Question about EnGenius EOC-3220 (EOC3220)
My senao eoc-3220 is showing SSID as 802.11g-SSID. But it does not acquire an IP automatically. I tried using defaults but that does not work either. Trying factory reset does not work because the "#" prompt does not appear in hyperterminal despite waiting long. please help
Hi
I had the same problem. This may be as simple as pressing the enter button on your computer keyboard after all the activity stops. This brought up the number sign for me after which everything else in the reset procedure worked fine.
Posted on Jan 22, 2009
My Seneo 3220 has changed its mac and gone to Realtek,can not log on to it any more,think its lost Engenius software. nigel 2205
I have no idea what it means for a Senao to "go to Realtek."
Here is the factory reset procedure for the Senao EOC-3220:
An RS-232 null modem serial cable is required for this procedure.
1. Connect the EOC-3220 to your computer with a null modem serial cable.
2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3220.
b. Select correct COM port. Ex:COM1.
c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
Oct 25, 2010 | EnGenius EOC-3220 (EOC3220)
How do i reset my engenius senao eoc 3220 outdoor radio
back side one reset button is there pull out the power cable then pull in that same time you have to press the reset button for three to five sec then all lied's blink all to gather then your default ip address is came then you again configure at default ip
Apr 15, 2009 | EnGenius EOC-3220 (EOC3220)
Problem resetting senao 3220
It all depends how your cable is wired. I had to add a null modem adapter and a gender changer to the USB-to-serial cable I bought for this task before I could communicate with the radio. I suggest you try the null modem to see if that is your issue.
Dec 22, 2008 | EnGenius EOC-3220 (EOC3220)
Senao 3220 - access configuration info
I do not know what you have for a DHCP server but some DHCP servers will show you what devices have been given IP addresses which you can use that information to find what address it is at now. Other than that you can use the guess and check method just going through IP addresses until the page comes up, you can use network mapping software to scan your network to find it or you can reset the access point to factory defaults where it will have the default IP address that you can then connect to and re configure it the way you want it.
Jul 06, 2008 | Computers & Internet
EOC-3220ext Loosing its wired connection with lan
Try to Flush DNS Cache
ipconfig /flushDNS
Also
May 08, 2008 | EnGenius EOC-3220 (EOC3220)
SENAO EOC 3220 CONNECTIVITY PROBLEM
hello!
-- try to change wireless channel on your access point
-- try to enable wireless security on your wireless network
-- try to assign static ip address on your wireless computer
Apr 26, 2008 | EnGenius EOC-3220 (EOC3220)
Resetting the senao eoc-3220 long range wireless access point/bridge
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
Feb 21, 2008 | EnGenius EOC-3220 (EOC3220)
I made firmware 1.39 to SENAO ECO3220
hey maick, I have the same proble, but I fix it, try this: 192.168.1.254, for me work fine, after that I reload the new firmware. now is working fine. good luck, jose luis Ogawa
Jan 19, 2008 | EnGenius EOC-3220 (EOC3220)
Needs reset
Don't use Engenius...there tech support is terrible and that is very mildly put....I don't use them anymore.....
Nov 30, 2007 | EnGenius EOC-3220 (EOC3220)
AP Mode Problems
Probably you have to learn that there are various people looking for an access of the internet through your facilities. Anyway, inorder to solve your problem these are the following recommendation I made just for you. Hope this will be helpful.
PHASE I
1.) How do I reset the EOC-3220 / EOC-3220 EXT / EOC-3220+ back to factory default settings? An RS-232 null modem serial cable is required for this procedure.
(where to buy it : http://www.keenansystems.com/store/catalog/product_info.php?cPath=3&products_id=221)
c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press “OK” to bring up the HyperTerminal window.
Phase II
1.) Since that you already reseted the AP you need to use the default IP which is 192.168.1.1 user: admin password: admin
2.) Make it sure you need to use different IP such as 72.10.251.xxx and the subnet: 255.255.255.xxx
3.) The idea of configuration in come from your own desire which was no body can no longer try to match your network IP so that there will be no body access your AP anymore without your knowledge.
4.) You need to make you SSID invisible to everyone inorder no body no longer able to reach your SSID by setting up basic setting which is transparent to everyone.
5) And lastly change the default user and password of your AP.
Good Luck
Nov 24, 2007 | EnGenius EOC-3220 (EOC3220)
EnGenius EOC-3220 (EOC3220) Logo
350 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
jgbyers1
Level 1 Expert
Tech support
Tech support
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
