Question about Kenmore 24032\24036 Top Load Washer
Disassemble Washer I have a model 110 Kenmore top loading washer that I need totake apart to replace the mixing valve. What is the trick inoreder to take the top off to access this part on the back wall of the washer?
  • vbogle Jan 05, 2009
    it leaks in the back where the hot and cold water enters washer. How do we repair it?
  • 5,911 Answers
Here ya go. Follow the steps provided in this link:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
The mixing valve is also know as a "fill valve" or "water inlet valve", just for clarification. I hope these steps help you with completing your repairs. If you get confused along the way, or require additional assistance, please let me know.
Posted on Dec 22, 2008
Top loading Kenmore h e washer roars while spinning
kind of hard to solve without more info.but it could be unlevel find a level or borrow one and place on top of washer.make sure it reads between bubble on level.check both sides on top of washer.if you hear kind of grinding noises and shifts hard it could be transmission..
May 26, 2014 | Kenmore 24032\24036 Top Load Washer
Kenmore 110 model purchased in 1987
really? that's unusual...sounds like the mixing of the hot/cold water is not working. could be control panel, or the actual valves.
you particularly handy, or do you usually have someone do this sort of thing.
Apr 25, 2008 | Kenmore 93702 Top Load Stacked Washer /...
Kenmore Washer Model 110 Movers pulled the bottom apart. Do you have a schematic to reassemble?
First, see the Sears Parts Site for this washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11015862400/0582/0153200?sid=MMLxMerchandizexManualsModelx15862x11015862400
Then see the following for how to tear one apart, you should be able to see what's not in place from this:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=0da65cea0e338fe930b1fde153a243f0
Then see the Whirlpool / Kenmore Service manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Between the three sites / documents you should be able to put it back together.
Nov 21, 2010 | Kenmore 15864/15862 Top Load Washer
Replace mixing valve
If this is a Kenmore top loader such as the one pictured, you need to remove the exterior washer case in order to access the mixing valve. DO NOT attempt to remove the back pnel as these washers are not designed to have the back panel removed. The following link explains step-by-step how to access and replace the valve:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
I could not find an exact match for the model number you provided, but most Kenmore top loaders are configured the same regardless of features.
If you have any questions about this repair, or if your washer configuration is different from what I have described (i.e., if this is a Calypso, Cabrio or Oasis), please post back and let me know. I hope this helps you.
NOTE: Kenmore is manufactured by Whirlpool, so these instructions do apply.
Apr 02, 2010 | Kenmore 23822 Top Load Washer
Kenmore 110.27822790 Top Load Washer
Check screens on the mix valve, hoses removed. If there is no humming sound when cold is selected then the mix valve needs to be replaced
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 110 washer
if screens on both ends of cold fill hose are clean replaced valve have seen restricted flow even with good flow to valve but be sure screen in valve is pulled and cleaned be sure to reinstall it
Aug 01, 2008 | Kenmore 22422 Top Load Washer
Kenmore clothes washer top loading
get a big screwdriver and jst pop the out wont break spring steel just reamber haw they hook to the washer and just popem back in when done
Mar 30, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
1,294 people viewed this question
Sal De
fordexpert
Robert Rankin
