Bad starter i have a 1991 bmw 735il series and the starter is bad what is the best way to start to fix from the top or bottom. what should you move to make it easy to get to for removal?
Yes, you can change it yourself. Just go to a Junkyard and get another one off another BMW of the same model or you could go to the BMW Dealer and order a new one. You should be able to change it with basic hand tools, Before you diconnect anything associated with the Fuel System, make sure you relieve the pressure in the fuel system first, by unscrewing the gas cap and leaving the cap loose.
You need a mother board for your cluster.I would try picknpull. The mother board is the black box on the very bottom of the cluster.pull it out and replace it with a good one.Be sure to reset your odometer for correct mileage.
your level is to low the coolent sensor can't read steam so it turns on the light... or your sensor is bad
or you have a short in the pigtail to the sensor
the motors are located behind the dash in what is called the IHKA unit. The most likely cause of this problem, however, is a bad temperature sensor. These are located in the center console behind the dash. To get to them you must remove the carpeted 'kick panels' on both the drivers and passengers side which cover the transmission tunnel. There is one for each side.
the carrier bearing needs replacing you can't fix it you can get the replacement at a drivetrain componants store in your area make sure you take the drive shaft and bear with you so they can match it properly. please rate this............thanks
That is correct...How to correct it will take some disassembly if you can follow instructions and sorta good with tools and have some nerve then get a Bently Service Manual on your BMW... It will be the best 100.00 you spend on the car, If you are frugal then look for a used copy on E-Bay.....
