Locate the "Mute" button on the phone. The button will be on the keypad near the number keys. Press the "Mute" button to mute the phone. Look for the "Mute" indicator on the phone's display to ensure that the phone is muted. Speakerphone Volume Use the VOL (+ or -) buttons to adjust the speakerphone listening volume while it is in use.
http://www.uniden.com/pdf/1380BKom.pdf users guide
Jan 20, 2013 | Lands Phones
Does this phone have speaker phone, and if so how do i turn it on?
Yes, there is a speaker option. Holding the phone in your hand look down to the lowest row of buttons - below the * 0 # buttons. There are four buttons: from left to right they are SPEAKER; PAUSE/REDIAL; REMOVE/MUTE; and, INT (INTERCOM.) Pressing the left/SPEAKER button one time turns on this feature. Pressing this button turns OFF this feature. Hope this was helpful.
May 11, 2011 | Vtech 5.8GHz Cordless Phone with Digital...
Cannot hear the ring on a particular phone. The same phone also cannot hear anything when using the "Handsfree" feature, nor can antyhing such as voice mail messages, be heard through the...
Dec 13, 2010 | NorStar M7324 Telephone
Using the T7316E in an onair studio want to have external mute
You can use Do Not Disturb feature
Feature 85 - On
Feature #85 - Off
Cheers
Jun 17, 2009 | NorStar T7316E Corded Phone
GE desk speaker phone model #2-9390A (NOT cordless) we cannot activate the speaker feature - any helpful hints? carole
There is not a programmable mute function on this phone so unless it is broke you should just have to push in the speaker button to answer the phone or push it and hang up to activate the speaker function. Hope this helps you.
Mar 29, 2009 | GE Lands Phones
On calling anyone they cannot hear me
Are you using speaker phone? Are you using the Hand Set?
If you are using the speaker phone, the first thing is to check the back end configuration of your IP phone system and Make sure that that Station has the Microphone Feature enabled. If it does, then the next step would be to configure a different phone with your same extension and ip. If that phone works fine, then it tells you that it is the microphone inside the original phone that is bad.
If it doesn't fix it, then the problem lies on some of the settings within your phone system.
Some other simply things to try if using the Handset, is 1) Replace the cord from the telephone base to the handset. 2) Grab a similar headset and hook it up to your phone. Test calling someone internally in the office, and out of the office.
Mar 09, 2009 | Inter-Tel Axxess Corded Phone
How do I mute my MLS-34D when using Speakerphone?
5104,
The button that mutes the speakerphone is the mic/HFAI key located above your speaker button. The mic mute feature works while using the speaker, when the phone is idle it works as the handsfree answerback intercom.
hope that helps,
Feb 09, 2009 | Lucent Lands Phones
Panasonic Phones are on mute and will not work
The following is generic for most cordless phones:
Did you check to make sure that the phone is not in the intercom mode? If this phone has a base station speaker phone, make sure it is not on mute. Some of these phones have a fax connection. Make sure your phone line is not accidently pluged in to the fax section. Also if the phone has a fax monitoring feature check the the setup menu that the fax is not enabled. If the phone has an answering machine mode, make sure that this feature is turned off.
In the worse case:
There may be a defect in the X-Mit section of the phone. I would suspect the fault to be in the base.
Jerry G.
Apr 09, 2008 | Panasonic KX-TG5632 Phone
My NEC Dterm Series E 16D-1 does not display the MUTE feature
Sir, a co-worker with this phone has the same problem, i have a fund the users manual for the phone and the code to turn on/off the mic is Feature then the number 1. for her the mic button lights up when the phone is off. meaning no one can hear her. the link for the users guide is.
http://www.chickasawtel.com/pdf/manuals/elitemultilineug.pdf
hope this helps.
Nov 28, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Toshiba DKT3020SD Corded Phone Logo
1,021 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
JP Services
JP Services
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
