Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Water leaking from bottom of refrigerator
How do I fix?
  • geneoj54 Dec 24, 2008
    I have the same problem! It doesn't seem to be the plastis tubing to the fridge but when ever I get water from the front of the fridge I notice in a few minutes some water will appear in the floor.
Thanks to all who spent money or shared their experience to have somebody do this repair, and I really mean it.
I have a Whirlpool TopLoad Fridge (not a side by side).
Things you'll need
30 minutes
Small socket for cardboard panel on lower back and panel inside freezer
Bicycle Pump
4 Towels
Hair Dryer
1. Take everything out of freezer
2. Turn dials off in fridge for both compartments
3. Pull fridge out so you can get behind it and unplug it
4. Be vigilant of ice maker line if installed
5. Pull cardboard panel off on back
On the left side you should see the back of the skinny drip pan and a small line. That line goes from the freezer and is most likely clogged.
6. Blow dry the back of the freezer enough so the ice is thawed at the bottom of the back panel.
7. Remove the two screws on the back panel. You may just be able to pull it toward you enough to get behind it. You'll see the coils and fan, and underneath these you may see some ice sheets and there should be a hole. That is the drain line that is clogged. I heated up some water and poured it over the drain to thaw the line. You may want to remove the crisper drawers and put some towels down there to catch the overflow. Once the ice is thawed enough at the drain. Go to the back of the fridge and place the end of the bicycle pump at the bottom of the drain hose. Apply pressure to get a good seal but keep pumping. You may have to go back and forth between pumping and thawing, but you'll know it is clear when you hear air going into the freezer and then the wonderful moment when water drips into the drip pan as advertised!
Keep those fridges less full so that the door stays sealed and keep the seal clean and also keep your doors from having too much stuff so the weight of the door doesn't pull away.
Okay, put it back together, turn everything on and be careful of your cord and lines when pushing the fridge back. Thank the Lord ours has wheels and man,was it cruddy underneath. Vacuum those coils underneath the fridge too for proper air circulation.
Blessings to you!
tay
Posted on Jan 11, 2009
Why does my samsung fridge leak water under the fridge when I use my water dispensor?
hi Todd.
Problem: It's leaking water. ... Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leakingout of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself - CNET
https://www.cnet.com/.../three-common-refrigerator-problems-you-can-easily-fix-yourse...
Why is my refrigerator leaking water from the bottom?If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013SOLVED: Water leak in refrigerator? - Refrigerator - iFixithttps://www.ifixit.com/Answers/View/128713/Water+leak+in+refrigeratorSearch for: Why is my refrigerator leaking water from the bottom?
Why does samsung fridge leak water under the fridge Google Search
Nov 27, 2017 | Samsung Refrigerators
Why is water leaking at the bottom in front refigerators
Water leaking in the freezer and on the floor in the front of your refrigerator usually is caused by a blocked evaporator drain line.
Hope the video helps you understand what you will need to do to fix the problem.
Appliance 911 Sea Breeze
Leaking Refrigerators
Sep 29, 2015 | LG LRFD22850 Bottom Freezer Refrigerator...
Water leaks at bottom of fridge
The same thing happened to me then I noticed ice had formed at the bottom of our fridge. It was covering a drain hole so water was leaking out the front of fridge instead of going to the drain pan or wherever the hole goes. After I chipped out the ice and cleared the hole with warm water the leak stopped. I also fixed another leak coming from bottom of fridge caused by a loose brass connection on water line going to the door.
May 25, 2014 | Hotpoint HSS25GFP Side by Side...
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Jun 04, 2017 | Samsung RF217ACPN - 20 cu. ft. French Door...
Water leaking from the bottom
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 16, 2009 | Refrigerators
Leaking freezer
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction. Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says ?energy saver? or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved. please do not forget to rate the solution.thanks.
Jun 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking at bottom of freezer side
that is not a leakage it might be sweating of the chilled line. and to collect this water there will be a tray fixed below the freeser or refrigerator exactly on the condensor so check this tray is in its place.
May 28, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
194 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
