Question about Intertherm P3RA-048K Air Conditioner
Breaker tripping on electric furnace.
I came home this morning and the system was blowing cold air... Thermostat set on 68 degrees... The breaker in the panel was tripped. It was around 16 degrees overnight here. Never had any problems until now. The breaker is very warm, but hasn't tripped as of yet.. been on and running for about 2 hours.( Bad breaker, heating coil, ?????)
Thanks
  • hickmanjohn6 Dec 23, 2008
    Thank you. Will just get a new breaker and try that first.
  • 833 Answers
First, how old is that breaker and are the connections all clean and tight?  A warm breaker is normal.  If it hot or buzzing, that is another story.  If the breaker is more than a few years old, it may pay to invest in a new one.  They do wear.  If you have a connection which has come loose or is corroded, it will trip the breaker, arc at a connection point or even cause a coil to fail.  Dirty connections heat up and actually back off the holding bolts to the point of failure or to tripping the breaker with arcing.  With the breaker off, inspect all connections from the panel to the unit.  You may get some surprises.
If none of this turns up a problem, inspect the actual heater coil, you may find dirt in there which is causing a problem or the unit itself is failing and touching a grounding point.
Posted on Dec 22, 2008
Home furnace comfortmaker blowing cold air
Home owner's manual? Troubleshooting section. Gas or electric?
If gas, pilot light may be out, or other gas controls. Are you sure you have gas supply? Do you have other Gas appliances so you can check? Furnace needs power for controls, fan and thermostat. Are you sure you have electric power to the furnace? Does the thermostat have a fan switch? If so turn it on and see if the fan turns on. If it does not turn on you may have a circut breaker poped. or some other reason power to the furnace is not working.
Feb 27, 2015 | Heating & Cooling
Why is my furnace blowing cold air?
I depends on if you have gas or electric heat. If electric, you could have blown a fuse. If gas, your pilot light may be out.
Feb 26, 2015 | Heating & Cooling
Auto fan does not start electric furnace
see this causes and fix it. God bless you
If the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel.
If there is not enough heat, raise the thermostat setting five degrees to see if it turns the unit on. If the unit still does not generate enough heat, check the comfort controls . Clean or replace a dirty filter, clean the blower assembly (see the Forced-Air Distribution Fix-It Guide), and make sure that all registers are open and not blocked.
If the furnace turns on and off repeatedly (cycles), clean or replace the filter; and clean the blower assembly (see Forced-Air Distribution Fix-It Guide).
If the furnace is noisy, make sure access panels are mounted and fastened securely; spray squeaking belts with fan-belt dressing and replace worn or damaged belts; adjust the blower belt; lubricate motor and blower oil ports.
If the element does not heat, refer to the Heating Element Fix-It Guide for guidance.
Oct 08, 2012 | Coleman Mobile Modular Home Electric...
I turned my thermostat down this morning to 68 degrees. I came back about 2 hours later to increase the temp to 70 degrees but when I push the ^ arrow instead of showing the increase to 70 it just flashes...
Since it's within 2 degrees of your setting it could be one of two things. Most furnaces run longer (pass your setting) to maintain the setting you made. Which really not a problem. However, your thermostat may need calibrating. To test this theory, place a regular wall thermometer next to your furnace's thermostat and see if the two temps match when the furnace cuts on and then when it cuts off.
If the temps are both the same, the furnace thermostat is fine.
If you're turning it down to 68, because no one will be at home during the day, just set it 2 degrees cooler than 68 degrees. You will then wind up with 68 degrees.
Feb 09, 2011 | Heating & Cooling
I've just moved into a home with an existing Armstrong Concept 10 A/C unit that's at least 15 years old. When I left for a 2-week vacation, the unit was working great. I set the thermostat to 77 to save...
Hello 93 The compressor caused the breaker to trip.A weak capasitor or burnt wire is a common cause.It sounds like the compressor is NOT on even though the fan is.It may need a new wire or maybe a HARD START kit to help restore operation.Call for help.HS kits are not expensive.NO damage results from leaving it on, the problem would have happened anyway even if you went on vacation or not.The curcit breaker stopped it.Its worth fixing.
Aug 30, 2010 | Heating & Cooling
The furnace is blowing warm air even if the thermostat low.
The only thing that tells the unit to come on and off is the thermostat so I would definatly say it is it. When you turn the system back on, does the a/c run normally? If it does, then it's the problem with the heating side of the tstat. Also, does the fan come on when you put it to on and then turn of when you switch it back to auto? If it does, then the system is working fine, its the t-stat. Let me know if you have any more problems.
Mar 23, 2009 | Intertherm P3RA-048K Air Conditioner
30 amp breaker trips intermittently
It sounds like this circuit breaker is worn out and needs to be replaced. good luck
Jan 19, 2009 | Siemens 2 pole 30 amp breaker
Electric Furnace Trips Breakers
it is normal for a breaker that is run right on the edge (50 amp and your furnance to use 45) to get weak after a while . the first thing you should do is change the breaker with the same type and amp rateing . it should take care if it
Jan 16, 2009 | Heating & Cooling
Electric furnace blows cold air before and after warm air.
It is normal. Your house has to go down a couple more degrees because the heat pump is not working. You can solve this by rewirng you thermostat. Take off the wire that goes to Y and tape off. Then take the wires that are marked w and e or w1 and put the wires to yellow. Do not run ac with it wired like this. If you need more information please post me back
Nov 29, 2008 | Heating & Cooling
Intertherm P3RA-048K Air Conditioner Logo
234 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
