Blue and red uniform streaks on each page-Ricoh Aficio CL4000DN
The streaks are mostly on each side--not in the very middle. I replaced the cyan color toner--didn't affect it.
It gives me no message as it should if it is the photoconductor--but do you think that is what it is??
If so, where do I get the best price??
Thanks.
lplummer@shawnee.edu
SOURCE: Color Streaks down length of page
This is a laser printer, neither a copier nor a multifunction unit, therefore it has no glass. At least, I cannot find any glass in it.
I finally had an authorized Ricoh repair center examine it and found streaks on the black unit that pulls out of the right side (I forget the part's name, <$90). We replaced it and things are better but streaks of color remain. They suggested replacing the color one (about $400) but the cost is prohibitive right now, so I'll live with those streaks.
On a related note, I remain unimpressed with this printer's quality and inconsistency. For example, greys often print in pink; nothing has ever resolved this. I refuse to put any more money into it. When I can afford to do so, it will be replaced, probably by a Xerox Phaser.
Posted on Feb 28, 2008
  • 22 Answers
SOURCE: My printer will only print from bypass tray. Why?
It may be something to do with the paper size settings on printer driver, document print settings or page setup. If for example the computer thinks the paper size is Letter, and the paper in Tray 1/2/3 is A4, it won't print.
Posted on Jan 24, 2009
  • 161 Answers
SOURCE: SC 366 on CL4000DN
cyan problem --check if cyan pcu is set properly or replace cuan pcu(drum)
Posted on May 06, 2009
  • 400 Answers
SOURCE: Ricoh aficio 1515mf photoconductor reset
Found some information here:
http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
Try the following
press the yellow “C” button
enter 107
press the red “C” button and keep it hold till the display changes
turn the power off with the big red switch on the front side
turn power on again.
OR
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
Posted on Jun 01, 2009
  • 990 Answers
SOURCE: Installing PCU on Ricoh Aficio MP2510.
Hello sir; The procedure little bit difficult, Remove PCU, remove the front cover(two screws), remove the rear bushing by remove one lock ring, remove the front joint, remove the developer hopper cover( 3 hook ) dump the old one out vacuum entire unit ( magnet roller ), fill in new developer, replace hopper cover, after replace PCU and developer you need to do some simulation, #1, press "clear mode" "107" and press hold "clear/stop" for 3 seconds, then touch screen on "copier sp". #2, enter sp3902-9 to1 for black drum unit, sp 3902-10 to 1 for yellow, sp3902-11 to 1 for cyan, sp3902-12 to 1 for magenta, #3, enter 3902-005 for black, 3902-006 for yellow, 3902-007 for cyan, 3902-008 for magenta, set 3902 to 1 for each of these if replaceing developer, press "exit" twice to end the service.
Posted on Sep 18, 2009
Ricoh Aficio 3800C: How do you clean the Development Unit Hello, I have a Ricoh Aficio 3800C. I noticed that there are faint Cyan streaks when I print. I opened up the printer/copier unit and looked at...
I believe what you are referring to is the drum inside the toner cartridge. The drums are usually very strong colors, blue or green and if it is streaking then the drum cleaning blade has failed on the inside and you need to replace the cartridge.
Feb 14, 2011 | Ricoh Aficio AP3800C Laser Printer
Blue dotted line of right side of paper
Sounds like the cyan photoconductor unit needs to be replaced. Usually what ever the color dot is that photoconductor has a pinhole in it and the only to get rid of it is to replace it.
Apr 06, 2010 | Ricoh Aficio SP C411DN Laser Printer
CL7000 2mm Black Streak on Back Side of Paper
Hello sir; There have a cleaning unit on the transfer belt, replace the cleaning unit should take care the problem.
May 05, 2009 | Ricoh Aficio CL7000 Laser Printer
SC366 on CL4000DN
I just came across this post, you've likely solved it by now; However it is a "Toner density" error related to your cyan photoconductor. It is a defective connector. Replacing the cyan photoconductor should solve problem.
Feb 05, 2009 | Ricoh CL4000DN Laser Printer
SC 366 on CL4000DN
Black smudgy streak in middle of printed page
if you need any parts for that machine a have 4of them
Thank You,
Mikey
Feb 26, 2008 | Ricoh Aficio AP3800C Laser Printer
My rep advised that if this problem is occuring when using the feeder, the small glass strip to the left of the glass can have some sort of either high lighter or white out stuck to it. He suggests cleaning this with some alcohol.
Jan 09, 2008 | Ricoh Aficio CL2000N Laser Printer
264 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
