What does the code 5100 mean on a mp450 cannon
I have reinstalled the drivers taken the cartridges out 3 times and reinstalled both of them I can't do a print head alignment copy scan or do anything with the printer. Cant find cannon support for this printer on the web What sould I do
  • 126 Answers
I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Jan 07, 2009
What is error message 5100 for this printer?
Code 5100 refers to a carriage that is not freely moving from side to side. Look to the far left and right for anything that would impede the carriage path.
Also, it is possible that the clear plastic encoder strip just behind the carriage path has become smudged with (most often) grease. You can clean the strip with a cotton swab dibbed in alcohol.
I hope this helps!
Mar 27, 2010 | Canon Pixma MP450 All-In-One InkJet...
Error 5100 on MP450
It sounds like the fine cartridge movement is being restricted.
Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
Oct 18, 2009 | Canon Pixma MP450 All-In-One InkJet...
Low ink lamp staying on cannon mp190
The Canon rep told you the correct information. The printer companies have included circuits on their cartridges that will not allow you to refill them. The printer reads the code and knows that the cartridge already ran out of ink. To date no one has figured out a hack for this issue.
Aug 10, 2009 | Office Equipment & Supplies
I have a PIXMA MP450 printer and error code 5100 displays on the LCD. What do I need to do?
error code 5100 means it cannot recognize the follwing UO51 cartridge.
A lot of the time the cartridges need to be re-set. for this :--
Remove both cartridges, turn off the printer for a few seconds. Then, restart your printer and wait for it to warm-up. When it's finished warming up and you see the error code for missing ink cartridges, open the printer and insert both of them and close the printer.
That might take care of it because the restarting of your printer, "fakes it out" every once in a while.
Hope this helps.
thanks for using FixYa
Feb 02, 2009 | Canon Pixma MP450 All-In-One InkJet...
I have a cannon mp450 printer.  The printer tonner need changing. I have now changed the tonners, the result is when i go to print I get error message 5100 and the paper gets stuck and eaten
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Canon Pixma MP450 All-In-One InkJet...
Canon PIXMA MP450 "Servic Error 5100"
Try this... it worked on my MP450... Turn the printer on and open the lid, it shows the cartridges. Now let the cartridges settle to the left. You can notice that the cartridges run on a metal belt. It might be dirty, mine showed a black stripe on it. Take a cloth, a cleenex will be fine and clean it up. Move the cartridges to the right (force them with your hand) and clean the part of the belt left behind them. Now turn it off, close it up and turn it back on. It should work
Apr 02, 2008 | Canon Pixma MP450 All-In-One InkJet...
Error 5100
Dear Scub,
Did you hear a loud crunching sound from the printer before the error code 5100 was displayed?
1. You may need to send in the unit for service. Some Cannon Service offer temporary replacement unit while working on yours.
Checking and do-it-yourself inkjet printer repair is messy.
2. You can try check if the print head assembly (carriage) moves freely from left to right. Lubricate/clean if necessary (If your printer has one) check also the **** strip at the back of the carriage. This is a plastic film with multiple dark notch like mark. Clean with cotton swab and light solvent or isoprophyl alcohol.
If these does not solve your problem, guess your back to # 1.
Cheerup And Be Happy always
Mar 25, 2008 | Canon Pixma MP450 All-In-One InkJet...
Error 5100
Have you taken the printer apart? as the issue I had with our spare printer was that the home mechanics around here had taken ours apart for some reason and had not put the paper roller pin back in correctly. it was sticking out preventing the ink tank holder from moving.
Dec 26, 2007 | Canon Pixma MP450 All-In-One InkJet...
