Cannot scan to FTP folder
I'm using Bizhub c 203, last friday I just couldn't use scanner.
I get errors, even if I didn't get error, the file is not in the folder.
What I can do?
  • 6 Answers
SOURCE: Konica Minolta 250 Bizhub scanning Operations
what u need to scan to emails is the email smtp ip address.
just put the ip smtp address in the network setting>smtp address
and try to ping from ur B250, if the result is OK, then u have the connection. go to Utility/Counter>user setting>one touch to register
the user address, then scan it, u should be getting the scanned file in ur inbox.
Posted on Aug 09, 2008
  • 24 Answers
SOURCE: Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
Posted on Jun 25, 2009
herminio_hal
  • 210 Answers
SOURCE: How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
Posted on Jul 09, 2009
DocuSystems
  • 10 Answers
SOURCE: job has been done improperly check log files
The first thing to try is to restart the Bizhub. Power switch for that is located behind the front panel where the toner cartidges are. Not the switch to the side of the operation panel.
If that doesn't work, you need to check the job history. Press details, there will be a description of the error.
Server Connect Error: The Bizhub cannot find your computer.
Things to check:
Firewall, ports that need to be open are TCP 139, 445, UDP 137, 138
Netbois resolution not working, try using your PC's IP address instead.
If using Host Name to resolve, try Host name in uppercase.
Folder Not Found:
Check to make sure you are using the correct share name. Not necessarily would be sd.
Login error:
Need to use a Username/Password which is an active account which has priveledge for the shared directory. If on a domain, use a domain authentication string for the username (username@domain.com) If on a workgroup, \\COMPUTERNAME\Username If your password rotates every 60-90 days, could be that all you need to do is update the Bizhub with that information.
Posted on Aug 05, 2009
Kevin Hayes
  • 167 Answers
SOURCE: Adding user to scan to FTP bizhub C350
You ned to check the appropriate window based on the first letter of the button.
If you want in on the first screen, you need to indicate to add the button to your "favorites". Otherwise it appears under the alphbetical listing.
Posted on Feb 16, 2010
Can I download a driver to scan docs to rft on HP Deskjet 2544 printer
To scan to Rich Text you will need to have a program that can conduct an Optical Character Recognition (OCR) conversion of your scanners output.
HP Deskjet 2544 All-in-One Printer does not come with OCR included. You can install the OCR using the below link:
1) Open below link and save the OCR software to downloads folder:
ftp://ftp.hp.com/pub/printers/ocragent/hpcom_OCR_140_003.exe
2) Run the file after the download is complete.
3) If there's an error "This update does not support any of the HP device......", do not close the message. This is very important. You'll need to extract the OCR software from the temp install folder.
4) Open your temp folder (usually C:\Users\<username>\AppData\Local\Temp)
5) Open 7z folder
6) Copy folder "ocr_web_pack" to downloads or desktop.
7) Now you can Click OK to close the error message.
8) Open "ocr_web_pack" folder which is copied to desktop and double click the "SETUP.EXE" file.
9) Follow the prompts to install the OCR software.
Enjoy!
http://tinyurl.com/mg28nc3
Jan 22, 2015 | HP Deskjet 2544 Wireless All-in-One...
Code 61
is it a network error code.
Could mean FTP TX interruption or SMTP connection rejection
check ftp settings are correct
http://www.manualslib.com/manual/421595/Konica-Minolta-Bizhub-223.html?page=63
Could mean smtp problem check settings
http://www.manualslib.com/manual/421595/Konica-Minolta-Bizhub-223.html?page=216
Apr 21, 2014 | Konica Minolta Office Equipment & Supplies
No specified folder error
when setting up scanning to smb check the file path you are sending the document to. it is easier to store the folder on the c:\ drive under scans. Also ensure you have the correct username and password for the pc that has the file stored on it and set the NTLM setting to accept v1/v2.
Jan 10, 2013 | Konica Minolta Bizhub C224 Color Copier...
While scaning to a folder(using FTP scan option) it showing a send error
Hi
It is either cable connection problem. Unplug and plug it back all the cable connections.
Or the scanner driver might be corrupted, try to uninstall and re add again the scanner driver in the scanner wizard option.
Regards
Jul 01, 2011 | Kyocera FS-1118MFP Laser Printer
We have a Konica Minolta Bizhub 250 at the office and I want to use it as a scanner...I connected the printer to my laptop using a USB cable but it doesnt send the scanned files to my PC. I'm not really...
First of all, bizhub 250/350 is not a single pc scanner.you cannot use it as a scanner by connecting usb cable with it.its a network scanner.so to use it as a network scanner, you have to do these main steps........
1-assign a free ip address to the machine.
2-ping it from the system to check the connection between machine and computer.
3-now, make a scanner one touch account on the machine.
4-enter computer's ip address in the destination option.
5-create a folder on the desktop of your computer and share it.give it full rights.
6-turn the firewall off.
7-enter the folder name which you have made, in the machine.
8-enter user name and password of your computer in machine.i mean while making scanner one touch account.
9-now place the original on glass and scan it........
Aug 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Error code 016 781
The 016-783 error message indicates that “Cause – Could not find the specified server path during file”.
The folder that the Xerox scanner job template uses to deposit the scans in had previously been deleted, so I had recreated the shared network folder. What I had neglected to do though was to recreate the sub-folders that the Xerox Job Templates use for the scans.
After recreating the subfolders that the file repository setup referenced in the job template I had no more error codes with that scanning job template.
Jul 01, 2010 | Xerox WorkCentre M-24 Color Copier
Can't download iTunes, IE 8, HP Printer...Fatal Error MSI Scan is the usual statement, although I've gotten numbered failures too. But Fatal Error is the main one.
Hey
The SCAN.MSI that comes up about your HP printer, that is located on the CD in a special folder.
It would be best for you to completely uninstall all HP programs from the computer related to the printer.
http://www.revouninstaller.com/revo_uninstaller_free_download.html
unplug the printer first
use the free(ware) version. Download the program, start it, go to the uninstall programs part, find the HP related items and uninstall, Use medium setting and delete all files and items it finds, just click on select all and then delete.
When that is done restart the computer, then use the CD or I'll direct you to the full feature download to reinstall it.
I've delt with this scan.msi issue quite a few times here and I know how to solve it. If this doesn't work for whatever reason you would have to go to the cd (right click, open) and find the scan.msi file, when the error comes up asking for the scan file, direct it there (Exactly to the file in the cd, it may be hidden inside a few folders) and it should solve that one.
May 08, 2010 | Computers & Internet
Job has been done improperly check log files
Things to check:
Folder Not Found:
Login error:
Jul 30, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Cannot access to the scanner page
Your laptop is not configured properly to the network. You forgot to mentioned what type of scanning. ftp, smb, scan to email scan to box. But any way your IT can help you with this problem. If not I will email you the step by step to configure you laptop.
Jun 24, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Mar 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
236 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
