Question about HP PhotoSmart C4480 All-in-One Printer InkJet
My c4480 printer will not turn on. I checked the connection on back of the printer. I used different A/C outlets.
  • 827 Answers
Try the following solutions if there are no light indications, no noise, and no movement from the printer when you turn it on.
Solution 1: Make sure you use the power cord that came with the product
Solution:
• Make sure the power cord is firmly connected to both the product and the power adapter.
Plug the power cord into a power outlet, surge protector, or power strip.
• If you are using a power strip, make sure the power strip is turned on. Or, try plugging the
product directly into a power outlet.
• Test the power outlet to make sure it is working. Plug in an appliance that you know works,
and see if the appliance has power. If not, then there might be a problem with the power
outlet.
• If you plugged the product into a switched outlet, make sure the outlet is switched on. If it
is switched to on but still does not work, then there might be a problem with the power outlet.
Cause: The product was not being used with the power cord provided.
If this did not solve the issue, try the next solution.
Solution 2: Reset the product
Solution: Turn off the product, and then unplug the power cord. Plug the power cord back in,
and then press the On button to turn on the product.
Cause: The product experienced an error.
Solution 3: Press the On button more slowly
Solution: The product might not respond if you press the On button too quickly. Press the
On button once. It might take a few minutes for the product to turn on. If you press the On button
again during this time, you might turn the product off.
Cause: You pressed the On button too quickly.
Solution 4: Contact HP to replace the power supply
Solution: Contact HP support to request a power supply for the product.
Go to: www.hp.com/support.
If prompted, choose your country/region, and then click Contact HP for information on calling
for technical support.
Cause: The power supply was not intended for use with this product or it had a mechanical
failure.
Solution 5: Contact HP support for service
Solution: If you have completed all of the steps provided in the previous solutions and are still
having a problem, contact HP support for service.
If prompted, choose your country/region, and then click Contact HP for technical support.
Cause: You might need assistance to enable the product or software to function properly.
Good Luck
Chris (ziraffa)
PS Have you changed the fuse in the plug? Just a thought..
Posted on Dec 22, 2008
Keeps rebooting
Hi, Please check if it is connected to a wall outlet or to a surge protector...If it is connected to a surge protector then connect it to a wall outlet.....
- If it is working then fine....If not then remove all the cartridges...disconnect the power chord from back of the printer and then from wall outlet......wait for 40 seconds then connect the power chord to wall outlet first and then to the back of the printer....
- If working fine then ok or else check adapter is warming or not......and check with different wall outlet and with different power supply....
- Now do the following re-sets :
A) Disconnect the power chord from the back of the printer
B) Press and hold # and 6
C) While holding these keys connect the power chord to the back of the printer and when you see that printer is warming up then release the keys.....
Or else replace the printer.
And also some of the electrical components used to build the logic board in the Cxxxx all in one printers about 2-3 years ago is failing. In my C6180 (with the same problem), there were 4 capacitors (see green cylinder shaped component in the attached - the bulge in the top indicates failure, and that this is the likely the cause) that I replaced (cost was about 60 cents!). If you are not comfortable doing some soldering yourself, you will have to find some help - it took me about 25 min to do the repair myself. Printer works great now.
Hope it helps..
Thanks for using fixya....
Oct 25, 2010 | HP Photosmart C5180 All-In-One InkJet...
Just replaced the ink cartridges. Printer keeps telling me to turn it off then on. However, it fails every time I turn it on again.
With the power cord connected and the unit on, disconnect your data cable(s) from the printer (USB, parallel). Press the power button to turn off the unit; wait 15 seconds and then turn the power on again.
Check if the error comes back. If it doesn't, reconnect your data cable(s) one at a time, checking for the error message between adding each connection. If you see the error, replace that cable.
If the error did come back after cycling the power when no data cables were connected, you have to look at your power cable. If the cable has a power module (box that you plug another cord into), make sure that you have the correct one for the printer.
In either case, unplug the power cord from the back of the printer (first) and unplug it from any surge protector or power strip (second). If you have a power module, unplug the cord from that and reconnect. Wait 30 seconds. Plug the cord directly into the wall outlet and then into the back of the printer. Then turn on the printer.
Check for issues. If the printer turns on, you may have overloaded the power strip. If it doesn't turn on, you should check the outlet for problems. Try using an outlet in a different room (preferably a different circuit breaker). (Move the printer and its power cord.) If the printer still doesn't work, replace the power cord or module.
If none of the above works, the printer needs service.
I hope this helps.
Aug 02, 2010 | HP Photosmart C6180 All-In-One InkJet...
My display screen is rolling and nothing stops it. My computer says the printer is offline.
Try doing this procedure to correct the problem.
1. Unplug the power cord from the back of the product.
2. Unplug the power cord from any surge protectors or power strips.
3. Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4. Plug the power cord into the back of the product.
5. Plug the power cord into the wall outlet.
6. Press the Power button to turn the product on.
7.Now check if its already working.
May 16, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
My hp photosmart c4480 is printing in horrible color, redish tint and hazy. i just installed brand new color and black ink and can't get my pictures to print right. Help!!!!
Hello Friend,
First of all please check for correct drivers for printer.
Secondally : Please draw three different - different color boxes in word and print them on you printer and find out which one color is missing. Example as follows.
Apr 06, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
My HP Photosmart C4480 was working fine last time I used it, but now the mini-display isn't lighting up, the power light is blinking on and off, and my laptop says the printer is "offline". What do I do?
HP photosmart C4480 power on but screen blank and nothing flashing - keeps asking to connect usb cable, this has been checked and new cable tried but still not working
Sep 22, 2009 | HP Photosmart C4480 All-In-One InkJet...
R800 won't turn on
1. make sure all power cables are securely connected.
2. check connection to pc from printer.
3. Plug the printer into different outlet (one can go out while others still operate normally, it happens!.....even on a surge protector!)
Apr 19, 2009 | Epson Stylus Photo R800 InkJet Printer
Jammed carriage cradle
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Nov 29, 2008 | HP PhotoSmart C4480 All-in-One Printer ...
My hp c4480 printer has a jammed carriage cradle. how do you fix it?  thanks
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Printer doesn't turn's on
Per Canon:
Solution: Disconnect and Reconnect AC power adapter or power cord to the device and electrical source
Secure all Power Connections
  • Disconnect the AC Power Adapter or power cord from both the device and the electrical source.
  • Then reconnect it.
  • If you are still unable to obtain power to the device, try another power outlet.
  • If possible, try connecting power directly to a wall outlet (as opposed to using a surge protector or power strip...just as a troubleshooting measure).
If this does not work, have you tried a different outlet to ensure that the outlet isn't the issue? Also, when you press the POWER button, does the printer respond at all, or is it basically dead?
Please post back if you need further help, otherwise, thank you for using and rating FixYa!
May 24, 2008 | Canon PIXMA iP1600 Printer
HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
1,010 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
