Question about RIM BlackBerry? Curve 8330 Cellular Phone
Turned on and now no keys or side bottons work
Then the screen goes black and can not get it back unless i take out the battery
    Brigadier General:
  • 7,752 Answers
It wiuld be best if you took the phone to a mobile service center and have it looked at there.
Posted on Jan 01, 2009
HP Pavillion screen goes black when inactive for short time. Even when I fixed all of the power settings to never shut off or go into sleep mode. If I don't use it for 30 seconds then the screen...
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Dec 08, 2012 | Computers & Internet
Side lx won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 01, 2012 | T-Mobile Cell Phones
Hitachi 55VS69 screen goes black and there is no volume and it will not turn off unless unplugged.
The key here is you have to unplug it---it means the problem is related to the microprocessor which may become confused because of an issue elsewhere in the set---no real easy answer except it may be expensive to locate and fix.
Mar 19, 2012 | Televison & Video
Screen black or with lines/check
The camera has a system control board problem, this controls all the key operations of the camera. Unfortuneately cost to repair would not warrant the expence to persue the matter.
Mar 04, 2012 | Ricoh Caplio R6 Digital Camera
BLACK LINE WHEN TRY TO TURN ON TI-83 PLUS
it seems it have an internal problem of contact and you must get it repair, or consider buy a new one that model is a little old.
Oct 02, 2009 | Texas Instruments TI-83 Plus Calculator
My phone just shuts off randomly
you might need a new battery but just to make sure take it to your phone company store and they will give you lots of help
Jun 28, 2009 | AT&T LG CU515 Cell Phone - Black
Blank White Screen with Black Dot
you can have the phone reflash to correct this problem or just take it into your provider and have them look at it for you.
Dec 12, 2008 | LG RUMOR Cellular Phone
RIM BlackBerry? Curve 8330 Cellular Phone Logo
80 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
