Question about Pioneer VSX-D704S Receiver
Vsx-d704s When turned on it reads over load
    President:
  • 3,130 Answers
There is a problem with the apeakers, the speaker feed wires or worse case is a blown audio output stage circuit in the amp. Good Luck
Posted on Apr 08, 2007
How to hook up stereo audio receiver VSX - D704S to my laptop
You need an 1/8" stereo jack to rca cord. Plug into headphone out on PC then into back of receiver (I.e. aux/cd). Then turn stereo to that input.
Oct 08, 2016 | Audio Players & Recorders
How do I hook up pioneer stereo receiver VSX-D704S to laptop
Use a headphone jack to rca adapter. Plug headphone into laptop headphone jack and connect rca ends to whichever input you want to use on the pioneer.
Oct 08, 2016 | Pioneer Audio Players & Recorders
How to hook up laptop to pioneer VSX-D704S
just go audio out from laptop,prob use headphone jack with a splitter (so you can do both left and right audio plugs,then into amp say cd in on back of amp,then set amp to cd....
I can't get my tuner to work, but everything else works fine. All I get is static went I turn to the radio stations on both FM/AM
If you are in a fringe area you might need an external antenna to work with your tuner. Happens.
Oct 15, 2015 | Pioneer VSX-D704S Receiver
I have a pioneer vsx-d704s reciever and when it is at a very low to 0 volume i get a low level scratching only on the left side. im not sure if it goes away when i turn it up or not but i dont think so
The volume knob is dirty. Behind the face of receiver the "pot", (as they are called) needs sprayed with contact cleaner. I use CRC QD contact cleaner. If the volume is a slider your can use the straw type devise for pin point spraying in the slider slot with receiver off and unplugged. After spraying work the slider back and forth to distribute the cleaner inside. If you have to remove the cover for a rotary "pot"spray while working the dial. Hope that helps..
Jul 16, 2011 | Pioneer VSX-D704S Receiver
My pioneer VSX-D704S won't turn on. Only The standby light turns on.
Your unit being stuck in standby mode is an indication that its having a power problem. Remove its plug from the wall and fix it back into the wall, then turn it on again. If its still stuck in safe mode, then the power supply board in the unit is the cause of the problem.
The power supply board might be defective and maybe that's why the unit won't power up. Its receiving power but it cannot transfer the current to the necessary part of the unit because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the unit might not come on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Jan 17, 2011 | Pioneer VSX-D704S Receiver
Blown 125v 10amp fuse blown what is the problem?
The problem shall be in the Power section of the amplifier. Check for burned transistors.
Nov 20, 2009 | Pioneer VSX-D704S Receiver
My Pioneer VSX-D704S WILL NOT POWER ON. WHEN I PUSH THE POWER BUTTON NOTHING HAPPENS. THEN THE STANDBY LIGHT COMES ON.
It is in protection and will need to be serviced. Find a local AUTHORIZED pioneer service center.
Jun 10, 2009 | Pioneer VSX-D704S Receiver
VSX-D704S
Have the speakers disconnected and turn on unit. If it still shuts down due to thermal protection the amplifier IC pack is damaged. Amplifier IC is tied to one side of the power supply by design. The left channel is probably shorted at the MOSFET on the pack. Nothing you can do but have it serviced. This is a common PIONEER failure.
Apr 08, 2007 | Pioneer VSX-D704S Receiver
155 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
