How do I reduce the amount of moisture accumulating on my windows
I have a carrier weathermaster 9200 furnace with central air. I am getting way too much ice and condensation on my window frames and need to know how I can reduce/eliminate this problem.
Thanks
Marcel
  • 700 Answers
First off run your bathroom fan for at least 1 hour after you take a shower. another thing to do if you have a humidifier is to lower the setting whenever the outside ambient goes down.
Posted on Dec 22, 2008
Why is water accumulating at the base of a newly installed furnace?
Air contains water molecules. Cold air has a lot more than hot air does. When you heated all that cold air the moisture was squeezed out in much the same way water accumulates on the window glass when hot air interfaces with cold.
Oct 14, 2014 | Heating & Cooling
What do I do if red LED light stays on and my furnace (Carrier WeatherMaker 9200), does not start.
turn power off for 5 min to reset and check thermostat wiring the red wire should be connecting to the white try a jumper at the furnace
Sep 12, 2014 | Heating & Cooling
Carrier weathermaker 9200 furnace air filter placement
air filter for your model can be found on amazon, click here and take a look: 20x25x5 Electrostatic Washable Furnace and Ac Filter 19 3 4 24 3 8 4 3 8. I hope this was helpful. Cheers
Feb 17, 2013 | Heating & Cooling
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
Feb 12, 2012 | Heating & Cooling
It leaks out of a tube in the back....it has only just started and have had the machine for a while now
Depending on humidity all air conditioners make a varying amount of condensate water,
its simply akin to placing a cold can of soda on a table and watching it grow wet on the exterior of the can as the moisture in the air condenses from its vapor form into a liquid form or state.
AC units have a splash ring on their condenser fan blades perimeterthat hurls the consensate upon the hot condenser coils thus evaporating the moisture usually, if it cant , it will do as you see.
I am assuming its a window or wall AC unit and not a central AC system.
If its a central system there are 2 drains, a primary and a secondary, the primary will be routed to a place you wont ever notice generally, like a drai or outside intoa planter etc.
If your furnace is in the attic a secondary will terminate i a noticable area like above a bathroom sink or outside a window where you will see the water where it never was , signalling a need to assess the condensate lines primary functioning. All AC units will make condensate moisture and it alone isnt an issue .
Dec 24, 2010 | Heating & Cooling
Hi, I have a Carrier Weathermaster XS. I don't
If I am correct, that is a gas furnace, right? I believe it may be between 15 and 20 years. Pro-active with and older gas furnace is never a bad thing. First of all it can become a safety issue, as concerns of heat exchangers cracking and leaking carbon monoxide into the home become increasing. Second, it sure only be 80% efficient, whereas a new condensing furnace today can be up to 95% efficient. That means that you currently only use 80% of the gas you are burning as actual heat transferred into the house via airflow, and the other 20% is literally leaving the house through the flue. So you can increase efficiency dramatically and be safe at the same time by replacing pro-actively
Mar 09, 2010 | Heating & Cooling
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
Furnace won't turn on
Have you checked to see if the fan motor is getting hot. Sometimes a system will shut down if the fan motor is causing the reset fuse to break the circuit due to heat. If that is the problem just a replacement of the motor will usually fix the problem.
Feb 06, 2009 | Carrier 38CKC042 Air Conditioner
Central air conditoner unit doesnt blow cool air into home has some ice on the inlet heat and cooling lines going into the central air unit
Change the furnace filter. Make sure you use a cheap one when air conditioning, as the better ones restrict airflow when they filter out so much stuff and then plug up, not allowing enough air to pass over the cooling coil in the furnace's air plenum. Turn the A/C off for a few hours (with only the furnace fan on if possible) to melt the ice off the cooling unit inside the furnace.
Sep 01, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
95 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
