Question about SanDisk Sansa E280 MP3 Player
My fairly new (1 year old and rarely used ) Sansa 280 MP3 player just died. Tried to recharge by hooking it up to the computer but nothing happens, the computer doesn't even recognise that I have hooked anything up. Time to get a new MP3 Player?
  • steveaa Jan 02, 2009
    just happpens to me too
  • Anonymous Jan 04, 2009
    I have the same problem mine won't even turn on. but the light around the controlls is lit
Take the back off with eyeglass screwdriver; remove battery and reinstall
Posted on Jan 02, 2009
Sansa 280 MP3 player won't charge. When attempting to charge, it
This problem indicates that it is stuck from inside . You just keep on pressing menu option and keep on pressing the center button for 2 minutes it will solve your problem .
It actually worked for me that's why I am sharing this .
If you still have a problem let me know .
Hope this helps .
Do rate my solution .
Dec 04, 2009 | SanDisk Sansa e260 MP3 Player
Sansa clip mp3 player has problem with recharging. now dead.
I've had the same problem as you. It probably just doesn't work on that computer. Try plugging it into another one, see if it charges.
Mar 15, 2009 | SanDisk Sansa Clip MP3 Player
Sansa mp3 locks up
Make sure the hold/lock is not engaged.
Jan 08, 2009 | SanDisk Sansa Clip MP3 Player
My Sansa 280 is "not licensed"
I solved the problem myself.  Bought a new one and threw the old one in the trash.  Voila!
Jan 04, 2009 | SanDisk Sansa e250 MP3 Player
Sansa 280 died, tried to rechrg but is not recognized by computer
Make sure the hold/lock is not engaged first.
Here is a friendly tip posted from another user - let me know if it works:
ok so i called 1-866-sandisk and she told me how to fix it. you just flip the key lock at the top so you see orange, then hold down the record button. then you should get some sort of message on the screen. then you plug it in and under my computer a file should show up. you open it and make a folder in it called sansa.fwm (i think thats the right folder name, if not, try sansa.tmp or email me). then you unplug it and it should say formatting or something like that. once its done it should work.
Dec 22, 2008 | SanDisk Sansa E280 MP3 Player
Nothing happens when ON switch is pressed.
Have you tried recharging the MP3 player? I too have a Sansa Clip which I play in the car so I don't often see the "battery low' message, but when I recharge it the MP3 player works again. I understand it takes longer to recharge from the computer so I bought a recharger I plug into the wall.
Jul 11, 2008 | SanDisk Sansa Clip MP3 Player
Sansa sandisk mp3 player 1 gig
Theoretically, you should be able to use this one forever, if you keep charging it. The battery isn't replaceable, so hopefully it will last you a good 3 years or more. The #1 threat to Mp3 players isn't the battery, but keeping up with software/computer environment changes. Most mp3 players introduced to date only last 1-2 years - much shorter than everyone had originally thought.
Jun 10, 2008 | SanDisk Sansa Clip MP3 Player
Recharging battery
either you need a new battery an new power cord or a new mp3
May 08, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e280
Have you tried recharging the battery? If it is not showing when you connect it to your computer, try holding down the Menu/On-Off button for 15 - 30 seconds and see if it goes on.
If you need a new battery this is a good place to get one:
http://www.jr.com/JRProductPage.process?Product=4153711
Feb 04, 2008 | SanDisk Sansa E280 MP3 Player
FROZEN!!! PLEASE HELP!!!
DEFRAG IN MSC! Then check, then format.
Found here, worked for me:
search: format sansa c150
www.fixya.com/support/t137630-mtp_db_mismatch_format
Jul 02, 2007 | SanDisk Sansa c150 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
65 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
