Question about Craftsman 2500 PSI Briggs & Stratton Powered Pressure Washer
Where are the filters located on the craftsman 2700 power washer
  • Craftsman Master
  • 885 Answers
The only filters on a pressure washer are: Where the hose hooks up to the pump there is sometimes a washer with a screen inside it. The syphon hose usually has a fine filter on the end that drops into the detergent. If this question is related to your other post see my answer there.
Posted on Aug 31, 2012
  • Tradesman Painting
    Tradesman Painting Aug 14, 2014
    yes that is right good answer.........
SOURCE:
Is the craftsman gas powered 2700 psi pressure washer to strong to wash cars and trucks?
yes -- it will remove any loose paint then keep going to take all the paint off
if used around the mechanical bits ,it has the pressure to blow in gaskets and force water into places that water would not normally get to
Oct 19, 2015 | Craftsman 2700 PSI,2.3 GPM Briggs &...
Motor runs but no pressure craftsman 2700 easy start
some filter is blocked up or the impeller is full or rubbish
motor runs so impeller should work
no preasure
something blocked hoxe kinken
start valve not actuating {check intake flow sensor}
Jun 04, 2015 | Craftsman Garden
Where is the choke on a Brigg-stration model 580-752920 engine?
This particular model is called a readystart engine, they do NOT have a primer or choke, if you are having fuel troubles starting there could be a blockage in the carburettor or fuel filter.
Hope this helps
Brad
Jul 28, 2014 | Craftsman 2700 PSI Briggs Stratton...
Cant find choke on craftsman 2700 2.3 ready start 7.75
If I remember correctly, there is not an operator actuated choke on that unit. It is thermostatically controlled be a device behind the muffler.
Aug 25, 2013 | Craftsman 2700 PSI,2.3 GPM Briggs &...
I cant start my power washer. the pull start is locked and wont release to start engine.
When the pull start gets locked, you have to release water pressure from the wand. I had the same problem last year.
Jun 16, 2013 | Craftsman 2700 PSI Briggs Stratton...
Engine lockup
Sounds like the intake or exhaust valve is not opening.
Jun 08, 2013 | Craftsman 2700 PSI Briggs Stratton...
I've got this white powder stuff in my fuel filter
its from using old fuel only use fresh gas 30days or newer
Aug 03, 2012 | Craftsman 2700 PSI,2.3 GPM Briggs &...
Started by Craftsman 2700 PSI , 2.3 GPM Briggs & Stratton Powered Pressure Washer for first time in 9 months. Added new oil, and gas. started but is smoking from muffler and is dripping what appears to...
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
May 09, 2011 | Craftsman 2700 PSI,2.3 GPM Briggs &...
Craftsman 2500 PSI Briggs & Stratton Powered Pressure Washer Logo
329 people viewed this question
Top Craftsman Garden Experts
john h
lnbn1975
Jay Finke
Jay Finke
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
