Question about Roper RAS8244KQ Top Load Washer
Washing machine not agitating
My Roper heavy duty washer model# RAS8245EQ is 8 yrs. old and I've never had a problem with it until yesterday when I heard a loud grinding/clicking noise. It fills and empties fine but will not agitate. Is this something that can be fixed easily or would I be wasting my time and money? I would have to have a service person do it as I'm physically not able to do it myself. Hope someone has an answer. Thanks, scalla
  • momma_d12205 Feb 09, 2009
    I have a Roper RAS8245EQ1 heavy duty washer and never had a problem with it til now. It fills up and drains properly but will not agitate or spin.It makes a grinding/clicking noise when turned on. You can turn the agitator full circle by hand and it tries to agitate but can only move an inch at a time.Is there a belt i can replace or are we dealing with plastic gears that are shot? You can email me with any advice.
  • Anonymous Feb 16, 2009
    washer fills and drains fine just wont agitate only if i push it around but have it keep pressure on it then it moves
  • 5,911 Answers
If the washer does not agitate at all, does not spin, but will still drain, this is a symptom of a broken motor coupling.
The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
This is a very simple repair that doesn't cost much. The repair is actually much easier than you think and requires no special tools. The part number is included in the link I provided. Appliancepartspros.com carries a replacement motor coupling for about $11.
NOTE: A broken motor coupling is usually accompanied by a loud rattling noise. You can hear the motor engaging and running, but there is no tub action.
If you need an illustration, you can refer to the website I mentioned and locate item 13 under the Brake/Clutch/Gearcase/Motor/Pump section.
The motor coupling is located between the drive motor and the gearcase (transmission). It takes the place of a drive belt and commonly fails on Whirlpool manufactured top loaders due to normal wear and tear. This configuration is known as a "direct-drive" system. The replacement motor couplings are more resilient and resist breaking better, because the manufacturer added a steel grommet.
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope you find this information helpful.
PS $11 for a do-it-youself repair, with instructions? I think this would definitely be worth your time and effort.
Posted on Oct 11, 2009
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Roper heavy duty super capacity 8 cycle fabric softener mess
check to see when and where you are to add the softener read the manual for tips look in the trouble shooting guide
Jul 06, 2012 | Roper RAS8445KQ Top Load Washer
The agitator is not turning but i can hear the mechanism turning inside the agitator. is there a sheer pin broken? this is a roper heavy duty / large cap.( model #ral5144awo) top load washer.
AGIT DOGS ,,, go get or order whirlpool part number 80040
replace those and you should be good to go.. they are under the cap and have lil grippers on them that wear down and help rotate the agaitator assy..
Jan 28, 2010 | Roper Washing Machines
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Feb 15, 2009 | Whirlpool Washing Machines
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Washer will not agitate with full loads
getting old - thow it out or just use small load
Dec 12, 2007 | Washing Machines
Roper RAS8244KQ Top Load Washer Logo
184 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Sal De
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
