Question about Sony KDF-E55A20 55 in. LCD Television
My t.v. picture goes on and off.
Could it be I need a new bulb for my sony
  • amp76 Dec 24, 2008
    My Sony KDF E55A20 is going off every minute or so (completely blak and no audio) then comes back on slowly after almost 30 seconds. I have had the TV for 3 and a half years with no problems. There are not lights blinking for me either. Anyone find out what the problem is yet?
  • desertcoast Dec 27, 2008
    Same problem, same unit and similar age.
    I am also not seeing any visual clue on the front panel to suggest a faulty bulb, as the manual suggests.
    The sound also goes away, which makes me question the bulb as the culprit ( why would the sound mute if the bulb is intermittent??)
Follow up: The audio/video blackouts were in fact a precursor to the bulb going bad ( even though no lights on front indicated such as the manual suggests). Replaced it, blackouts went away. Picture is noticeably brighter, so the bulb was showing signs that I didn't pick up on. If you're reasonalby handy, the lamp assembly is an easy fix for approx $200-$250 .
Posted on Jan 01, 2009
Yellow screen
my picture goes red shades and this means new bulb needed
sorry, but sounds like the same issue..... new bulb
I get hitachi with 3 year bulb warranty now for our school - cheaper in long run
Jan 22, 2013 | Philips Sony KDF55WF655 KDF55WF655 Lamp...
Picture on my sony kds 60a2000 tv goes out and then comes back on repeatedly, what could be wrong
you have to replace the bulb what happening is the life hours on the bulb is almost over just replace the bulb soon or later you will see a red flashing light sometimes that's indicating the bulb needs to be replaced
Jan 26, 2011 | Sony KDS-60A2000 60" HDTV
I have a sony tv model kdf-50e2000,and it has a problem with the picture going blank,the only light that on or flashes is the green (POWER) light. when turning the set on the green light blinks as it...
You tv used lamp XL-2400 or also known as F93087500. It is very common for this bulb to fail and have the exact symptom you are experiencing. I cant count how many times I have seen it.. Replace the lamp with either the exact Sony or an OEM and you will be back in business..
Good Luck!!
Dec 28, 2010 | Sony KDF-50E2000 50" HDTV
I have a Sony KP-48S35, Rear Projection TV and the picture goes on and off but the audio works fine. When I first turn the TV on, it takes around minutes for the picture to even come on.Which meens for...
i would say the bulb is on its way out and needs changing. on the back there is a hatch with one screw remove the screw and unclip the bulb holder, then pull out by the handle part number is on the bulb housing or the tv case.
May 23, 2017 | Sony KP-48S35 48" Rear Projection...
The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
easyab
Mar 14, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Picture flickers on Sony HDTV
Hi,It seems your ballast(board that powers light bulb) is going weak.The ballast was used to provide a lower voltage because lamp didn't use as much as brand new one. A newer one takes more voltage and when ballast doesn't provide as much power it will flicker or produce a dimmer image.I found the one for your tv here: http://www.discount-merchant.com/1091041-KDS-60A3000-p/1091041.htm?Click=48173 Good luck and God bless you!
Jan 06, 2010 | Sony KDS-60A3000 60" HDTV
Sony KDS-50A2000 - bulb replaced but picture still yellow
Hi,It sounds like a light engine problem Sony is having.Basically the light of the lamp goes through tunnels that have mirrors that direct the lamp to 3 main LCD chips,These 3 LCD chips are blue,green, and red they blend to create the image and colors.When they start to fail you'll get color discoloration like what you are getting.You will need to replace the optical block because unfortunately they don't sell the LCD chips by themselves.GOD BLESS YOU!
Oct 06, 2009 | Sony KDS-50A2000 50" HDTV
Tv goes off then red blinking light comes on
Hello it is the bulb the bulb's on the Rear projection tv are ****. Buy  new tv cause it costs alot to have these tv fixed.
Jan 10, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony KDF-E55A20 55 in. LCD Television Logo
103 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
