Question about Epson Perfection 4870 PRO Flatbed Scanner
Epson 4870 streaking when scanning med format negs
I am using a 4870 to scan old negs (20'x14' with 12 5.25"x3.5" negs) two at a time. I use the batch mode and do two at a time, but am getting streaking in the direction or the scan. The streaking is b&W oh the left and progresses to a bluish streak on the right in prescan and finishes with B&W in the greyscale scan. When I started the project it was working ok and progressed to streaks. For a while it I could turn off the scanner and it would do 1 or 2, but now it just streaks. Any ideas?
  • wayne_degner Jan 23, 2009
    Yes, I use negative and B&W. Maybe I have to think about getting a replacement scanner. Thanks for your thought.
  • dklagoon
    dklagoon Jun 19, 2012
    I'm getting the same thing on B&W large negatives from 1896. Think I'll just go get a new scanner.
    Sergeant:
  • 378 Answers
Its the problem of the rays which your scanner is throwing out to copy the document as its lens is gone weak and the machine needs servicing/cleaning now to work again as normal.just get it serviced it will work properly.
Posted on Jan 09, 2009
  • 4,472 Answers
The short non-technical answer is that the scanner is most likely now defective. How long have you owned the unit? Once I have more information I can recommend the best step to take next, most likely being repair or replacement. Also please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
    Brigadier General:
  • 5,158 Answers
Are you using the setting for scanning b&w ?
Epson 4490 scans with colour streaks/ digital interference
did you properly close the scanner lid? these type of errors do usually occur when you unproperly close the lid wherein light passes inside causing it to reflect on the document that you are trying to scan
Sep 13, 2009 | Epson Perfection 4490 Film / Flatbed...
Epson V300 Photo Scanner Streak When Scanning Negative
I also own a v300, and I have noticed that I occasionally get rainbow streaks if I bump the scanner at all while it is scanning negatives, so this might have something to do with vibrations in the machine. Is it sitting on a stable surface?
Mar 14, 2009 | Epson Perfection V700 PHOTO Flatbed...
Yellow streak through color image scan
http://www.carlmcmillan.com/CanonScanner/Canon.htm
Feb 25, 2009 | Canon CanoScan 8400F Flatbed Scanner
Document Type "Film" greyed out
Close Epson Scan, unplug the TPU, plug it in, turn off the scanner, turn it on, reopen Epson Scan.
Feb 16, 2009 | Epson Perfection 4870 PRO Flatbed Scanner
I have a 3490 scanner but have lost the neg holder to scan negs.
You really cannot scan a neg without a special holder. I recommend paying $90 to Costco and buying their special USB Scanner which scans one neg at atime! They are great!
Thanks,
Mark
Dec 31, 2008 | Epson Perfection 3490 PHOTO Flatbed...
I think your flatbed lamp is damage
if u replace or color it pure white ink
Jun 10, 2008 | Office Equipment & Supplies
Scanner won't scan full frame med format neg 2.25"x2.25"
ll you do is click on the arrow next to preview, and select normal instead of thumbnails. It took me a while to figure that out as well. Also, you will want to scan the film rightside up (opposite of what they say) and flip it in photoshop. When you scan it they way they say, the film touches the scanning bed, creating rings in your photos.
Dec 07, 2007 | Epson Perfection 4870 PRO Flatbed Scanner
Epson perfection 4990 photo scanner
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Sep 25, 2007 | Epson Perfection 4990 Flatbed Scanner
4870 Photo Pro
Hi FYI, A lamp Circuit board and assembly would cost around 80% of the total cost of a brand new printer. Plus labor costs.
Sep 18, 2007 | Epson Perfection 4870 PRO Flatbed Scanner
Epson Perfection 4870 PRO Flatbed Scanner Logo
109 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
