Question about Pentax *ist DS Digital Camera
Battery Light Blinking
Batteries went flat on camera and light started blinking.Replaced with good HD Eveready as that was all that was available at time.Light still blinking and camera won't fire up. Replaced with Duracell Power Pix still nothing.Have used these before without any problems.Tested batteries and have 1.66v in each.Where to from here?
  • Chris Wood Apr 21, 2007
    Comment by Plughole.
    Have since got camera working for no apparent reason, but then batteries went totally flat in one day without any use
  • Anonymous May 29, 2008
    Yep.  Same problem.  If I take the batteries out and then put the same batteries back in, it starts up saying batteries full.   If I try to take a picture, it tells me batteries half, but won't fire.  Then it shuts down and says no batteries.  If I reload batteries, it will repeat the above.  Never had a camera last so little time before needing repair, and I've had dozens.
I had the same issue and that is why I found this forum. I tried lightly tapping the on off switch and it came back on. I had to reset the date and time, which indicatest that there may have been a short or total depletion, but all is good now.
I couldn't replicate the fault, which is a good thing. So perhaps some dirty contacts around the on-off.
Good luck
Posted on Jun 02, 2009
    Genius:
  • 2,985 Answers
You have a short circuit somewhere. it colud be the flash capacitor. But what ever it is its beyond the avarage guys scope to fix So into the the repair shop with it. Unless you have some warranty still left. Worth a talk to the Tech Support Team at Pentax
Posted on May 26, 2007
I bought a power adapter for the camera, but it doesn't seem to work without batteries in the unit. If I use the batteries alone, I will eventually get a red blinking light at the back of the camera,...
Because the camera is what is technically known as 'Portable'and is designed to work purely from the internal battery. the Power Adapter merely charges the internal battery
May 08, 2017 | Kodak EasyShare C330 Digital Camera
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
My battery is empty but if i plug it in to charge.. it keeps blinking orange and aint charging.. When i got this camera as a present it had the same problem.. bought a new battery.. problem fixed and even...
I have this same problem. I went onto the Samsung website troubleshooting and it says that if there is an orange blinking light then the charging cable is damaged and needs to be replaced. Hope this helps!
Feb 19, 2011 | Samsung L100 Digital Camera
I go to charge the battery and it looks like it charges for a while then the charger red light starts blinking. I put the battery back in the camera and the battery is still flat. Not sure what's wrong?...
The blinking light on the charger indicates that the battery needs to be replaced and will not charge. You can buy a replacement lithium battery online at sites like Amazon for less than $10.
Nov 18, 2010 | Olympus Stylus 820 Digital Camera
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
When I placed my Lithium Ion Battery in the charger it doesn't carge the batter and the red light that's supposed to stay lit while it's charging keeps on blinking on and off.
How old is the battery?
It's very possible that the blinking light is indicating a bad/old battery. These rechargeable batteries after so many cycles lose it's charging capability and the fault system built into the recharging base will indicate by giving you the red light on & off. Energizer rechargeable station is a good example when it detects old or bad batteries.
Nov 08, 2009 | Casio Exilim EX-Z57 Digital Camera
Red blinking light
same problem, red blinking light in series of 5 flashes
May 30, 2009 | Pioneer PureVision Pro-1000HD 50 in....
Red light blinking three times in a row
Service manual says 3 flashing red leds = eeprom error (main digital / video pcb).
Suggest you start by implementation of Fujitsu Service Bulletin PDP 0068-01 Main Digital pcb see:-ttp://www.eserviceinfo.com/download.php?fileid=43450
Mar 31, 2009 | Fujitsu Plasmavision P42HHA10 42 in....
Why does the charging light blink sometimes when there are no batteries in the camera?
Some models of camera have an ultra capacitor in them to extend battery life. This ultra capacitor is indistinguishable from a battery to the camera electronics. If the charging light starts blinking when there are no batteries in the camera, it will not cause any damage. After a few minutes, the light will stop blinking.
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Pentax *ist DS Digital Camera Logo
139 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
