Question about Toshiba 250GB TOSHIBA USB 2.0 PORTABLE EXTERNAL 25 250 GB Hard Drive
Response to your Suggestion re: transferring files to external hard drive
I really appreciate your response, however, you did not answer it in its entirety.
Can I edit the folders that I transferred to the external drive on the external drive or continue to edit them on the C drive? Then, I back them up correct?
The external drive I have, has an installed backup system. Is this prudent
to use that as my backup system or should I get the one you mentioned,
the EZbackup as well?
Thanks for your knowledgeable help, I do appreciate it.
    Scholar:
  • 73 Answers
This depends entirely on how the backup program you use works. Usually they will go with whichever file/folder has been edited most recently, so if you edit them on your backup drive, they will not be replaced by the ones on your C drive. It would probably be easier just to edit them on your C drive and let the backup program do all the transferring, though.
Also, if your drive comes with one, you should usually use it, and no, having two would be inadvisable because you would end up with two identical sets of your data on the same drive, which serves no logical purpose.
Hopefully that is a more exact answer!
Posted on Dec 22, 2008
Drive light is flashing. Drive barely works but is very, very slow. Managed to get two folders transferred but it;ll take days to transfer my music. I don't want to even think about my movies. Why...
my opinion is, better to backup your files while you can still access the drive. Then try to format your external drive.
Just a suggestion. Hope it helps thanks.
Sep 10, 2011 | Western Digital My Book Essential 1TB...
Sir, may request to your company to provide me a software that can i use for transferring of my files into external hard disc from laptop. Sreen appears "write protected" by when i used...
Theres two likely possibilities to this
1. if you are in a corporate environment, then the restricted machine may have a policy set to stop data being placed on an external device. in which case contact your administrator to allow access.
But most likely the restricted machine may be windows 7 and the unrestricted is not.
there is a policy in windows 7 that stops people from writing to the root of any hard disk.
to confirm that this is your problem, simply use the other machine to create a new directory by right clicking somewhere in the drives explorer folder and select NEW then FOLDER, call it TEST for example then take the portable drive across to the restricted machine, open the folder then try dragging your files into this folder.
should work
Mar 18, 2011 | Computers & Internet
No response freez making funny noise
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Is it an external drive?
If it is, open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
Lastly, if its not an external drive, the same applies because, its still all about hard drive.
I wish you all the best.
Jan 08, 2010 | LaCie F.A. Porsche (301177) Hard Drive
No response at all from laptop regarding my toughdrive 160GB
Your files are safe on the HDD, the trick to retrieve.
You should have backup at the end of your sessions
If you have the setup disc, reinsert and run!
Nov 13, 2009 | Freecom Portable II External DVD Drive
Unable to transfer files from an acomdata external hard drive.
Borrow a friends "hard drive docking station" and remove the hard drive from the other external drive and place in the docking station and see if you can read the drives contents. The docking stations can be purchased at Best Buy or Office Depot if you want your own. Your external drive could have a faulty power supply or you really could have a hard drive that has developed bad sectors and that is a disaster for your data. When a drive starts acting up, you really need to act and transfer important files to a new drive or burn the data to DVD's.
Apr 14, 2017 | Computers & Internet
Not much memory left in my powerbook
De-fragmentation does nothing to free up space. It only moves files that have been fragmented across scattered sectors into a file running across contiguous sectors. This speeds up disk read operations and is less stress/wear on the hard drive. To free up space... continue what you're doing. Move all non-essential files to an external drive and uninstall any programs that you don't really need.
If this answers your question and provides a solution to your problem then please take a moment to rate this post. - Thanks.
Jul 01, 2009 | Apple Mac OS X 10.4 Tiger for Mac
Seagate Ex-HD will not power up
check with your BIOS settings. Check with other system if it is worked sure there is problem with bios if not worked u must check with new power cord
Run CHKDSK, run it with both the option, I mean the 'automatically fix file system errors' and 'Scan and attempt to fix bad sectors'
click this link for more info
Thanks Good Luck
Appreciate to rate as "Fixya"
May 03, 2009 | Seagate USB 2.0 External Enclosure + 400GB...
Cannot transfer any files from my computer to my external hard
Did you install the drivers for the drive? Is it recognised in Windows as a device? If not, try reconnecting and Windows should prompt you to install the drivers, Assuming the drive is recognised by WIndows, then are a few causes for not transferring data. I've attached a link to Western Digital's FAQ regarding Data Transfer problems with your drive....
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_alp.php?p_sid=nCt181pj&p_accessibility=0&p_redirect=&p_lva=1017&p_li=&p_page=1&p_new_search=1&p_search_type=answers.search_nl&p_sort_by=&p_search_text=transferring+data
Several page of possible solutions are listed above.... however, you can refine the search if it is only happening when running specific apps or @ specific times. The answer you seek is located in this link. If you can provide more details on the type of file(s) you are trying to transfer and how, I'll refine the solution for you....
Jan 14, 2009 | Western Digital 250GB MyBook External USB...
Seagate FreeAgent Desk - "Drive cannot be modified"
I went into Disc Utility and partitioned the whole drive for Mac OSX. After that was done, I was able to write to the drive and copy over files.
Nov 29, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Help retrieving files from simpletech 320gb hard drive!
I have to admit I haven't used a Mac since high-school, but I can tell you that my first thought on this problem was "file system".
Most external HD's are formatted to be used on a Windows PC, and many are even formatted as NTFS. If this is the case, last I heard anyways, Mac OS doesn't support NTFS.
My suggestion is to use either machine to format the external HD (**you will lose all data on it**) as a neutral file system. By that I mean one which will work on both operating systems.
I could be wrong about this, and Mac OS may support NTFS, but if that's the case somone will be kind enough to correct me.
Mar 15, 2008 | Computers & Internet
Toshiba 250GB TOSHIBA USB 2.0 PORTABLE EXTERNAL 25 250 GB Hard Drive Logo
105 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
