Question about Whirlpool Duet GHW9150P Front Load Washer
My washer door will not lock
When i try to start the cycle it makes a clicking sound and then error coad f22 comes up on the display.
  • 5,911 Answers
"F22" is a Door Lock error code. It's usually an indication that your Door latch assembly is damaged or malfunctioning. Before assuming you have a fault, however, the manufacturer recommends unplugging the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main computer for the washer. In many cases, this is all that is required to corrected momentary glitches. If the problem reoccurs, your next step would be to inspect the door lock to make sure all the electrical connections are in place. If the electical connections are good, it is recommended you replace the door latch. The following link explains:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Keep in mind, you have a newer model washer. The error code you are indicating is the same as the "Fdl" error on older model washers. The procedures for replacing the latch are the same, however. Another method of replacing the latch involves, removing the top panel of the washer and working from the top behind the the front panel. You can use this method if you prefer.
A replacement door latch can be purchased at any of the following websites: searspartsdirect.com, pcappliancerepair.com, repairclinic.com and appliancepartspros.com. Any one of these sites offer great service with competitive pricing. So...check them all out for the best price.
I hope you find this information helpful. Let me know if you require additonal assistance.
Posted on Dec 22, 2008
F22 flashing on hot point washing machine
Google it this is not the hotpoint website .
Jan 06, 2017 | Washing Machines
DRYER DISPLAYS CODE F22. What does this mean?
"F22" is a door lock issue Press the "Stop" button twice to cancel the cycle if "F22" shows. Check that the washer door is firmly shut--open it and shut it and try again. Make sure there aren't items blocking the closing of the door. Don't overload the basket. Try the cycle again.
Nov 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
F22 code ?? duet locks but will not run
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is code F22 on sport duet washer? The locking mechanizm buzzes a little, and when you push start it's locked and stays locked, and you have to stick your hand up in it to unlock it.Thanks.
Thank you !!
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When its turned on makes a clicking sound the in
Hi
Thanks for using FixYa. F22 is a door lock error, this error occurs after the washer has made 6 attempts to lock the door. To resolve this issue you’ll need to check the door switch, door lock mechanism and the wire harness between the central control unit & door switch, replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door will not open has a code 22
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet washer showed F22 error; we followed manual instructions; disconnecting power, etc. but door remains locked and washing cycle won't restart. Help!
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F22 Error Code
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
Sep 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer F22
thats a door lock failure code try unplugging the washer then let me know shut the door firmley before operating
Mar 28, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
99 people viewed this question
Dan Webster
Dan Webster
Sal De
