SOURCE: Refrigerator making loud noise and fan: help!
take raer panel off inside freezer and check there is no ice build up which is hitting the fan
SOURCE: HotPoint model HSS25GFTBB fridge warm freezer cold?
Friend,
ngfam1 At your service!
I came to your service on fixya.com some days ago!
And gave you some good advice!
But, I did not receive a rating from you yet!
Can you please give me a rating at our fixya.com site!
Bless, You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
SOURCE: Hotpiont side/side HSS251FMB not cooling
Compressor might be working but you may have lost some freon. Continued operation with low freon can lead to other problems. This may require a service call since recharging freon can only be done by a service professional.
SOURCE: freezer temp and fridge temp not as they should be
you should try and defrost the feezer completely as ice might be blocking the cold coming in. it happed to my fridge freezer and that cured it and it is working perfect now.
SOURCE: hotpoint csx22d side by side has leak under
This leak , is coming from the defrost drain , inside the freezer section , at the back . The defrost drain is clogged with ice . Remove the bottom freezer crisper , and use a hairdryer to defrost the ice . You will see a drain hole where the defrost water is supposed to drain thru . Hot water helps defrost this hole . Once defrosted , use a small hose inserted into the drain hole , to blow thru , to remove built up debris , inside the unseen drain line .
Testimonial: "thanks for help.....looked for drain for short time will go back & try again.....no drain pan throwing me off.....thanks again"
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
