CPI Trouble Light will not Reset
I have a CPI alarm. Trouble light came on when backup battery went bad. Replaced backup battery with a new one from Batteries Plus, then pressed Reset to reset the panel, but the trouble light remains on. The alarm is monitored by CPI and the trouble indicator reported to me by them was low batt. So, they told me to replace the battery and I did. When I called them on the weekend to see it they were still getting a trouble they said everything looked good. Any ideas on how to get rid of the trouble light?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 141 Answers
Try to check the line if it is correctly installed to the proper area. maybe your battery doesnt have enough power to comply the proper amount of your system.
Posted on Jan 05, 2010
Car battery went flat an tried jump starting an didn't work put another battery in an now wont start an hazard light an all other lights are flashing
Battery went dead or replaced, it set the alarm. Some alarms can be reset with the key, some with a scanner, some at the dealer. Year, make , and model would be helpful.
Dec 21, 2014 | Cars & Trucks
Were is the starter relay in my cpi sm 50?
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and downloads that you will need please visit the websites below. Good luck and have nice a day.
http://www.apriliaforum.com/forums/showthread.php?243900-Cpi-50-sm-(Rs50-engine)-Starting-problem
http://www.garage24.se/Catalogs/CPI/Servicemanual/Verkstadsmanual%20CPI%20SX%20SM.pdf
CPI Scooter Parts Racing Planet USA
CPI SM Supermoto 2007
CPI SM 50 review and CBT
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 12, 2014 | 2006 Cpi Supermoto SM
No ignition
Hi, Futeballmom and the usual suspects are:
Startup Troubleshooting Starting Your Scooter 1 7
Fix Chinese 49cc Scooter that won start
CPI motorcycle manuals
CPI Oliver 50 2004
Jul 24, 2012 | 2005 Cpi Oliver 50
No voltage at coil CPI Aragon
Hi, Anonymous if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
TROUBLE SHOOTING
How to diagnose no spark situation on motorcycle
http://www.garage24.se/Catalogs/CPI/Servicemanual/Verkstads%20manual%20CPI%20Skoter.pdf
https://absolutelyscooters.net/Omanuals/CPI%20ARAGON%20125%20USER'S%20GUIDE.pdf
Mar 01, 2012 | Cpi BWs Naked Motorcycles
No spark cpi hussar
Hi, Malcom if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
No spark cpi hussar 2005 Cpi Hussar 50
My scooter has no spark how to fix gy6 chinese scooter 139qmb qmb139 50cc...
http://absolutelyscooters.net/service-manuals.html
Free CPI Motorcycle Service Manuals for download
Jan 07, 2012 | 2005 Cpi Hussar 50
Hello i have a 2006 cpi sm50 and it has a weak spark witch wont let the bike start. i put in a new startor coil and a new ngk indruim spark plug but none of them has helped the bike. Please could...
Hi, Andy1151 if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
http://www.apriliaforum.com/forums/showthread.php?157632-Electrical-problem-need-help-from-rs-experts
Need Help Trouble Starting CPI SM50
http://yournewfiles.ga/get~cpi-sm-50-user-guide.pdf
Jul 07, 2011 | 2006 Cpi Supermoto SM
Trouble indicator came on after a power outage and
When was the last time the backup battery was checked? The trouble indicator could mean a weak or non-working battery. If the system is 12 years old, the battery should be changed.
Mar 07, 2010 | Air Purifiers
All alarms go off; 1 of 6 alarms has a flashing green light
Your alarms are interconnected, meaning when one alarm goes off, they all go off. The alarm with the flashing green light is the one that triggered the alarm. If it only went off once, it was probably just fluke thing, and you can reset the alarm memory (flashing green light) by pressing the test button. If it happened more than once, you should try cleaning the alarm. Do this by removing the alarm, and blowing compressed air into the sensor opening (located around the back side perimeter of the alarm). If this fails, replace it.
Aug 09, 2009 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Computers & Internet Logo
179 people viewed this question
Alun Cox
David Payne
David Payne
