SOURCE: how do u replace a shifter cable for a 1988 honda accord lx
remove cable from transmission,follow cable behind engine,along exhaust pipe,then up through floor into center console.along the way you will find retainer clips (on both ends of cable) which hold the cables in place,and also underneath you will find a fastner which holds cable to bottom of floorboards and a panel with a rubber gasket in which the cable goes up into the console through. you must then remove center console to release the other end of cable.Once cable is loose go under car in the middle of the cable and pull out from floor then pull the other end out from engine compartment.
SOURCE: cooling fan only comes on when the AC is on. Have checked relays and fuse.
there are 2 fans 1 for the ac that only comes on when the ac is on thats normal.and the radiator fan that comes on when it reaches 160' to 180'degrees only on electric fans.u might have to reposition the wires on the fan.
SOURCE: Exterior rear door handle on Honda Accord 2001
To Remove Door Panel on 2001 Honda Accord:
A: To remove the plastic piece with the door lock button and door handle connected to it:
1- Remove the screw in the middle located behind a plastic cover button
2- Push (slide) the whole assembly Forward (toward front of car)
Besides the screw, it is held in place by 3 hooks on the backside that hook into holes in the metal door frame
3- Now unhook handle from small metal bar going through door by pushing (toward door) plastic clip (blue?) off of the bar, then the bar will come out of the clip hole, thus releasing the handle.
4- Depress little grey button /bar (purple painted on it)on elec. connector to seperate connector, thus releasing door lock switch
Now the whole assembly (metal handle, door lock switch, and plastic piece) will come off door panel
B: The door is held on by 2-screws, 7-plastic snaps/plugs, and 1-plastic plug.
The screws are located: bottom of hand hold and the other behind the handle, both covered by little covers that have to be pryed off to access the screws.(hint: the screw with the built in spacer goes behind the handle when you are trying to reinstall)
The 7-plastic snaps: 3 across bottom and 2 on each side. Not visible, they are mounted to the inside of the panel.
The 1-plastic plug is visible at the upper front of the panel and is the same color as the surrounding trim
C: Take off the big plastic triangle piece above the door panel and behind the mirror. Pull/pry off. It has 2 snaps holding it on. one near bottom and one near the front.
D: Light lens prys off from bottom. Unscrew (1/4 turn) the light assembly with bulb still intact from backside of panel
E: Remove the Hand-Hold/window switch assembly:
SOURCE: Brake Lamp remains on
This light is controlled by the hand brake,brake fluid level and on some models the brake pad wear indicators.
Low brake pads or a broken sensor wire is a common reason for this problem.
SOURCE: Replacing passenger window in 1998 Honda Accord LX
yes you can replace it, more than likely I would try getting a replacement window from your local import salvage yard. you will need to remove the door panel screws (normally in the small pull compartment to close the door) and one in the latch, both have a plastic cap that needs to be pried up, it is also connected to the screw or bolt. next, you will need a flat blade screw driver or flat pry bar to take off the panel, start at the bottom. it should just pop out (loud snapping noise). In addition, there is a triangular shaped black plastic cap in the corner, that will also pry off. You will need to unplug the window and door lock connector, carefully remove the lining, you should be able to gain access to the two bolts that hold the window in place. you might have to raise or lower the door till you see them in the removal holes, should be a 10 mm socket. After you loosen remove old glass and install new one and re assemble as you have taken apart, Good Luck!!
